Discussing control arms in the 2005+ Forum. what kind of suspension set up do I need to help me off the line (... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
2005 Mustang GT
12.002@114.82
control armswhat brand is the top of the line? isn't there something you can take off of the front suspension an anti roll bar...that will reduce weight and help 1/4 mile times? how will that effect daily driving? |
06 GT & 98 GT
Yes, removing the front sway bar will help you on the dragstrip. As far as other suspension, check out BMR and Steeda.
![]() 98 GT: Accufab, Steeda, BBk, Mac, FlowMaster, Moser, Ford Racing, American Racing, Nitto DR's, Eibach, SCT, FPS 06 GT: JLT, SCT, FRPP/Borla, Pypes, Steeda, BamaChips, Deez Nutz RadMustangs Store |
12.3 @ 115
i recommend BMR
and to help ya down the 1/4 strip, get yourself a pair of lower control arms and an upper control arm, will eliminate your wheel hop and help you hook up better..... |
2007 Mustang GT
11.55 @ 118.89
BMR makes a drag racing pack that is very complete, i'm installing it on my car next week. Heres a link to it.
http://www.lethalperformance.com/pag...r-package.html They also have a level 2 for really agressive cars.
GT 5sp Grabber OrangeFor mods check my garage. 345 rwhp, 327 rwtrq Naturally Aspirated 430 rwhp, 465 rwtrq 100 Shot 60ft: 1.6849 1/4: 12.43 @ 109.67 N/A 60ft: 1.61 11.55 @ 118.89 100 shot Nitrous |
I have BMR lowers with the relocation brackets. I haven't installed the upper yet but will do that when I get the new driveshaft next year. I also removed the front sway bar, not to remove weight but to promote better weight transfer to the rear wheels since it allows the front to move up a little more.. It leans a little more around tight turns now but it isn't bad. There is a radiator support that is available if you want to run without a sway bar. This is probably what you are thinking of for front end weight savings.
The sway bar delete you're referring to, I believe is from BMR. It's not cheap as it is a K member combo piece but will save you weight as well. Just don't use it for anything other than dragging according to them.
Ford Racing heads, Comp stage III cams, 4.10's, Steeda delete plates, SLP long tube headers, Custom 3'' X pipe, Magna flow 3" Magnapacks, Airaid CAI, SCT XCAL 2 93 tune, Steeda front and rear swaybars, Dynotech aluminum driveshaft, HTP TB spacer |
Threads Similar to: control arms
| QA1 Tubular Control Arms (A-Arms) | keith0s | 5.0 Mustangs | 3 | October 19th, 2007 11:20 AM |
| steel control arms vs aluminum control arms | Saleenwolf720 | 99-04 | 1 | October 15th, 2007 01:32 PM |
| Upper Control Arms & Lower Control Arms | LUV2XLR8 | 2005+ | 6 | October 6th, 2007 11:45 AM |
| Steeda lower control arms (Trailing arms)? | kmjsmith | 2005+ | 6 | July 4th, 2007 04:59 PM |
| Control Arms | MnrlGry01gt | Suspension | 17 | August 16th, 2006 09:53 AM |
