Go Back   Forums at Modded Mustangs > Mustang Forums > Modular Mustangs > 2005+
Discussing Clutch Install in the 2005+ Forum. I checked on this Centerforce Dual Friction I got, and it comes with the pressure ...
Old June 26th, 2007, 05:01 PM   #1
Modern_Muscle's Avatar
Clutch Install
I checked on this Centerforce Dual Friction I got, and it comes with the pressure plate and disc, also needs a new slave cylinder and a bearing I think when its installed, but says I need the flywheel re-surfaced or a new flywheel. I have 37k on my car. Is that really needed, or will a good cleaning get it alright. If I need a new one, im just going to wait for an aluminum flywheel and aluminum d/s for total weight savings...
any opinions or comments?
2005 GT, Bolt-Ons, into a 40mph headwind, 13.0 @ 105.5...UGH
1993 XJ 4x4 4.0 M5 214k mile hoss!
2006 F150 Crew Cab...Work Truck
Old June 26th, 2007, 07:40 PM   #2
All Throttle with a Bottle
MustangMatt96GT's Avatar
12.91@105.29 @ 5800 FT
Get the new flywheel because if not you will tearing your car apart a lot quicker!! You have it apart and it will benefit you to replace it now! If you had less than 10K miles I would say your safe, but get the new flywheel! Otherwise you will get hot spots that will be horrible!
We expect shit to break, look foward to realizing exactly when it is happening, and than obsess about dropping plenty of cash to rebuild stronger, so we can try to run it hard as hell and break again. We are sick individuals.
I support the MM Staff
Old June 27th, 2007, 07:51 AM   #3
GT/CS's Avatar
What kind of friction surface did you go with, kevlar?
Ford Racing heads, Comp stage III cams, 4.10's, Steeda delete plates, SLP long tube headers, Custom 3'' X pipe, Magna flow 3" Magnapacks, Airaid CAI, SCT XCAL 2 93 tune, Steeda front and rear swaybars, Dynotech aluminum driveshaft, HTP TB spacer
Old June 27th, 2007, 12:33 PM   #4
MMs Official Playboy
1FastFox's Avatar
2006 Aston Martin DB9
When it comes to clutches I love SPEC ( specifically stage 2 ). Definitally dont go throwing a new clutch in with resurfacing/replacing your flywheel. You wil be hating yourself in a month for not doing it. As for the bearing, you dont need to replace your throwout bearing, just be sure to lube the shit out of it. Your slave cylinder should be fine too.
Old June 27th, 2007, 02:13 PM   #5
I think so, I got it off a guy that had it on for only around 100-125 miles, then had to remove it cause his knee went out on him, and he went to stock to sell the car I beleive.
The puck side is a carbon composite, I just looked it up.
Part Number df611679
Old June 27th, 2007, 02:52 PM   #6
1FastFox's Avatar
Not to bring you down about your new clutch. But thats not really something I would put in my car used.... Might want to look into a new one...
Old June 27th, 2007, 03:23 PM   #7
Regency 2007's Avatar
F-150 FX4
go ahead and get an aluminum fly wheel, also make ure you break your clutch in good or you will just be buying another one in a short amount of time (500 miles with alot of stop and goes and nothing over 3,000 RPM)
Old June 27th, 2007, 05:39 PM   #8
well, i looked at it before I bought it, and the damn thing looks brand new, i mean lightly dirty, but perfect, thats the only reason I bought it.
Threads Similar to: Clutch Install
Centerforce Dual Friction Clutch Install SilverStang03 99-04 8 September 21st, 2007 03:01 PM
Clutch install ?'s SS07GT 96-98 4 June 13th, 2007 01:39 PM
CLUTCH AND CLUTCH CABLE MAJOR PROBLEMS Hububula 5.0 Mustangs 3 May 28th, 2007 11:08 AM
clutch install? superbeef1000 99-04 11 May 12th, 2007 05:15 AM
Clutch install please help jtlogruss08 V6 Mustangs 8 March 4th, 2007 03:04 AM
