Discussing Red Line Synthetic Oil?? in the 2005+ Forum. Anyone here running this stuff...the guy at the store said that there is 10 ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
Anyone here running this stuff...the guy at the store said that there is 10 hp in this oil if you put it in your complete drivetrain...Anyone else hear this?
10 hp from swiching oil....im sceptical!
07 GT Chrome footprint gas pedal Fuzzy dice Comfort grip steering wheel cover Custom 8 track install |
#2 | |
Re: Red Line Synthetic Oil??
a read: http://www.automedia.com/Oil/Viscosity/ccr20040601ov/1
Tdog 2007 mustang GT 5speed, Black |
royal purple, amsoil, castrol, all full syns have that gain.
I had an article faxed to me when I worked at an oil place of an independent test done, AMSOil cam out on top, then the european castrol...royal purple was 7th out of 9...it held waaaay too many metallic particles, and even pieces...thats when I switched. Amsoil 0w20 full syn and k&N filter...
![]() 2005 GT, Bolt-Ons, into a 40mph headwind, 13.0 @ 105.5...UGH 1993 XJ 4x4 4.0 M5 214k mile hoss! 2006 F150 Crew Cab...Work Truck |
How many miles before u switched to 0/20?
OIL
I use Redline in my tranny & rear end, but Mobil 1 in the engine.
i used mobile one in the eng. with the mobile one filter and i haven't had any problems. i used to use all that red line oil for my wrx and i wasn't to happy with it.
2007 Mustang GT
12.3@113 1.8 60'
Synthetic oil is synthetic oil is synthetic oil...you're gonna see better performance, less burn off, and better protection no matter what brand you get. I change my oil and filter every 5000, and the oil still looks brand new at the change...it doesn't soak up crap in the carbon and push it through your motor like conventional oil...puts it in the filter where it belongs. If your oil is still clear when you drain it, that's a good indication that it's working properly, and your motor is still sealed up and getting the protection it needs.
HMUSN: "I was rewarded with a fart of colossal magnitude -- a cross between the sound of someone ripping a very wet bed sheet in half and of plywood being torn off a wall." |
2007 Mustang GT
12.3@113 1.8 60'
Doesn't hurt to have an oil sample analysis done at about 30000 miles either, just to see what particulate matter from cylinder walls, bearings, etc. are in it, 'specially with forced induction. They can tell you what's wearing, and if somethings about to fail, they can tell you that too just by seing how much of what types of metal are in your oil.
I started running mobile 1 in the engine a few months ago. Can't really say that I have seen a power increase, but I have picked up a couple mpg's. Here soon I want to put in 4:10's and will switch to synthetic in the rear at that time.
05 Mustang GT |
Threads Similar to: Red Line Synthetic Oil??
| Synthetic | Youngin | V6 Mustangs | 43 | August 31st, 2007 12:02 PM |
| synthetic oil ? | Blackbeauty v601 | V6 Mustangs | 6 | July 31st, 2007 11:05 AM |
| Synthetic or Regular Oil | PaperCross | General Tech | 28 | May 2nd, 2007 07:31 PM |
| Synthetic vs. semi synthetic vs. standard | stagecrewgod | Engine | 2 | March 29th, 2007 10:33 AM |
| Synthetic Oil | TedG954 | 2005+ | 33 | March 5th, 2007 12:23 PM |
