Discussing Upper Control Arms & Lower Control Arms in the 2005+ Forum. Hi boyz, Please advise which UCA & LCA i should go for. No adjustables needed. ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
Hi boyz,
Please advise which UCA & LCA i should go for. No adjustables needed. I was thinking A) BMR Tubular Lower Control Arms w/poly bushings... $134.95 pr. Or B) BMR Tubular Lower Control Arms with polyurethane bushing and spherical bearing combination ... $208.95 pr. and A) BMR UCA Tubular Upper Control Arm w/poly bushing... $135.95 or B) BMR Tubular Upper Control Arm w/spherical bearing $175.95 What does poly mean? is it the same as polyurethane? whats a spherical bearing ? is it really important? Any other considerations added too would help? Appreciate the help. Thanks
JLT CAI (BamaTuned), UDP, Delete plates, MagnaFlow, Saleen Suspension System, BMR LCA & UCA, Upper Strut Mounts, MGW Shifter, Shorty Antenna, Pony Mats, Tint Protector. * Comming Soon: 4.10 Gears, Clutch, Flywheel & Brembo Brakes. |
bump i wanna know the same thing
2005 Mustang GT ![]() -STS single turbo kit 478whp/465wtq @10psi -Fidanza 4.3 clutch Should i use my race gas tune i have?? ![]() http://i104.photobucket.com/albums/m...er7/stang3.jpg |
http://www.miracerros.com/mustang/t_suspension.htm#Rear
"If improved straight-line (dragstrip) performance is your primary goal, the stock rubber upper & lower control arm bushings can be replaced with solid polyurethane bushings or spherical bearings. Hard bushings/bearings eliminate wheel hop, reduce axle deflection, and improve rear end grip. The downside of solid poly bushings is that they prevent the necessary movement of control arms during body roll, which in turn produces significant suspension bind in turns. Spherical bearings do a better (but still imperfect) job of handling control arm motion during turns. And they also tend to transmit a lot of road noise and vibration into the car. If you use your car in open track or autocross competition, you'll probably want to leave the stock upper control arms alone and install only new lower control arms. The stock rubber bushings in the upper arms continue to allow the axle to articulate through its full range of motion in turns, while the new lower arms improve axle location. One popular lower arm design (illustrated below) uses segmented poly bushings on the chassis end and spherical bearings on the axle end. This combination has been found to improve rear axle location without any significant increase in suspension bind."
![]() On board: Livewire, 4.10's, Eibach Pro kit, J&M LCAs, Steeda adjustable panhard bar, FlowMaster American Thunders. Wish list: Watts link, T56 (high ratio), Aluminum DS and Flywheel, Centri blower, Mac Mini with 7" screen. |
how much power are you putting out?
is you car a daily driver? what all do you use your car for? daily drivers will want poly bushings, it is a better ride that rod ends or sphericals. just a weekend warrior, or a drag car will want rod ends, or sphericals. puts power to the ground better, and has a harsh ride. I personally have the CHE LCA's with poly bushings, or whatever theirs is equivalent to. Love it, a lil rougher ride than stock, but not too bad. buddy has the rod ends for his turbo 06, and its a rougher ride with more road noise too. if you are 400+rwhp think about rod ends, but polys will still hold itj ust fine. poly is polyurethane. sherical uses a bearing inside of the poly bushing for more articulation I believe. =(o)= like that
1998 Trans Am WS6. (Anti Venom) Forged 347, stage 3 T56, and a 76mm Turbo... 659rwhp @ 13.5# ~725rwhp @ 15.5# Meth, C16, and 20psi coming soon 03 Z71 (H/C/I/E/T)...sold 2005 GT, Full Bolt-Ons...12's... GONE |
07 GT/86 LX 5.0
12.86@104
the spherical bearings will be harsher than the poly bushings. they are more for racing than just a street car. if you are going to lower the car then i would suggest getting the adjustable ones though. i use bmr and i love them. very simple to install everything.
![]() I just wanna go fast and I finally got to install my parts.....H&C ftw |
Havent been on here much lately but will have to put more effort into it.
Thanks peeps. Great Info! Looking for a daily drive, havent dyno'd her yet so not sure how much HP im runnin, Got a coupla basic mods ill mention in my sig...Mod List is still quiet large Decided to go with Tubular Lower Control Arms w/poly bushings, and Adjustbale upper Control Arms and Adjustable Upper Control Arm w/poly bushing. Cheers
#7 | ||||
Like a Boss...
2006 Mustang GT
In the 13's
Youprobably have about 280 rwhp
![]() Liberals are like cheese, they are full of holes, and stink. They lack the moral fiber to function as most of us do. When the world turns to chaos because of their actions, we will simply know them as food for the rest of us. JAKE'S PIITB CREW MEMBER#4
Threads Similar to: Upper Control Arms & Lower Control Arms
| For those with Upper/Lower Control Arms... | the real shocker | 99-04 | 26 | September 19th, 2007 06:49 AM |
| upper and lower control arms | kreil45 | For Sale | 3 | June 11th, 2007 10:01 AM |
| bbk upper and lower control arms | sonicblue | For Sale | 8 | March 28th, 2007 07:20 PM |
| Upper And Lower Control Arms | Tony_90fox | 5.0 Mustangs | 18 | February 27th, 2007 01:57 PM |
| bbk upper and lower control arms | sonicblue | For Sale | 2 | January 27th, 2007 09:21 PM |
