Discussing BMR LCA Drop Bracket...Heads up to everyone in the 2005+ Forum. Nice!! I may take you up on that, may do it on the alignment rack ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
#21 |
IBEATU
06 GT & 98 GT
Nice!! I may take you up on that, may do it on the alignment rack too.....I'm so indecisive. Have to do it before MCE day though!! Need to come by and see those wheels/tires too
![]() 98 GT: some stuff 06 GT: some more stuff Paxton/Vortech Crew Member #3 RadMustangs Store Injected Engineering |
#22 | ||
2007 GT
Was that your car JW?
Anyway, glad you got it all worked out and nothing was hurt.
#23 |
Yeah, that was my car. I was having trouble with the driver side front tire coming up (cool looking but I didn't want the chassis flex) so I removed the rear sway bar and put in the BMR XTreme antisway bar kit so I'd have even launches. My son was driving and we had the ET Street Radial tires set at 17psi, the QA1 shocks about half way, and dumping the clutch at 6k. Well, the f***er hooked like it was supposed to and the bracket gave way. Here's normal and the damaged one:
![]() 2005 Mustang GT ???hp/???trq NA all the way, cams and usual bolt-ons 12.40 @ 111 |
#24 |
Authorized Vendor
![]() Join Date: Feb 2009
We definitely recommend welding them. Its sounds to me like the bolts loosened up and the bracket moved. If they were tight the brackets would have ended up like jwgroovin's. If you have any further issues let me know.
Dennis Dunn BMR Fabrication (813)986-9302 Office Hours Mon-Fri 8:30am-6:00pm est. www.bmrfabrication.com dennis@bmrfabrication.com |
#25 | |
2007 GT
I had speculated that someone backed the car into a curb or something and did that but since its you ill give it a legit stamp. Thats what i was thinking. |
#26 |
2005 Mustang GT
View the Anti-Squat Brackets<BR>Part # CHE1L at http://www.cheperformance.com
does anyone have experience with the CHE brackets? they say no welding required, but from everything I've read about LCA drop brackets welding is a must, so I don't know why these are different...
2005 Windveil GT >> ROUSH CAI, FRPP Stingers, Silverhorse Blackout Panel, Brushed "Aluminum" Dash Kit, chrome American Racing ROGUE wheels 20x8.5 with 255/35/20 Yokohama S.Drive tires, ROUSH rear springs |
#27 |
That bracket took two weekends worth of hits while we worked on dialing in the shocks, tire pressure and launch RPMs. Consistent 1.62-1.65s all day long. When Zach (my son) hooked on that last run, I'm betting it would have been an easy 1.5x. the front end lifted, the left front tire got air (street wheels, not my Bogarts!!!!), the rear planted and BANG! That rear tire rotated forward into the wheel well lip:
![]() Lesson learned. Figured I could get by without welding for a couple of trips to the track, but even 348hp NA and a great hook is enough to collapse the bracket.
#28 |
2009 Mustang GT/CS
N/A
what companys brackets were those?^^^^
'09 GT/CS SHOW: GT500 Spoiler, Black Turn Signals, 5k Headlight & Fog HID's GO:Flowmaster 40's, BMR Poly/Rod LCA's |
#29 | |
2008 Mustang GT
They won't bend nearly as readily as the BMR design (steel plate looks thicker and doesn't have that long stretch of metal to bend up, it's all boxed in) and they have lock channels to fit into place so they won't rotate. But, what's it take to weld them in? Besides, the CHE brackets only have one mounting hole, whereas the BMR and other designs have flexibility (no pun intended) for their usage.
Experience is what you get when you didn't get what you wanted.
#30 |
BMR. While I bolted them in, I didn't follow up with welding as indicated in the directions and paid the price. Remember, do it right the first time...
#31 |
It's wise to weld in any LCA relocation bracket.
