Go Back   Forums at Modded Mustangs > Mustang Forums > Modular Mustangs > 2005+
Discussing C&L CAI Installation - Filter Shroud - Question in the 2005+ Forum. Hi everyone, Although I haven't chimed in very often, I've been reading the ...
Old August 5th, 2007, 01:30 PM   #1
2007 Mustang GT
Hi everyone,
Although I haven't chimed in very often, I've been reading the blogs in here every day for about the past year. Y'all are always a good source of information and entertainment ... and now I have a question for anyone who has done the C&L CAI install.
I finally got my C&L CAI "Racer" kit with the X2 tuner from Doug at BamaChips. I have an '07 GT. My main question relates to the filter shroud / heat shield - Is it supposed to sit with the bottom (floor) and top edge level to the ground, or is it supposed to sit slanted foward, with the front edge (the one sitting near the radiator) a couple of inches lower than the back edge? I've looked at lots o' pictures of the system ... it's hard to tell, but I've always imagined it sitting level to the groung. Mine won't sit that way (i.e., the contours of the shroud don't fit to the contours of the top of the wheel well if you try to make it sit level).
At first, I thought they might have sent me the wrong shroud, but Doug says that the shrouds for all of the different systems (for V6, GT, etc.) are the same. Maybe it's just the fact that I've always imagined it sitting in there with the floor of the shroud level to the ground (it just looks weird to me leaning forward), but I've actually started wondering whether my car (an '07 delivered in March) has a differently shaped wheel well or a mounting hole in a different location.
I've attached pictures so you can see what I'm talking about. As you can see in the second picture below, the lip where it mounts to the wheel well is slanted upward compared to the bottom floor and top edge. And since the mounting location above the wheel well sits pretty much level to the ground, it makes it impossible for the shroud to sit level once you bolt it down.
Let me know your thoughts.
Also, even with it installed slanting forward, the lines you can see in the lower left corner of the first picture seem to be in the way. Are those my ABS lines? The C&L instructions say that the ABS lines may be in the way and that I should "pull the rearmost ABS lines towards the forward of the vehicle so that they clear the bottom of the filter shroud." They are certainly in the way, but it seems to be the front edge (not the bottom) that is having clearance problems. And the instructions say that "they should move easily, and not require any real effort." If those lines in the lower left corner of my picture are the ABS lines of which they speak, they are hard (metal) and don't budge. Are the instructions implying that the nuts holding them in place should be loosened and that then they will swing a little out of the way without any real effort?
I hope all of that makes sense. I don't know if any of you have encountered these same things, but I'll appreciate any help / information / suggestions y'all can offer. Thanks in advance.
'07 Alloy Grey Metallic GT
Steeda UDP's
Steeda Upper & Lower Control Arms
BMR Lowering Package
C&L Racer CAI
SCT X-Cal 2 Tune - BamaChips
Wheels - Shelby TT's (18x10 rear, 18x9 front)
Tires - Nitto 555s (285/40 rear, 255/45 front)
Old August 5th, 2007, 01:36 PM   #2
Shite Mod
TheUNZippee!'s Avatar
2007 Mustang GT
282 rwhp/292 rwtq
Location: Beside a bubble. Wife calls it a 'clown tent'. Somewhere up north, eh.
My Airaid actually uses the bolt that holds that ABS junction block down as an additional mounting point for the shroud. Are you sure there is nothing like that for the C&L?
Dyno Pull/MBRP's - The pee Test
My Mods
Originally Posted by goober
i couldn't find a midget on a bike. well i couldn't find a naked midget on a bike
Old August 5th, 2007, 01:37 PM   #3
Shite Mod
2007 Mustang GT
282 rwhp/292 rwtq
p.s. If need be I can take a picture of mine for you, although I have no idea if the Airaid mounts similarly to the C&L.
