Go Back   Forums at Modded Mustangs > Mustang Forums > Modular Mustangs > 2005+
Discussing Wiring Help in the 2005+ Forum. hey gang I am new here so be gentle...I have an 06 GT and ...
Old August 31st, 2006, 12:10 AM   #1
Look Ma! My First Post!
Wiring Help
hey gang I am new here so be gentle...I have an 06 GT and I am tryin to figure out how to remove the door panel so I can wire in some LED's...can any one point me in the right direction (and the door doesnt count :-p )
ram
Old August 31st, 2006, 05:06 AM   #2
psycho bob's Avatar
07 MUSTANG GT
12.86@104
well can't say i have removed one from this car as i won't have mine till december. all the cars i have taken them off though you have to take off all the pieces that are screwed into the door itself (IE: the door latch cover). There are also usually plastic retainers that you pry off, you can use a screw driver for these but i wouldn't advise it on your new car. really i would get the tool made to remove them. like i said though i've never taken off one from this model.
JLT CAI, SCT Tuner, Eibach Pro Kit, D-specs, BMR LCA's, Adj. Panhard bar&support, Tri Axe w/ pistol grip, FRPP X-pipe, SLP loudmouths, Konig Beyond w/ BFG KDW's, MT ET Streets
on order: GT/CS bumper, BMR shaft loops, black grill upper and lower.
Old August 31st, 2006, 08:13 AM   #3
Here are some directions to remove the door panel.
1) Remove the sail panel (on the drivers side you have to disconnect the harness for the mirors)
2) Pry off the cover behind the door release handle, and remove (1) torx T30 screw
3) Pry off the cover behing the door pull handle, and remove (1) torx T30 screw
4) Pry up the power options switch panel, disconnect wiring harness and remove.
5) Remove (8) philips screws from sides and bottom of door panel.
6) Pry off and remove power switch housing. Remove (1) 7mm screw.
7) Lift door panel, disconnect wiring harness and door release cable to remove.
Threads Similar to: Wiring Help
wiring help 95 mustangmiz Electronics 1 June 16th, 2007 12:19 PM
wiring???? 95 mustangmiz Electronics 1 June 16th, 2007 12:01 PM
msd wiring whiteboycustom 5.0 Mustangs 8 February 16th, 2007 09:01 AM
Sub/Amp Wiring? Xeremeh Electronics 0 December 10th, 2006 03:11 PM
WTB: A/C wiring cobralini Want to Buy 2 August 9th, 2006 02:46 PM
