Discussing Total Fluid Change in the 2005+ Forum. Just like the title says I want to change all my fluids to Royal Purple. ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
2007 Ford Mustang GT
13.253 @ 106.96mph
Total Fluid Change
Just like the title says I want to change all my fluids to Royal Purple. Sorry about all the questions. New to the car and only want the best. Correct me if I'm wrong on some of the fluids and amount needed. Would it be worth to change everything to RP, if not what are the next top of the line products that have been in the trial and error process.
1. Motor Oil- 5w20, 6qts 2. Transmission- 75W90 or 75W140, 3qts 3. Differential- 75W90, ??? 4. Power Steering- Max EZ, ??? |
#2 | ||||
Like a Boss...
2006 Mustang GT
In the 13's
Check
For the trans its 3.2 quarts for a stick and 11.9 for an auto. The manual doesnt say what weight. Rear end is 75W-140 4.25 pints And the power steering fluid wouldn't make a difference, just leave it. I use Mobile 1 myself, but RP is also very good.
![]() Liberals are like cheese, they are full of holes, and stink. They lack the moral fiber to function as most of us do. When the world turns to chaos because of their actions, we will simply know them as food for the rest of us. JAKE'S PIITB CREW MEMBER#4
2006 Redfire Mustang GT
Royal purple is a good choice for synthetic fluids as would amsoil ... even mobil 1 full synthetic seems to be a decent synthetic oil for your crankcase. I'd definately go full synthetic with your oil, trans, and power steering but I think you already have full synthetic in the rear end if I'm not mistaken. Depending on how hard you intend to drive your stang ... it should be fine with the factory fluid there. IMHO
I changed mine @ 1300 km for amsoil full synthetic 5w 20 in the crankcase and will be changing the manual trans to full synthetic as well. (Std Trans Uses Synthetic ATF fluid - same as the automatic) (For some odd reason Ford filled all Canadian bound mustangs with dino oil, and the US mustangs recieved synthetic blend. I was more than happy to change out the black tar, for some golden honey, once it was broken in) Dollar for dollar a wise investment for your baby! |
#4 | ||||
Like a Boss...
2006 Mustang GT
In the 13's
good choice in colors :wink
#5 | |
#6 | ||||
Like a Boss...
2006 Mustang GT
In the 13's
#7 | |
13.253 @ 106.96mph
It'll be pretty cheap for me because I can get it on base and its all tax free. So 3.2qts (5spd) tranny, Rear end is 4.25qts
Mods in garage Hurst Crew Member #13 Military Crew E-5
since when does the NEX "exchange" store sell gear oil?
13.253 @ 106.96mph
Not sure when but our auto shop/ gas station sells the entire line of RP. From motor oil, tranny, power steering, radiator additive, rear end. Then again I'm in the Air Force and I'm guessing by NEX your in the Navy.
not any more but I used to be.
13.253 @ 106.96mph
There shouldn't be a problem if I added RP power steering fluid to bring it up to the Max line
Threads Similar to: Total Fluid Change
| HOW MANY GT/CS are to be made total? | Hellrazor62201 | 2005+ | 24 | October 29th, 2007 08:46 PM |
| tranny fluid and oil change | JASonic | V6 Mustangs | 8 | October 16th, 2007 12:05 AM |
| Tranny Fluid change?? | gt_andy | 99-04 | 4 | October 13th, 2007 02:04 PM |
| Manual transmission fluid change | Saleen0101 | 99-04 | 24 | September 25th, 2007 11:27 AM |
| How much for total alignment? | nba1341 | Classic Mustangs | 14 | July 30th, 2007 07:03 AM |
