Discussing Under Drive Pulleys in the 2005+ Forum. Done. Was an easy job really and I have not worked on a car other ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
Authorized Vendor
Under Drive PulleysI hope i torked that bolt on right. spilled some antifreeze and that was steaming of after i drove it. but it was dark by then. I hope it isnt leaking something. Thanks for the help MSUSN. |
I Touch Myself Sometimes
91 Sonic Blue Goodness
19.83 @ 12mph
not a problem gtstang07
![]() MILITARY CREW FOUNDER SCT Custom Tuning, JLT intakes, Aeroforce Interceptor OBDII gauges and PLX widebandsemail joe@tricktuners.com |
Authorized Vendor
HMUSN that is.
19.83 @ 12mph
2006 Mustang GT
12.85 @ 104.85mph before 4.10's
worth the 200 bucks??
![]() BBK LT Headers or x pipe : JLT CAI : 93 octane tune : Flowmasters : Hurst Shifter : Steeda Lower/Upper arms : 325/45r17 M&H's for the track : CHE K-Member/Torque Limiter : FRPP 4.10's : Steeda UDP's : Spec Stage 3+ w/alum fly |
Authorized Vendor
im sure. I only drove it a little bit so you know. Ill let you know when i really test it out
but you could notice a difference in the way the engine felt. Ill put it through the paces tomorrow.Plus im gonna dyno it again and see what i got. |
2006 Mustang GT
sweet bro keep us posted!
Congratz man. One things holding me Back for this Mod is the issue with being conservative on electricity consumption in your car and must have a hawkish eye on your alternator charging your battery. What are your views on this ?
JLT CAI (BamaTuned), UDP, Delete plates, MagnaFlow, Saleen Suspension System, BMR LCA & UCA, Upper Strut Mounts, MGW Shifter, Shorty Antenna, Pony Mats, Tint Protector. * Comming Soon: 4.10 Gears, Clutch, Flywheel & Brembo Brakes. |
Authorized Vendor
Well I talked to frpp about it, among other people on this forum. He said you would not have a problem with pulleys unless you are driving a lot in rush hour traffic like sitting in a traffic jam in hundred degrees with the ac blasting. You would have to watch your gauges then. He also said like a lot of people on here that if you have some huge aftermarket stereo/enterainment system with tv's and xbox hooked up or something it could be a problem. I dont, im stock with the shaker 500. But he said he wouldnt worry about it under normal driving contitions they are still pumping more power than your alt, water pump or power steering needs. If i am sitting in traffic one day ill shut the car or the ac off if i have too.
Oh ok, well that should be alright then. Hope it goes well for you. thanks and keep us posted with HP and long term use
2006 Mustang GT
12.215@112
I've had the steeda pulleys on my car for about 9 months now and never had any issues with them
Saleen SC, 3.4 pulley, GT500 fuel pump,JBA Shorty Headers,O/R H-Pipe,JBA Axle Back Exhaust,JLSCT II Tuner,TCI3000,PMP line locks,3:90gears ,Power House Drive Shaft,BMR UCA&LCA W/relo Brackets |
Threads Similar to: Under Drive Pulleys
| Steeda Under drive pulleys | 07stanggt | 2005+ | 6 | December 20th, 2007 11:47 PM |
| Idler Pulleys Underdrive pulleys? | 96GtGoodz | 96-98 | 4 | November 19th, 2007 11:02 AM |
| Under Drive pulleys, which to buy? | 03_StangGuy | 99-04 | 14 | June 14th, 2007 10:20 AM |
| Under drive pulleys | ByPopularDemand | V6 Mustangs | 12 | April 5th, 2007 02:43 PM |
| 7 tooth drive gear or 8 tooth drive gear for my 98 GT manual | Blue98GT | Modular Mustangs | 1 | January 6th, 2007 07:27 PM |
