Discussing engine cleaning in the 2005+ Forum. looking for something the i can clean my engine up with...like a spray or ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
engine cleaning
looking for something the i can clean my engine up with...like a spray or something
thanks |
#2 | |
Red ♥ Zippy
2006 Mustang GT
In the 13's
good question. I've been wondering this too.
91 Sonic Blue Goodness
19.83 @ 12mph
basic engine degreaser works.
as far as detailing it... avoid anything with petroleum solvents or silicone oils. |
#4 | |
Shite Mod
2007 Mustang GT
282 rwhp/292 rwtq
Location: Beside a bubble. Wife calls it a 'clown tent'. Somewhere up north, eh.
Make sure you cover the PCM & do not soak the coil packs. Cover them with plastic & tape the plastic up. Also try and avoid soaking the alternator. Our alternators are sensitive bitches. Like me.
![]() Dyno Pull/MBRP's - The pee Test My Mods
#5 | |
Red ♥ Zippy
2006 Mustang GT
In the 13's
for degreaser, something like Simple green I thinks its called. and like armor all for detailing.
and cover up the fuse box and PCM. I've also heard of using like one of those bug sprayers that you pump up. do you reccomend any particular brands?
19.83 @ 12mph
I like meguries personally.
#7 | ||
Red ♥ Zippy
2006 Mustang GT
In the 13's
#8 | |
Shite Mod
2007 Mustang GT
282 rwhp/292 rwtq
Once I get mine clean, I then try and keep it clean using Meguiars detailing spray on the fenderwells & firewall & other exposed painted surfaces. Then I use Armor All Gel on a rag to shine up the.....things that can be made shiny. Don't lay it on thick, it will attract dust like a mofo. Just squirt a bit on a rag and spread it around.
2006 GT
11.99@114
simple green, wet and dry rags, and elbow grease.
F-150 FX4
On my old Mach, I would cover the intake, battery, and fuse boxes.
Spray greased lightning on everything and let that sit for a while, then gently hose everything down. Then I would crank up the leaf blower and blow dry it :wink DONT CLEAN A HOT ENGINE! |
#11 | |
2021 Mustang V12
Quad Turbo with nawz
Location: modified88dreamer likes penis in and around his mouth
http://kalecoauto.com/index.php?main...products_id=32
GTConcept05: i'm dying of cancer here,, please jack me off for me ^^ ![]() slow car club - crew member 1 of 9 join www.moddedautos.com i had my bowl of WIN for breakfast. did you? |
#12 | ||
2005 Mustang GT
~SLP Loudmouths~K&N CAI~BAMA Tuned SCT X-Cal 2~Hurst Shifter~ ~Cervini's Side Scoops~Roush Quarter Louvers~GTS Brake Light Covers~ ~MRT Hood Scoop~Tinted Turn Signals~FRPP Hood Pins~ Hurst Crew Member #14 |
#16 | |
Red ♥ Zippy
2006 Mustang GT
In the 13's
I think those STS turbo systems are way to complicated, with all the pipes runing back aand forth under the car. I like the second one better.
I'd take the second on too, unless they realese there TT kit and isn't as complicated as the STS one.
F-150 FX4
STS turbo systems are crap, a mutang tuner here in town hates to even install them. And to add to it, they perform worse than they look!
i wonder if kaleco sells blinker fluid or muffler bearings. i seem to be running low on some. The bsi light keeps flashing.
"Are you sure thats as big as it gets? I thought you said it was big?" 2007 GT K&N CAI, Hurst Short throw, who needs mufflers? hood scoop, hood, and spoiler painted flat black. Hurst Crew Member #12 |
06 GT & 98 GT
I've never hosed down any of my engines. I get in all the grooves and crevices by hand.
![]() 98 GT: Accufab, Steeda, BBk, Mac, FlowMaster, Moser, Ford Racing, American Racing, Nitto DR's, Eibach, SCT, FPS 06 GT: JLT, SCT, FRPP/Borla, Pypes, Steeda, BamaChips, BMR RadMustangs Store |
Threads Similar to: engine cleaning
| Engine Cleaning? | Snipe061 | Visual | 14 | September 22nd, 2007 01:04 PM |
| Engine Cleaning | tnknepp | Classic Mustangs | 4 | July 23rd, 2007 07:48 PM |
| engine cleaning.. and other things | 3.8Coastie | V6 Mustangs | 13 | June 25th, 2007 09:25 PM |
| Cleaning engine | MustanG_guy17 | Engine | 14 | April 20th, 2007 10:22 PM |
| Cleaning Engine | themav46 | V6 Mustangs | 15 | October 9th, 2006 08:23 AM |
