Discussing 2005 auto mustang vibration noise/ rumbling noise in the 2005+ Forum. hi ppl i was on the way back home in a rush so i gave ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
2005 auto mustang vibration noise/ rumbling noisei was on the way back home in a rush so i gave to stang some to get home qwick time. i was doing about 95mhp after i took my foot off the gas i herd some really bad virbration noise/ rumbling noise coming from under the car. even when i looked in the rear view mirror i could see the rear spoiler vibrating i took the car to the garage the next day we lifed the stang up to see if any thing was hitting. we checked the exhaust system to see if it was clearing everything that was ok. the only time the vibration would happon is at high speed and only when i would take my foot off the gas at high speed any ideas people ?????????????????????? thanks 2005 mustang GT auto Stoptech gt stage 2 braking system Kenny brown strut tower brace Bmr rear swaybar Bmr lower rear control arms eibach pro kit springs Bbk airfilter kit Bbk ceramic short headers Magnaflow x pipe with racing cats Magnaflow Cat-Back Exhaust System Bbk 62mm twin throttle body Moto blue under drive pulley kit brentspeed Sct tuner Ford racing 4.10 gears Comp cam racing cams stage1 comp cam valve steel retainers comp cam valve springs Ford racing cmcv delete kit tci torque converter 3000stall |
07 MUSTANG GT
12.86@104
you could possibly have a bent axle
i also see you have the FRPP charge motion delete plates.......do you like them over the steeda. i ask because they are under a hundred bucks unlike the ones from steeda
JLT CAI, SCT Tuner, Eibach Pro Kit, D-specs, BMR LCA's, Adj. Panhard bar&support, Tri Axe w/ pistol grip, FRPP X-pipe, SLP loudmouths, Konig Beyond w/ BFG KDW's, MT ET Streetson order: GT/CS bumper, BMR shaft loops, black grill upper and lower. |
#3 | |
im starting to think now maybe when i had a dyno run they did strap the rear of the car on the right side of the axel but im sure it cant bend it that easy. can it ? + im thinking cant it be one of the bearing on the driveshart |
May want to check if the tires are balanced
#5 | |
Threads Similar to: 2005 auto mustang vibration noise/ rumbling noise
| 2001 mustang 5 speed vs. 2005 mustang auto. | DannyStu | Drag | 20 | October 6th, 2007 10:55 AM |
| Shifting problem and noise on auto after tune | F350toGTstang | 2005+ | 14 | September 18th, 2007 12:40 PM |
| 2005 Mustang GT Auto Gear Box Noise | ozan169 | 2005+ | 10 | September 16th, 2007 11:18 PM |
| V6 2000 Mustang Help. What is that noise?!? | Mrs_Mustang | V6 Mustangs | 8 | April 27th, 2007 12:55 PM |
| 2000 Mustang V6 rear end noise | Makikun | Drivetrain | 6 | December 29th, 2006 08:48 PM |
