Discussing by pass valve in the 2005+ Forum. Whats the by pass valve that bossman has? and can somone explain to me it'... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
1993 5.ohhhh
14.47 at 96 mph
by pass valve
Whats the by pass valve that bossman has? and can somone explain to me it's function.
302 h/c/i
The bypass valve is a release which vents off pressure in a rapid de-acceleration situation. When the Supercharger is producing boost and you abruptly let off the gas, closing the throttle plates, the boost has nowhere to go (also known as compressor surge) kind of hard on everything. The Bypass helps relieve this and also helps smooth out your idle. It is also helpful in building up boost faster, and as a bonus, it helps to prevent parasitic power loss. Under idle or normal driving (vacuum) the valve is open. When it sees a boost signal it closes.
http://home.alltel.net/mcfly/bypass_valves.htm http://www.superchargersonline.com/content.asp?ID=14 There is more from many other places.
It is only a machine. |
F-150 FX4
I have one very loud bypass valve on my Hellion turbo kit.
Nothing like running wide open by someone with that loud v8 growl then let off and you hear a loud "pssshhh" Sometimes I feel like a ricer becuase my car makes that noise
I aughta slap you for degrading the noise of a Turbo with the term rice...
Threads Similar to: by pass valve
| will i pass emissions | mustang2517 | 99-04 | 21 | October 17th, 2007 02:38 PM |
| turbo by pass valve | wadman | 2005+ | 7 | October 15th, 2007 10:48 PM |
| by pass valve | flattusmaximus78 | 2005+ | 8 | August 10th, 2007 05:22 PM |
| Pass on Gas 15 May... | WAR-PARTY | The Clubhouse | 33 | May 5th, 2007 03:18 AM |
| Video of 11.4 pass and slo-mo of a launch | mdvaldosta | Videos | 20 | February 22nd, 2007 02:58 AM |
