Discussing Idle problem /// Need some help ! in the 2005+ Forum. When I am driving and push in my clutch, my idle will move up and ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
When I am driving and push in my clutch, my idle will move up and down from 500 to 800 until I come to a complete stop. I have checked for vac leaks, changed my pcv valve, checked for exhaust leaks. I do not think it is my tune because I put it back to stock and it still done it.
I have an 05 gt with a vortech s-trim, xpipe, flowmasters and 4:10 gears. It seems that it did not start until my gears were installed. Maybe just a coinsidence. any help would be great !!!!
granny shifting, not double clutching like ya should. You could win by an inch or a mile...winning is winning. |
is your air filter on your S/C breathing okay ? Idle is when the engine is at its weakest for sucking air. If you have blockage, this is where it could be.
Fuel too.
Tdog 2007 mustang GT 5speed, Black |
yes it seems to be ok, I can hear it pretty good, what can I check as far as fuel ?
replace fuel filter. Before that though I'd go and buy gas from somewhere else. It could be gas. And, based on your tune for your S/C, you could be running the wrong octane.
I usually buy 93 octain, when I buy 92 octain I cant tell any difference. I have not checked the fuel filte. I will check and see what it is tuned for.
GO to your garage and get a tune and/or your tune looked at. Follow the specs for gas that they tell you to the letter. Given you are supercharged, it could be the tune.
I dont understand why it has not done it the whole time I had the tune though.
hard to say then. could be gas, fuel filter, air filter prob...so hard to know unless you take care of each one at a time
I going to replace the fuel filter today, thanks for the help !!!
2007 Mustang GT
12.3@113 1.8 60'
Drain all the fuel out of your system. Have a bonfire. Roast some weiners. Fill up at a different gas station that gets more business. Had the same thing when I filled up at a casino gas pump...loosely regulated...also got a lot of surging when I opened the throttle. Only thing I can think is the PCM was pulling timing waaaay out...
HMUSN: "I was rewarded with a fart of colossal magnitude -- a cross between the sound of someone ripping a very wet bed sheet in half and of plywood being torn off a wall." |
changed my fuel filter and it is still doing it. It cant be the gas it has been doing it for over a month.
2007 Mustang GT
12.3@113 1.8 60'
I thought it couldn't possibly be gas with my 350z either...I was just filling up at the wrong gas station...new gas and it never came back.
I have noticed something else today, if I am in neutral and I just tap the gas pedal down like an 1/8 of an inch the idle goes down to 500 then goes back to 900 where it is set.
Threads Similar to: Idle problem /// Need some help !
| umm have a weird problem? idle problem? | blue03mach1 | 99-04 | 16 | March 4th, 2008 01:03 PM |
| HELP!!! idle problem ????????? HELP | das50cal | 2005+ | 1 | June 9th, 2007 09:25 PM |
| Idle Problem | jtlogruss08 | V6 Mustangs | 16 | May 22nd, 2007 05:21 PM |
| 99 3.8 with problem Idle | nweatherby | V6 Mustangs | 5 | April 3rd, 2007 04:13 PM |
| need help with idle problem | cooktheworld | 5.0 Mustangs | 2 | August 21st, 2006 10:54 PM |