My Mods
Old August 5th, 2007, 06:01 PM   #4
2007 Mustang GT
The C&L shroud bolts to the stock airbox hole, with zip-ties to fasten to ASB lines (for extra support). The other C&L version (not the "Racer" like mine) also has a mounting bracket that bolts to the valve cover. It sounds like the Airaid is a completely different set-up. Thanks, though.
Steeda UDP's
C&L Racer CAI
Old August 5th, 2007, 06:27 PM   #5
Shite Mod
2007 Mustang GT
282 rwhp/292 rwtq
Ah I see. Sorry I couldn't be of more help, then man.
My Mods
Old August 6th, 2007, 12:42 AM   #6
Red ♥ Zippy
06RedfireGT's Avatar
2006 Mustang GT
In the 13's
I saw a vid of how to install a C&L intake (non racer) and the way it mounted was the inlet tube went on the throttle body the the shroud went around the inlet tube the it attached to the inner fender using that one hole, and then the filter cone attached to the inlet tube using a hose clamp. The mounting for the shroud of the racer should be the same as the Trueflow. The contours of the shroud of both should match right up to the contours of the inner fender.
Originally Posted by Arsenal
im gayer than 2 boys fucking
Old August 6th, 2007, 09:32 AM   #7
2007 Mustang GT
Thanks for chiming in, 06RedfireGT. Yeah, I've seen a video showing the install, too (it came free in one of my 'Stang magazines). I'm confident I'm attempting to put it in the right place in the right way, it's just not sitting in there the way it looks like it should. The "what-goes-where" and "what-connects-to-what" parts are no problem - it's just that once it's in, it's either sitting differently than it seems to sit in the pics/vids I've seen (slanted significantly forward versus level) or the contours of my shroud or car are different because it sure doesn't sit level. I'm hoping someone with this piece in his/her car can either tell me "Yeah, it should sit level, so something's wrong" or "Yeah, you idiot, it's supposed to slant forward."
And any input anyone can give me on my question about the ABS lines (with respect to the instructions saying they should easily move out of the way) would be much appreciated.
Steeda UDP's
C&L Racer CAI
Old August 6th, 2007, 01:54 PM   #8
Red ♥ Zippy
2006 Mustang GT
In the 13's
sorry I couldn't help out more.
Old August 6th, 2007, 02:18 PM   #9
2007 Mustang GT
Hey guys,
I finally got in touch with someone at C&L. They confirmed that the shroud is supposed to sit slanted. It just wasn't how I'd pictured it, but I can see how that works now.
So the only problem now is that it seems that my ABS lines don't want to move like they usually do. The tech at C&L said they usually just pivot/swing out of the way with little effort. It looks like my setup may be a little different for some reason. The lines are actually clamped down in several places, preventing them from swinging. I should be able to figure that out, though. I can either play with the clamps and try to free them up, or I can just cut slots into the shroud.
Thanks again.
Steeda UDP's
C&L Racer CAI
Old August 6th, 2007, 02:20 PM   #10
Red ♥ Zippy
2006 Mustang GT
In the 13's
good that you got everything worked out.
Old August 6th, 2007, 02:20 PM   #11
Shite Mod
2007 Mustang GT
282 rwhp/292 rwtq
Wow, I had no idea the C&L was so finicky to mount. I'm not one to put down another guys purchases, but I'm glad after hearing this I scored the Airaid.
At least the C&L will perform great. I know a bunch of guys here that have them, and they all say they work amazingly well.
My Mods
Old August 6th, 2007, 06:13 PM   #12
2007 Mustang GT
Update:
FYI, I got everything worked out on the install (including the ABS lines). But when I went to load the tunes, I discovered that the vendor loaded the wrong ones (for a JLT CAI, not the C&L, and for the wrong octane ratings). I'm starting to think that this "15-minute install" is never gonna end. I'm not gonna bad-mouth those guys at BamaChips for a simple mistake, though. They've been really nice and great to work with, and I'd recommend them to anyone. I'm just going crazy waiting to hear back on how to proceed with the process of getting new tunes.
