Go Back   Forums at Modded Mustangs > Mustang Forums > Modular Mustangs > 2005+
Discussing Spring question? in the 2005+ Forum. Just got finished installing my rear eibach springs and when I lowered it down and ...
Old September 1st, 2007, 12:10 AM   #1
JAY'SRED02's Avatar
2006 mustang gt
Spring question?
Just got finished installing my rear eibach springs and when I lowered it down and stuck the tape to it the passenger side is almost 1/4'' lower than the drivers side. What could cause this? Will it settle in place after I drive it? I still have to adjust the panhard bar and put the front springs on in the morning. Anybody had any issues like this?
Old September 1st, 2007, 12:29 AM   #2
Red ♥ Zippy
06RedfireGT's Avatar
2006 Mustang GT
In the 13's
not sure but did you not adjust the bump stops or something
Originally Posted by Arsenal
im gayer than 2 boys fucking
Old September 1st, 2007, 12:35 AM   #3
Luis_GT's Avatar
I don't think the bumo stops has anything to do with one side lower then the other, could be that the spring is not correctly placed on one side.
Eagle Scouts or GTFO!
Originally Posted by ChrisJ View Post
yes I agree 100% with MSO...
Originally Posted by DeMello View Post
new clutch, i cant drive, too much power for me to handle, shifter problem since i installed it myslef
Old September 1st, 2007, 12:51 AM   #4
Red ♥ Zippy
2006 Mustang GT
In the 13's
maybe but he could have trimmed one and not the other
Old September 1st, 2007, 12:56 AM   #5
Luis_GT's Avatar
yeah, but thats a little rubber piece that limits the car's bottoming out, not how low the car will drop. The little ruber piece is like 1" tall, you have to drop the car like 3 or 4 inches for the bump stop to limit how much the car is dropped.
Old September 1st, 2007, 12:59 AM   #6
JAY'SRED02's Avatar
2006 mustang gt
After reading an old 5.0 article on installing the eibachs it said not to tighten the shocks up until car was on the ground that tightening while lifted could cause bushing preload and a slightly higher ride height. That may be where I screwed up.
Old September 1st, 2007, 01:11 AM   #7
Luis_GT's Avatar
Thats prolly it. post up if you fix it.
Old September 1st, 2007, 01:25 AM   #8
JAY'SRED02's Avatar
2006 mustang gt
Yeah I'll let you know tomorrow maybe even post some pics of the new stance if I can figure out how to re-size the images.
Old September 1st, 2007, 01:39 AM   #9
Luis_GT's Avatar
Use photobucket, you can select the size you want and it'll upload it @ like 800x600, 1024x768 or whatever.
Old September 1st, 2007, 02:23 PM   #10
2006 GT
11.99@114
First thing I would do is check the psi in each tire. Then I would take the car to a location where I know the surface to be flat. Usually a concrete slab is a good indicator of a level surface. Like at a gas station or at one of these oil change places that have pits. I would think that would be very level.
Aint gonna happin.
http://i3.photobucket.com/albums/y51...hn/front-1.jpg
Threads Similar to: Spring question?
Best spring set for a DD? TIM350 94-95 0 August 18th, 2007 11:04 PM
strut, shock, and spring question buddie Suspension 1 August 9th, 2007 06:54 AM
Spring kit lwhitetrash88l V6 Mustangs 12 April 24th, 2007 10:44 PM
spring question - need help fallstar01 Suspension 2 July 6th, 2006 02:05 PM
spring question reeds98gt 96-98 1 July 4th, 2006 11:17 PM
