Go Back   Forums at Modded Mustangs > Mustang Forums > Modular Mustangs > 2005+
Discussing Oil Pressure Gauge Question in the 2005+ Forum. I'm new to this so please don't shoot the messanger if this has ...
Old September 5th, 2007, 01:08 PM   #1
I'm new to this so please don't shoot the messanger if this has been gone over before. I just put an a-pillar pod gauge setup in my car and I'm trying to put in an Oil Pressure Gauge.
My question is, I've got a Roush Stage 3 that is supercharged and I'm trying to find where to install the sender unit.
Also, I want to power the lights on it off of my dash lights so the lights come on when the dash lights come on. Does anyone know what line I need to hook into for that to happen?
Any help would be appreciated.
www.mustangministries.net
Old September 5th, 2007, 02:36 PM   #2
1FastFox's Avatar
Im not really sure about where to tap the guage into. But I run my guages off the dimmer switch that way not only do they light up but also dim with the interior. I put an inline fuse on my ( prolly overkill, but safe ) line b/w the guages and dimmer switch.
Aston DB9, 91 GT Hatch, 06 EB Explorer
Aston Crew Member #1 ( of 1 )
Old September 5th, 2007, 02:49 PM   #3
Emay's Avatar
2007 Mustang GT
Fast did similar to myself in going after the dimmer, if you have a test light it's a easy find. I forget what color the wire was, I remember green for some reason, but I'm guessing at this point.
For the sender, see this thread.. tells you exactly where to go with pics:
http://www.modularfords.com/forums/f...ace-55363.html
View and purchase my pics:
http://erinmayphotography.exposuremanager.com/g/
Old September 5th, 2007, 03:08 PM   #4
1FastFox's Avatar
Its funny that your mention green, caus that was what I was thinking just didnt want to say it without being sure ( which Im still not ), just probe a test light into the back of the switch and see which one lights up, also your test light will dim as you turn the switch.
Old September 5th, 2007, 03:20 PM   #5
Thanks guys! I'll have to check and see if there is a green there. I know that the green in the ignition wiring is the one I had to splice into for my push button start. I'll take it apart tonight after church and check it out.
Did you run ground to a screw or attach it into the dimmer switch wiring some way?
Old September 5th, 2007, 03:28 PM   #6
1FastFox's Avatar
I make a new ground for it...
Old September 6th, 2007, 12:25 AM   #7
Grabber523's Avatar
2007 Mustang GT
Location: Northwood, ND...yes, hell does freeze over...
Grounded all my gauges to the dash behind the dimmer...I think the wire i used for dimming the gauge lights was black with either a green or purple stripe...the car's 7,300 miles away, so i can't go check...sorry
myspace.com/grabber523
2007 Grabber Orange GT Premium 5-Speed, CDC Sequential Taillights, 2.6L Kenne Bell, 3.73 FRPP Gears, Steeda Tri-Ax, Dynotech Alum. D/S, BMR D/S Loop
Threads Similar to: Oil Pressure Gauge Question
fuel pressure gauge dr.gonzo 5.0 Mustangs 7 March 15th, 2008 11:22 PM
Fuel pressure Gauge question. DrHolliday 99-04 5 June 2nd, 2007 02:46 PM
Electric Fuel Pressure Gauge question hawks05 99-04 3 March 10th, 2007 05:57 PM
Problems With Oil Pressure Gauge... Need Help! chase 5.0 Mustangs 4 February 9th, 2007 06:25 PM
Fuel Pressure gauge sensor Gosh 99-04 0 August 22nd, 2006 11:02 AM
