Discussing Kenne Bell 2.6 + Stage 3 Comp Cams in the 2005+ Forum. Well guys the day is almost here. I finally made up my mind and gonna ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
2006 Mustang GT
10.82@125.2
Well guys the day is almost here. I finally made up my mind and gonna stick with the KB 2.6. I'm gonna run 12psi. You guys think it'll be a good combo with what i already got?
My mod list is as follows: 323 RWHP 325 Torque 12.89 @ 106.5 Stage 3 Comp Cams w/ springs & retainers TCI 3000 Stall Eaton Posi Diff. 3 73 Gears Aluminum Driveshaft Bassani LT's Bassani O/R X-Pipe Bassani Race Axle Back Shelby GT500 TB MSD Coil Packs Steeda Ultra Lite Springs BMR Lower Control Arms BMR Adjustable Pan Hard Bar
www.RADMustangs.com www.s197Performance.com Bassani Crew Member #2 10 PSI 10.82 @ 125.2 1/4 6.87 @ 98.8 1/8 1.46 60' The 10 Second Daily Driver.... Ask me what I run on street tires! Check it out at myspacecom/havokdacarking
#2 | ||||
Like a Boss...
2006 Mustang GT
In the 13's
I think 12psi will stress the internals and the tans too much. I would say 8-10psi or 450-470rwhp
![]() Liberals are like cheese, they are full of holes, and stink. They lack the moral fiber to function as most of us do. When the world turns to chaos because of their actions, we will simply know them as food for the rest of us. JAKE'S PIITB CREW MEMBER#4
12psi is too much for a stock car, let alone one with all your mods. i say 8 or 9 psi.
![]() Jesus Christ is #1 "The Founder Of Crews"
12.3 @ 115
8psi! 12psi you are kissing your internals goodbye within a month!
If i was you i'd go with the 4 psi supercharger. I'm wanting to say its the Saleen VI series that offers the 4psi s/c. You can buy the pulley kit and increase to like 175 if you build up your block later on down the line. Thats the route i'd go.
The only questionable thing about it is your bottom end of your block. Also, how many miles are on this car?
#7 | |
More Than 7, Less Than 8
2007 Mustang GT
282 rwhp/292 rwtq
Consider 10 psi the absolute max for a stock bottom end. Over that, and you're playing with fire.
![]() JAKE'S PIITB CREW MEMBER#1 LACEY'S TIOTB CREW #1 BLACK STANG CREW #2
Its not just the psi u gotta watch out for, its how much you've done to the top of your block compared to the bottom. All kinds of bad thigns can happen if you put new heads n cams, or a S/C on a motor that has a little wear. Burning oil is very common.
Threads Similar to: Kenne Bell 2.6 + Stage 3 Comp Cams
| Cams For Kenne Bell S/C | motorhead6776 | Modular Mustangs | 5 | December 10th, 2007 06:51 PM |
| Kenne Bell | Emay | Power Adders | 16 | October 16th, 2007 12:52 PM |
| FS: Comp stage 1 cams. 262s | Invictus | For Sale | 4 | April 28th, 2007 12:56 PM |
| kenne bell | punkafi888 | Power Adders | 43 | April 4th, 2007 04:52 PM |
| Comp stage 1 cams. 262s | Invictus | Modular Mustangs | 0 | December 7th, 2006 12:34 AM |
