Go Back   Forums at Modded Mustangs > Mustang Forums > Modular Mustangs > 2005+
Discussing Pillar Gauges in the 2005+ Forum. you guys that have them.....where did you splice into for power. I cut into ...
Old December 9th, 2007, 04:06 PM   #1
07 procharger's Avatar
07 Mustang GT 5 Speed
Pillar Gauges
you guys that have them.....where did you splice into for power. I cut into my headlight switch but i have no adjustability. I want to be able to dim them or shut them off.......ideas??
Old December 9th, 2007, 04:26 PM   #2
May 08 ROTM
Emay's Avatar
2007 Mustang GT
You picked the wrong wire on the switch, one of them is dimmer to interior cluster and dash lamps. Believe it's a green wire, use a test light to be sure so your not splicing all of the wires in that lead to the lamp switch..
View and purchase my pics:
http://erinmayphotography.exposuremanager.com/g/
Old December 9th, 2007, 04:30 PM   #3
thanks emay...green you say... is that where yours are?
Old December 9th, 2007, 04:31 PM   #4
now im wondering if the autometer cobalts are dimmable??
Old December 9th, 2007, 10:13 PM   #5
Grabber523's Avatar
2007 Mustang GT
Location: Northwood, ND...yes, hell does freeze over...
Yes the cobalts are dimmable, I wired mine to dim as well, they work great and match the intensity of the dash lights perfectly, no matter how dim they are. DO NOT wire your gauge power wire into the dimmer though...just the gauge lamp wire...
myspace.com/grabber523
2007 Grabber Orange GT Premium 5-Speed, CDC Sequential Taillights, 2.6L Kenne Bell, 3.73 FRPP Gears, Steeda Tri-Ax, Dynotech Alum. D/S, BMR D/S Loop
Old December 9th, 2007, 10:52 PM   #6
MustangJon255's Avatar
2005 Mustang GT
13.032
speaking of gauges...I was looking into a wideband 02 sensor gauge. Any ideas as to where to look for some ok-priced ones?
"Never before has a 13 second car looked so mean and intimidating. Bring it."
Go to
www.fquick.com/americanmuscle255
for all info as well as videos!
Old December 9th, 2007, 11:10 PM   #7
Grabber523's Avatar
2007 Mustang GT
I think autometer makes them now in all their popular styles, such as the Cobalts...wish they'd made them before I bought an AEM wideband that doesn't match. Try americanmuscle.com or lethalperformance.com
Old December 9th, 2007, 11:18 PM   #8
TASSY5's Avatar
2007 Alloy GT
I am putting these in my car in the next few weeks.
Speed of Sound Pillar guages. $119.00
Dynojet Wide band A/F guage with moniter $400 dollars
Autometer Manusl Boost Guage Black Face with silver trim ring. $90.00
And I am putting Blue Bulbs in them and hooking them up to my dash dimmer.
Any opinions about what i am choosing to go with and if I am making any mistakes?
Also is the 2 pod good enough with the 2 guages above mentioned or should i go with the 3 pod and ad another guage(If I need another one)
Thanks
2007 Alloy GT. 5 speed, Spydershaft, MGW shifter, 3.55 gears, Sequential tail lights, C 300 Cervini's Full Body Kit, CDC Hood Struts, Whipple HO.SC. 468 SAE RWHP 450.44 RWTQ
Old December 9th, 2007, 11:26 PM   #9
Grabber523's Avatar
2007 Mustang GT
You want blue gauges? Seriously, go with the Autometer Cobalts...they match our blue dash PERFECTLY...needles and numbers and all...and get the threee-gauge with the blue raptor shift light with boost, wideband A/F and fuel pressure (or EGT if you're N/A)...I absolutely have nothing bad to say about any of autometer and SOS's stuff...
Old December 10th, 2007, 09:40 AM   #10
MMs Official Playboy
1FastFox's Avatar
2006 Aston Martin DB9
The air/fuel guage isnt backlit- FYI...
Aston Crew Member #1 ( of 1 )
I will apologize in advance for those who take offense to my comments, 99.9% of them are made in good fun and shouldnt be taken to heart. Those I have hurt, I apologize ( except Demello as that was intentionally ).
Old December 11th, 2007, 04:10 AM   #11
Grabber523's Avatar
2007 Mustang GT
Nope...but it's real purdy...and blue...anybody wanna buy my AEM wideband so I can get the Cobalt?
Old December 11th, 2007, 05:53 AM   #12
I've got the Speed of Sound a-pillar and the Oil Pressure/Boost Guages from Autometer's Lunar line. I wired them into the power on the headlights and into the dimmer as well. That way my lights control the guages coming on and the dimming works just fine.
www.mustangministries.net
Old December 11th, 2007, 07:55 AM   #13
May 08 ROTM
Emay's Avatar
2007 Mustang GT
I'm not 100% sure it was green, which is why I said "I believe", and backed it with use a test light to be sure.. I put mine in nearly a year ago and without going back in the dash I can't be 100% certain.
Old December 11th, 2007, 07:57 AM   #14
May 08 ROTM
Emay's Avatar
2007 Mustang GT
pastor, I'm not a big fan of the ingiglo look, however I like the signature lighting up in the cluster alot. Is that the roush stage three cluster in it's natural state or did you add a indiglo type overlay?
Old December 11th, 2007, 08:56 PM   #15
crazytaz's Avatar
The best wideband o2 guage to go with is a plx device. i have one and it very good. you don't to calibrate them at all.
Old December 11th, 2007, 08:57 PM   #16
hmmmm i only have three wires for my tach / shift light (cobalt) black green and red. black to groud green to tach adaptor and red to dimmer?
Old December 12th, 2007, 02:37 AM   #17
Grabber523's Avatar
2007 Mustang GT
Probably...your green wire is your signal, but IDK...if the signal from the coil wire is amplified at all by the power from the red wire, you'll have problems...not sure how the black magic inside the tach is wired up, but the rest of the gauges have power (red), ground (black), signal (vaires from purple to grey depending on gauge), and white for backlight control, which goes to your switch/dimmer.
Threads Similar to: Pillar Gauges
Truck Gauges and Pillar itschristorres8 All Other Vehicles 1 November 24th, 2007 08:40 PM
C-Pillar 1 SNAKE 3 V6 Mustangs 12 November 22nd, 2007 12:24 PM
Gauges For A-Pillar Mach Boy 99-04 7 November 11th, 2007 10:11 PM
C-Pillar Scoops SickSixer04 Visual 11 July 29th, 2007 07:06 PM
FS: gauges and a pillar pods matrixpuba For Sale 14 April 28th, 2007 11:58 AM
