Discussing so let me see if i understand this... in the 2005+ Forum. these new engines now-a-days have 2 cam shafts? wtf.......... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
1965 Mustang Fastback
so let me see if i understand this...wtf....... |
I Touch Myself Sometimes
91 Sonic Blue Goodness
19.83 @ 12mph
yup.
![]() MILITARY CREW FOUNDER SCT Custom Tuning, JLT intakes, Aeroforce Interceptor OBDII gauges and PLX widebandsemail joe@tricktuners.com |
Along with 8 coils and 8 injectors. In order to make room they did away with the distributor and carburator. I had a 66 FB and was tired of tuning every Monday and Thursday to drive Fri thru Sun ... not to mention the burned valves and weak rings.
Now say it with me ... WTF |
Rockin the Casbah
12.88 @ 112
some of them actually have 4
03 04 cobras and machs have 4 cams...lsx has 1, 2 & 3v modulars have 2, 4vs have 4...
![]() 2005 GT, Bolt-Ons, into a 40mph headwind, 13.20 @ 103.5...UGH 1993 XJ 4x4 4.0 M5 214k mile hoss! 2006 F150 Crew Cab...Work Truck |
2007 Mustang GT
12.49 @ 105.67
Not to sound condescending, but do you no know the difference between an OHV overhead valve (the cam being in the block, above the crank actuating pushrods that actuate the rocker arms that actuate the valves), and an SOHC single overhead cam (one cam in each head actuating the cams, and DOHC dual or double overhead cam (2 cams in each head vice on, typically with a high valve per cylinder count). AND there are even "hybrids" where a SOHC will still have the cam in the block actuating either the intake or exhaust valves just like an OHV engine but still have overhead cams doin the other valves. There are even more variations on engine designs those are just the most common.
GT 5sp Grabber OrangeFor mods check my garage. 335 rwhp, 330 rwtrq Naturally Aspirated 439 rwhp, 465 rwtrq 100 Shot Times are still from N/A unfortunately and before the cams 60ft: 1.6849 1/4: 12.4969@105.67 |
#7 | |
1991 LX, 2003 SNK, 2007 S
11.3
First off the mods are a Single over head cam and the 2,3,4 are the numbers of of valves per a cylinder not cams |
2007 Mustang GT
12.49 @ 105.67
He was correct he just worded it a little ambiguously.
11.3
cars dont have 4 cams 4valves yes but theres only one cam in the cobra and if im wrong then its 2
11.3
o well everyone makes mistakes
2007 Mustang GT
12.49 @ 105.67
you are wrong, the cobra has 4 cams, 2 in each head. One cam operates the 2 intake valves in each cylinder and the other cam operates the 2 exhaust valves in each cylinder. Hence the Dual Over Head Cam, 4 total. Thats not all that crazy either, there is and Opel that has 6 valve per cylinder, and some other car whose manufacturer I cant remeber now has quadruple over head cams, thats right 4 cams per head 8 total in the car. Now thats amazing, imagine the size and complexity of that engine.
11.3
Double overhead cams, four valves per cyclinder, 4.6 L / 280cid, 90° V-8, cast iron block, aluminum heads, forged crankshaft
Bore x stroke: 90.2 x 90.0mm Compression ratio: 8.5:1 Horsepower: 390 hp @ 6,000 RPM (85 Hp per liter) Torque: 390 lb./ft. @ 3,500 RPM Fuel Delivery: Sequential electronic fuel injection Induction: Eaton Generation IV Roots-type supercharger/water-to-air intercooler with boost pressure @ 8.0 PSI, Aluminum intake manifold / tuned equal length runners, 57mm twin bore throttle body, 90mm mass-air sensor Ignition: Distributorless coil-on-plug |
11.3
thats on 03 cobra need anymore proof
11.3
http://auto.howstuffworks.com/camshaft.htm
go to this website and read then youll understand |
2007 Mustang GT
12.49 @ 105.67
OK, well that thread you posted only makes what I just said sound correct. What is it your confused about, I thought I explained myself pretty clearly. Just tell me and I'll try better to explain it.
2007 Mustang GT
12.49 @ 105.67
I know exactly how they work, I wouldnt have went into so much detail if they didnt. Thats just a generic picture and explanation. Good grief man I'm just trying to help you out.
19.83 @ 12mph
it's simple.
a Terminator. 4 cams total. 2 in each head 4 valves per cylinder. 8 cylinders. which equals 32valve DOHC v8
11.3
the way im understanding you you were saying for 4cams there is
DOHC meaning 2cams And SOHC meaing a single cam IM sure we both understand just not each other |
19.83 @ 12mph
it's either a single cam per head or 2 cams per head.
(red lines represent camshafts)
11.3
Ok never mind
Threads Similar to: so let me see if i understand this...
| I Don't Understand.... | joejoe8455 | The Clubhouse | 47 | August 4th, 2007 02:49 PM |
| help me understand turbo | aaddmm18 | V6 Mustangs | 1 | March 31st, 2007 11:43 AM |
| Someone help me understand this. | energiesource | 99-04 | 2 | October 6th, 2006 09:09 AM |