'05 GT, Whipple, JBA, Zoomers, Centerforce, Metco, J&M, JPC, MGW, FRPP, BBR stage 2 billet cams, McLeod, Diablosport, LFP, Autometer, CDC, tuned by Kevin MacDonald NEED A TIMING CHAIN WEDGE? PM ME |
#32 | |
11.82@118
Maybe I can get replacment nuts sent out to me and i will replace the bolts I used with the BMR included bolts. I recall when i did the upgrade being short on time and anxious to get to the track. Lesson learned...do it right the first time.
06 Paxton HO, 60lb Inj, GT500 pump, 3.16 pulley, BMR LCA Panard Drop Bkt, FRPP spgs, Basssani exhaust, Off X, SLP LLck, 4.10 gear, Weld RT 15x10 rear, 4" ft-MT 28.1 x 12" rear (PB 11.82:1.62 60 ft on 10-25-09 at SDR)Paxton/Vortech Crew Member #4 |
#33 |
2007 GT
Smaller diameter. Ok thats how it can move and not bend. Yea Dennis can help you.
#34 | |
2002 SS
incredibly slow
love you bitch |
#35 |
11.82@118
Update. After resetting the pinion angle to neg 3 degrees the drive train noise was eliminated. Gone. Musta been the angle.
Someone asked why I needed to adjust each LCA equal amounts. That since I have the adjustable LCAs. You have to turn each adjustment nut equal amounts otherwise one will be longer than the other causing your axle to be slightly twisted. I also measured from a fixed point on the body to the center of the bolt that clamps the LCA to the axle mounting tab to make sure they were equal distance as I measured for the pinion angle.
#36 |
2002 SS
incredibly slow
rich is gonna be very interested in this when he reads it... I rep'd ya for that info man, thank you for your research and diligance!!
#37 |
2006 Mustang GT
11.632@116.22
Last season I was cutting 1.6xx 60's without them welded in, but I was running them in the top hole on the relocation brackets.
last week I dropped them to the bottom hole and had them welded in, hopefully next week we will see what kind of difference it made. Also added Cobra Jet rear springs.
Saleen SC,Saleen Super Shaker, 3.2 pulley,60 lb. injectors, GT500 fuel pump,JBA Long tubes,O/R H-Pipe,JBA Axle Back Exhaust,SCT II Tuner,TCI3000,PMP line locks,3:90gears ,Power House Drive Shaft,BMR UCA&LCA[size="4"] |
#38 |
Authorized Vendor
Your car should 60' much better with the arms in a lower hole. Let us know the results of your next trip to the track.
#39 | |
2006 Mustang GT 5spd
12.61@109mph
On BMR's site they have a video with a vert 05 on the stock BFG tires...with the brackets at the bottom hole and their LCA's it got into the 1.8x's on the 60'...damn impressive on those shitty street tires..so i can't wait to see what this saturday is going to be like with the the steeda chromoly LCA, UCA..QA1 shocks..BMR panhard and brace..rear roush springs..325/45 M&H's and skinnies. Its going to be fun im sure..
![]() JLT CAI: KOOKS LT's: Comp NSR II's: 4.56's: TR6060: Steeda LCA, UCA: QA1's: Roush rear springs...see garage for more. Last edited by 06GTMustang89 : November 3rd, 2009 at 01:09 PM. |
#40 |
2006 Mustang GT
11.632@116.22
FORD RACING SPRING KIT DRAG RACE COBRA JET 2005-2010 - CJ Pony Parts, Inc.
price went up on them a little, but if you order on a Friday they give you 10% off.
Threads Similar to: BMR LCA Drop Bracket...Heads up to everyone
| BMR LCA brackets | 06GTMustang89 | 2005+ | 23 | August 12th, 2009 04:22 PM |
| LCA | ia07gt | 2005+ | 7 | July 2nd, 2008 07:05 PM |
| LCA | usafimj | 2005+ | 12 | June 28th, 2008 10:17 AM |
| Bent BMR LCA Relocation Bracket | 05mustang_kb_charged | 2005+ | 13 | June 7th, 2008 05:55 PM |
| LCA Relocation Bracket | orangemonster | 2005+ | 14 | April 8th, 2008 12:54 PM |
