Go Back   Forums at Modded Mustangs > Mustang Forums > Modular Mustangs > 2005+
Discussing New drivehsaft gettin here tommorow!!! in the 2005+ Forum. Well, I called around to every distributor that sold aluminum DS's for our cars. ...
Old June 3rd, 2007, 07:17 PM   #1
RStrick0352's Avatar
2007 Mustang GT
11.40 @ 121 mph
Well, I called around to every distributor that sold aluminum DS's for our cars. Everyone had the same story about Dana Spicer goin through bancruptcy and that they couldnt tell me how long it would take before they could get one for me, soooooooo, I called the Driveshaft Shop which is located here in NC and the guy tells me "look our steel one is stronger and weighs only 4lbs more than the aluminum, so the diff in weight is negligible and that the steel tends to be less vibration prone" so they sold me on the steel DS. They finished building it friday so it should be here tommorow or tuesday. I cant wait to get rid of that damn hanger bearing and that DS that looks like it belongs under an F-350. Cant wait to let yall know how differently the cars drives, I'm sure it will be huge!!
GT 6sp Grabber Orange
For mods check my garage.
349 rwhp, 331 rwtrq Naturally Aspirated
445 rwhp, 495 rwtrq 100 Shot
60ft: 1.74
1/4: 12.15 @ 112.43 N/A
60ft: 1.71
11.40 @ 121.18 100 shot Nitrous
Old June 3rd, 2007, 08:12 PM   #2
Modern_Muscle's Avatar
how much did you get it for? I might wanna check into that...lol
2005 GT, Bolt-Ons, into a 40mph headwind, 13.0 @ 105.5...UGH
1993 XJ 4x4 4.0 M5 214k mile hoss!
2006 F150 Crew Cab...Work Truck
Old June 3rd, 2007, 09:21 PM   #3
2007 Mustang GT
11.40 @ 121 mph
Heres the web address for the shaft. http://www.driveshaftshop.com/item168735.ctlg
If you have any questions just give them a call, the staff was very polite and helpful.
60ft: 1.74
60ft: 1.71
Old June 3rd, 2007, 09:22 PM   #4
2007 Mustang GT
11.40 @ 121 mph
60ft: 1.74
60ft: 1.71
Old June 4th, 2007, 01:22 AM   #5
You will notice a big difference. I have the carbon fiber in mine, and wow, how much smoother the ride is. Also felt faster of course.
Old June 4th, 2007, 01:57 AM   #6
Regency 2007's Avatar
F-150 FX4
Give me some feedback after you get your new shaft in, my tuner who is doing my Helion install also installs aluminum driveshafts and I think it costs around $700.... wondering if it is worth it....
Old June 4th, 2007, 03:44 AM   #7
PaperCross's Avatar
2007 Mustang V6
does it require a new tune?
Old June 4th, 2007, 11:11 AM   #8
05mustang_kb_charged's Avatar
2005 Mustang GT
Dyno Racer
no it doesn't need a tune. the reason for it being faster is the rotational weight between the transmission and the rear end is greatly decreased. it doesn't give you any horsepower at the motor but they have seen as mush as 15 rear wheel increase when removing the stock shaft and replacing with a one piece lighter one. reduces drive train loss, it is more efficient.
Old June 4th, 2007, 03:52 PM   #9
PaperCross's Avatar
2007 Mustang V6
cool...i thought maybe the rotational increase required a re-tune....thanks for clarifying that...
Old June 4th, 2007, 04:56 PM   #10
If you install your own...
DON'T OVER TIGHTEN the Pinion Flange nut and for the LOVE of GOD don't use an impact wrench either.
It's a shame that statement was not in my install instructions.
700$ mistake.
Old June 5th, 2007, 05:42 PM   #11
2007 Mustang GT
11.40 @ 121 mph
thanks for the warning man, how much do you recommend to torque them down to
60ft: 1.74
60ft: 1.71
Old June 5th, 2007, 05:58 PM   #12
It's been a while, lemme go dig it up.
Old June 5th, 2007, 06:23 PM   #13
The 12mm 12 point nuts you want as tight as you can get them, or as they say "Torque specs are till your eyes pop out."
IRS Torque Specs:
Subframe-to-body bolts 76 lb-ft
Subframe-to-rear bracket bolts 76 lb-ft
Subframe rear bracket-to-body bolts 59 lb-ft
Shock absorber-to-lower arm and bushing bolts 98 lb-ft
Shock absorber-to-body nuts 30 lb-ft
Upper arm and bushing-to-subframe nuts 66 lb-ft
Upper arm bushing-to-knuckle nut 66 lb-ft
Lower arm and bushing-to-subframe bolts 184 lb-ft
Lower arm and bushing-to-knuckle nut 85 lb-ft
Toe link-to-subframe nut 35 lb-ft
Toe link-to-knuckle nut 35 lb-ft
Stabilizer bar bracket bolt 41 lb-ft
Stabilizer bar link nuts 35 lb-ft
Rear axle diff rear insulator-to-axle housing bolts 76 lb-ft
Rear brake disc dust sheild-to-knuckle bolts 89 lb-in
Brake line-to-rear brake caliper bolt 30 lb-ft
Parking brake cable bracket-to-lower arm bushing bolt 11 lb-ft
ABS sensor bolt 17 lb-ft
Axle shaft-to-hub retainer 240 lb-ft
Driveshaft to pinion flange 83 lb-ft
Wheel nuts 95 lb-ft
Old June 5th, 2007, 07:20 PM   #14
2007 Mustang GT
11.40 @ 121 mph
thanks dude, your the man!!
60ft: 1.74
60ft: 1.71
Old June 6th, 2007, 11:18 PM   #15
Authorized Vendor
mustang fanatic's Avatar
06 GT
I heard that with the aluminum driveshafts they tend to brake off at high speeds 100+. Is this true?
2005-2009 Mustang Performance Parts
Register for our Newsletter and receive special sales and promotions
Old June 6th, 2007, 11:19 PM   #16
Authorized Vendor
06 GT
Break off is what I meant. Dont want to look like a total idiot
Old June 7th, 2007, 06:59 AM   #17
It has happened but it's not the norm.
If they fail it's usually due to a bad install.
Driveshaft safety loops can provide some security in the event of catastrophic failure and they aren't that expensive.
Threads Similar to: New drivehsaft gettin here tommorow!!!
Starting it up tommorow 89LX347 5.0 Mustangs 56 October 1st, 2007 01:51 AM
PI Cam Tommorow HELP 97redgt 96-98 2 August 25th, 2007 10:19 AM
ordering tommorow *poll* 232stang The Clubhouse 5 August 2nd, 2007 11:52 PM
Replacing O2 Sensors Tommorow Which Ones to Get? Bigb2000GT 99-04 9 March 23rd, 2007 10:14 AM
Installs happening tommorow flattusmaximus78 2005+ 3 February 15th, 2007 01:31 AM
