Discussing Adjustable Front Lower Control Arm, GT500 Brakes & Wheel Spacers in the 2005+ Forum. Here's what I want to do. I would like to install the GT500 Brembo ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
Here's what I want to do. I would like to install the GT500 Brembo calipers that I have sitting in my basement.
However, to fit them properly with my stock 18" Bullitt rims, I would need a full 1" spacer. The problem is that I can't use a spacer that large because of the 3" drop that I currently have with my Eibach Pro Stree-S coilovers. A spacer that large would locate the tire less that 1/8" from the fender lip. Mind you, the overall tire heigh is actually taller than the height of the fender, so the top of the tire actually sites higher than the opening of the fender. Trying to conjure up a solution, it occurred to me that if they made a shorter front lower control arm, that it would move the entire wheel assembly inboard, and potentialy allow me to install a 1" wheel spacer. Surely enought, BMR makes an adjustable front lower control arm. I already have Maximum Motorsports camber/caster plates. The coilovers also have an oversized upper strut mount hole that permits a wide range of caster adjustment. I also have Steeda's bump steer kit to correct extreme toe angle. Would BMRs adjustable front lower control arm solve my problem? Please respect that I do not have any intention of altering the ride height or swapping out the rims. So that is not a solution.
Bump for ya!
Threads Similar to: Adjustable Front Lower Control Arm, GT500 Brakes & Wheel Spacers
| Wheel Spacers | RC02GT | Wheels/Tires | 9 | December 30th, 2007 07:49 PM |
| Lakewood Adjustable Upper Control Arms Mustang 79-04 | Sable | For Sale | 1 | November 13th, 2007 01:56 AM |
| Adjustable Upper and Lower Control Arms | MustangMatt96GT | 96-98 | 4 | April 8th, 2007 01:23 PM |
| wheel spacers | 97_4.6L_Stang | 96-98 | 6 | February 15th, 2007 05:07 AM |
| wheel spacers | via sin dios | V6 Mustangs | 3 | December 31st, 2006 01:37 PM |
