Go Back   Forums at Modded Mustangs > Mustang Forums > Modular Mustangs > 2005+
Discussing SCT Trouble Codes! What to do? in the 2005+ Forum. Just installed my JLT CAI and Bama tune (93 torque)... now my check engine light ...
Old July 6th, 2007, 11:55 AM   #1
wormster00's Avatar
Just installed my JLT CAI and Bama tune (93 torque)... now my check engine light is on and the codes are P0171 and P0174 (both say running too lean). How can I fix this?
Thanks!
Are you like Pedro's cousins with all the sweet hookups?
Old July 6th, 2007, 12:01 PM   #2
2006 GT
11.99@114
Be sure that the tune actually loaded up. Check for air leaks. Then remove your positive cable from your battery for about 15 minutes and replace that should do it.
Aint gonna happin.
http://i3.photobucket.com/albums/y51...hn/front-1.jpg
Old July 6th, 2007, 12:05 PM   #3
wormster00's Avatar
I know that the tune loaded successfully. I'm going to check for air leaks now. Shouldn't the tuner clear the code w/o having to disconnect the battery?
Thanks! I have to drive 5 hours tomorrow so I'm freaking a little...
Old July 6th, 2007, 12:14 PM   #4
wormster00's Avatar
I couldn't tell if I had any air leaks... everything seems snug, but with all the air coming off the fan, it's hard to tell. The SCT wouldn't clear the trouble code which probably means it wants whatever is causing the lean condition to be remedied before it'll clear it... God knows I don't want to change any of the parameters in the tuner w/o some help!
Old July 6th, 2007, 12:29 PM   #5
Make sure all you hoses are correctly hooked up.. also dude call bama maybe he made a mistake doing your tune!
Originally Posted by TheUNZippee!
Originally Posted by BWAL09
im pulling my information out of my ass, just like i always do.
There sure is a lot of...shit in your ass.
http://www.danasoft.com/sig/sign2231.jpg
Old July 6th, 2007, 12:45 PM   #6
wormster00's Avatar
Not answering his phone until Monday so I e-mailed him. Hope he replies today since I'm leaving in the morning for 12 days!
Old July 6th, 2007, 01:10 PM   #7
2006 GT
11.99@114
Did you try the battery? Make sure the MAF is connected correctly. I believe its directional.
Aint gonna happin.
Old July 6th, 2007, 01:54 PM   #8
Chuck Norris of Mods
06RedfireGT's Avatar
2006 Mustang GT
In the 13's
the MAF is directional, you might have installed it the wrong way. check that.
Old July 6th, 2007, 02:32 PM   #9
wormster00's Avatar
I double checked the direction of the MAF... it points toward the throttle body (according to the install directions). But Doug e-mailed me back with another file to replace the 93 torque tune that I was having problems with. He said he hadn't adjusted quite right for the JLT on that tune (but the 87 and 93 performance tunes were fine)!
I had tightened everything down again and disconnected the battery. Then I went through the procedure in the owner's manual about getting the computer to relearn the idle. If you didnt know, anytime you disconnect the battery, you're supposed to let the car idle for a minute, then turn on the AC and let it idle another minute, then drive about 10 miles.
This corrected the CEL, and I might've been okay, but Doug got back to me in less than an hour!!!!!!!!!!!!!!!!! I downloaded the corrected tune and uploaded to my car.
If I have any more problems (and I don't think I will), tomorrow's 300 mile trip to Boone will expose it.
THANKS!
MM folks rock!
Old July 6th, 2007, 03:00 PM   #10
2006 GT
11.99@114
Just for shits and giggles you might want to throw your ford stuff and few tools in a box and bring with.
Aint gonna happin.
Old July 6th, 2007, 03:14 PM   #11
2006 Mustang GT
In the 13's
are you talking about boone, NC? if you are you are a lucky bastard. i love the mountains. its beautiful up there. and i agree with 1loudgt bring the ford stuff just in case. its like a condom. you'd rather have it and not need it then need it and not have it.
Threads Similar to: SCT Trouble Codes! What to do?
Trouble Codes GTsetGO Modular Mustangs 15 December 4th, 2007 03:13 PM
trouble codes...HELP!!! sleezy 96-98 6 July 10th, 2007 10:06 PM
Trouble codes bigbadtalontsi 5.0 Mustangs 3 March 30th, 2007 12:26 AM
trouble codes scubasteve041186 V6 Mustangs 2 December 31st, 2006 11:19 AM
trouble codes.... stang fanatic General Tech 0 July 6th, 2006 11:36 PM