Steeda UDP's
C&L Racer CAI
Old August 6th, 2007, 06:23 PM   #13
Red ♥ Zippy
2006 Mustang GT
In the 13's
too bad you have to go through all this hassle, but when its done you're gonna love it.
Old August 7th, 2007, 06:46 PM   #14
Look Ma! My First Post!
bigolgeek's Avatar
I just installed the C&L and let me tell you that I really thought I was going to be getting a quality intake. I have never seen a bigger piece of garbage in my life. Invest in oh maybe 15 minutes of R&D into a better shroud C&L
Ziptie the shroud to the ABS lines
C&L gets my :award for quality!
Old August 7th, 2007, 06:51 PM   #15
Modern_Muscle's Avatar
doug will just email you new ones, i had a light come on from mine, and he corrected in within 3 days...
2005 GT, Bolt-Ons, into a 40mph headwind, 13.0 @ 105.5...UGH
1993 XJ 4x4 4.0 M5 214k mile hoss!
2006 F150 Crew Cab...Work Truck
Old August 7th, 2007, 06:59 PM   #16
Geezer's Avatar
The way you have it positioned in the first picture is correct.
You must return to stock air intake until your tunes arrive though. They should go in at the same time.
20" Niche GT w/Falken FK452
10" Stripes 1/2" Pins & Custom Rocker St
3D Carbon Tonneau Cover
Steeda UL lwr springs
St UD Pullies
St Strut T Br
St G-Trac Br
Tokico D-Spec S & S
C&L CAI
X-Cal2 w/ 92 Bama Tunes
Old August 7th, 2007, 07:09 PM   #17
2007 Mustang GT
I got the new tunes from BamaChips and loaded them up yesterday, but then I discovered that the problem wasn't that my tuner had the wrong tunes on it but that they sent me the wrong tuner (for some guy named David). So, since the calibration was set for a different car, the car wouldn't crank. I've re-installed the stock tune and stock airbox for now and am waiting for Doug at BamaChips to get in touch. I have a tank full of 93 octane, though. Does anyone know if I'll be okay driving it around on that with the stock tune?
Steeda UDP's
C&L Racer CAI
Old August 7th, 2007, 07:51 PM   #18
Geezer's Avatar
You are absolutely fine driving 93 octane.
St UD Pullies
St Strut T Br
St G-Trac Br
Tokico D-Spec S & S
C&L CAI
Old August 7th, 2007, 07:55 PM   #19
acehogg69's Avatar
06 GT with bolt ons
I sucked
SLT-2 FTW! IMO
Kyle Busch Haters Club!! Member Uno!
Tony wrote "Blowers blow, turbos suck, and nitrous rules!!! lol "
Borla cattless L/T's topped with Flowmasters , Roush short throw, JLT2 CAI w/ X-CAL2 from Brenspeed, Bullit 18X9 and 18X10 deep dish.
Old August 7th, 2007, 08:19 PM   #20
RyanHNT's Avatar
2007 Mustang GT
Thats an odd looking fit? My airade CAI fit like a glove. It had two knobs in the bottom that fit inside the holes in the fender well to keep air flowing around it and to reduce any vibration then it bolted to the old air box hole and to the ABS forward bolt, no freaking zip ties?? Thats kind of cheese.
2007 Mustang GT , mod. #1. Airaid CAI. #2, Strange Deveopment, Ext. clearence strut tower brace,#3 Diablo Sport Predator.
Threads Similar to: C&L CAI Installation - Filter Shroud - Question
Fender well cold air intake filter installation???? GHEDEUP 94-95 3 October 13th, 2007 12:45 PM
Fender well cold air intake filter installation???? GHEDEUP 5.0 Mustangs 8 October 12th, 2007 01:03 AM
JLT CAI installation question??? 02StangGToWNEr 99-04 21 September 7th, 2007 11:01 PM
PI Cam Installation Question uscroberts 96-98 1 April 11th, 2007 09:03 AM
installation question skatebaker 96-98 5 November 29th, 2006 07:35 PM
