Go Back   Forums at Modded Mustangs > Mustang Forums > Modular Mustangs > 2005+
Discussing Crankshaft torque specs anyone?? in the 2005+ Forum. I'm installing my udp's and wondering what I should torque the crankshaft bolt ...
Old August 21st, 2007, 10:33 AM   #1
stanglifemike's Avatar
06 GT & 98 GT
I'm installing my udp's and wondering what I should torque the crankshaft bolt to. And exactly where is the keyway?? I've got high temp silicone for it, just making sure that I'm putting in the right area. Also, instructions dont say but I've heard that I should be using Loctite on the bolts too. Thanks in advance. I'll check back periodically throughout the install. Any other advice or tips would be greatly appreciated.
98 GT: Accufab, Steeda, BBk, Mac, FlowMaster, Moser, Ford Racing, American Racing, Nitto DR's, Eibach, SCT, FPS
06 GT: JLT, SCT, FRPP/Borla, Pypes, Steeda, BamaChips, BMR
RadMustangs Store
Old August 21st, 2007, 12:52 PM   #2
05mustang_kb_charged's Avatar
2005 Mustang GT
Dyno Racer
the torque is 75 foot lbs if i remember right, if you use loc tite use the blue not the red, and the key way should be on the crank, they should have a 1/4" gap cut in crank for the key to fit into, i'm not sure these cars have one i never removed my balancer
A Couple Bolt-Ons and GOOD Air
613 rwhp and 534 rwtq on 15 psi. and 17 degrees of timing
F/I Crew Member #1
KENNE BELL Crew Member #1
Old August 21st, 2007, 01:38 PM   #3
06 GT & 98 GT
Thanks KB, I had just gotten the specs from Steeda, its actually a 4 step process. And there is a keyway on these 3v's. Just about to put the new pulleys on.
RadMustangs Store
Old August 21st, 2007, 03:43 PM   #4
Shite Mod
TheUNZippee!'s Avatar
2007 Mustang GT
282 rwhp/292 rwtq
Location: Beside a bubble. Wife calls it a 'clown tent'. Somewhere up north, eh.
Dyno Pull/MBRP's - The pee Test
My Mods
Originally Posted by goober
i couldn't find a midget on a bike. well i couldn't find a naked midget on a bike
Old August 21st, 2007, 05:47 PM   #5
06 GT & 98 GT
So it is, so it is. I'll have to do something about that then.
RadMustangs Store
Old August 21st, 2007, 05:51 PM   #6
Shite Mod
2007 Mustang GT
282 rwhp/292 rwtq
My Mods
Old August 21st, 2007, 05:55 PM   #7
06 GT & 98 GT
Per Zip's request.
Here is before
RadMustangs Store
Old August 21st, 2007, 05:56 PM   #8
06 GT & 98 GT
During
RadMustangs Store
Old August 21st, 2007, 05:58 PM   #9
06 GT & 98 GT
Finished
RadMustangs Store
Old August 21st, 2007, 05:59 PM   #10
06 GT & 98 GT
Hey actually now that I look, the pic where the intake is on, was before the install. Woops
RadMustangs Store
Old August 21st, 2007, 07:05 PM   #11
Shite Mod
2007 Mustang GT
282 rwhp/292 rwtq
Good stuff Mike. Thanks
Difficult install? And have you driven it yet.
My Mods
Old August 21st, 2007, 08:09 PM   #12
Red ♥ Zippy
06RedfireGT's Avatar
2006 Mustang GT
In the 13's
very nice
Originally Posted by Arsenal
im gayer than 2 boys fucking
Old August 22nd, 2007, 12:42 PM   #13
06 GT & 98 GT
Install was actually pretty simple. You need a 3-jaw puller, which I rented from a parts store. Impact gun makes the water pump pulley a breeze. You'll need a breaker bar for the crank bolt, I used a 24" bar and it came off easy. Loosen the bolts in your idler, then take a pry bar to relieve some tension off the belt. The hardest part is getting the 3-jaw on the pulley so that you can remove it. Other than that it was pretty self-explanatory. They say you need to jack your front end up, but I only got under the car once, and found that everything was simpler from above.
RadMustangs Store
Old August 22nd, 2007, 12:47 PM   #14
06 GT & 98 GT
Oh and I did drive it last night. Nice!! I could definatley tell a difference. It feels like it has a little more pep all through the rpm's. Mainly picked up around 2500. It least thats how it feels. I havent seen a dyno graph of before and after on a car, but thats my guess. You need to do it Zip, I believe you get slightly better gas milage too, if I remember correctly. I think my 98 got a little better but that was years ago when I had them put in.
RadMustangs Store
Old August 22nd, 2007, 12:54 PM   #15
Shite Mod
2007 Mustang GT
282 rwhp/292 rwtq
Thanks for the great write-up & pics Mike
The one and only reason I haven't put UDP's on mine yet is because of my stereo system. It will pull 160 amps at roughly 2/3 volume, and my installer told me he would fistfight me if I put them on. lol
I'm not averse to a good ole' fistfight, but this dude is 6'4" & 250lbs, and it just takes me so much longer to heal now at my advanced age. lol
My Mods
Old August 22nd, 2007, 12:56 PM   #16
06 GT & 98 GT
Gotcha, well ya know I just realized with the install that you dont change your alternator pulley, like on the 2v's. It's just water pump and crank. So it may not affect it
RadMustangs Store
Old August 22nd, 2007, 12:59 PM   #17
Shite Mod
2007 Mustang GT
282 rwhp/292 rwtq
Really? Interesting. Would be more interesting to verify that. *ponder*
Hmmm...well...if you change the crank one, that would in turn be affecting all accessories turned off of that pulley.
My Mods
Old August 22nd, 2007, 01:04 PM   #18
06 GT & 98 GT
Well the crank pulley is smaller, allowing it to spin faster. The water pump is larger, slowing it down. Everything is will spin the same though.
RadMustangs Store
Old August 22nd, 2007, 01:11 PM   #19
Shite Mod
2007 Mustang GT
282 rwhp/292 rwtq
Far out.
My Mods
Threads Similar to: Crankshaft torque specs anyone??
3.8 Torque Specs Twist 2 Go V6 Mustangs 10 April 24th, 2008 10:52 PM
Torque specs 96GTRagTop 5.0 Mustangs 13 August 11th, 2007 11:47 PM
4.6 Torque Specs Twist 2 Go Modular Mustangs 27 June 25th, 2007 07:12 PM
crankshaft specs acmillr 99-04 3 June 24th, 2007 10:57 PM
5.0 Torque Specs Twist 2 Go 5.0 Mustangs 1 May 16th, 2006 12:52 AM
