Discussing A Possible Major Problem in the 2005+ Forum. well everytime i go beyond 80 mph my car begins to vibrate rather loudly. what ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
2006 Mustang GT
11.27@119.7
www.RADMustangs.com Bassani Crew Member #2 430 RWHP 415 Torque Saleen S/C at 9.5 psi, stock engine and auto transmission, Full Bassani exhaust 11.34 @ 121.8 1/4 7.1 @ 93 1/8 1.54 60' ![]() Check it out at myspacecom/havokdacarking
1999 Mustang GT
Vibrate loudly? like vibrates and makes noises or vibrates very strong? Balding tire or simply bad balancing? Does it pulses when you brake?
13.334 @ 106.57
was it in an accident prior to u buying?
Accufab 75mm TB and Pleunm, JLT cai, Steeda Caster Chamber Plates, Eibach Sportline Springs, Tokico Shocks/Struts, FRPP Aluminum Driveshaft, FRPP 3.73's, Hooker LT's, Hooker O/R X, Pypes Violator Catback, SCT Xcal 2. 280rwhp |
07 Mustang GT 5 Speed
u joint could be out of it as well...just cant feel it at lower speeds?
1965 Coupe
Check the alignment as well. My thunderbird used to shake at high speed, then i discovered the alignment was way out of whack.
2007 Alloy GT
OK, the first thing you should do for this post is let us here know what Mods you have done to the car (meaning rims/tires/driveshaft/Etc.....)? That could help some of us help you.
2007 Alloy GT. 5 speed, Spydershaft, MGW shifter, 3.55 gears, Sequential tail lights, C 300 Cervini's Full Body Kit, CDC Hood Struts, Whipple HO.SC. 468 SAE RWHP 450.44 RWTQ |
2006 Mustang GT
11.27@119.7
yea only at high speeds. n its not the sway bar as it would do it before too. mod list is:
Bassani Long Tube Headers Bassani Catted X-Pipe Bassani Race Mufflers w/ 4 inch tips AFE Cold Air Intake Sanoli Tuned SCT Xcalibrator II Konig Light Alloy Aluminum Wheels 3.73 gears 1-Piece Aluminum Driveshaft 3000 Stall Torque Converter Stage 3 Comp Cams w/ Springs and Retainer Eaton Posi Differential Shelby GT500 65mm Throttle Body Steeda Charge Motion Delete Plates MSD Coil Packs Autolite HTO Spark Plugs Steeda Ultra-Lite Lowering Springs BMR Lower Control Arms BMR Adjustable Panhard Bar LFP Sway Bar Elimination Kit
12.3 @ 115
which driveshaft do you have installed on your vehicle? that might be the source of the problem.....
2006 Mustang GT
11.27@119.7
ULT-CD60350 05-08
2006 Mustang GT
11.27@119.7
its from rpm outlet
2005 Mustang GT
1 piece driveshafts are notorius for causing nvh on the 05+ stangs especially those with an auto tranny. That's why the car comes with a two piece shaft from the factory. Being that the car is lowered, your pinion angle is probably off. Adjust the pinion angle back to spec and see if that helps (i think it's supposed to be -1 to -2 degrees)
Series VI, 3.2 pulley, C&L Racer 95mm cai, 39lb injectors, HTO's, BAP, PCV delete, Saleen susp., JBA LT's and H-pipe, high flow cats, Magnaflows, CHE lca's and antisquats, Saleen shifter, 18" Fanblades, 255/45zr/18 g-force kdw's
#12 | |
2005 Mustang GT
Dyno Racer
+1
start with ckecking ds angle, there has only been 1 driveshaft that has been proven not to vibrate and that is the spydershaft. But there are not a 100% guaranteed either. If I remember he has only had 1 customer that had a vibration with his ds. If not that check your tires for a separated belt or just out of balance
A Couple Bolt-Ons and GOOD Air 613 rwhp and 534 rwtq on 17 psi. and 17 degrees of timing F/I Crew Member #1 KENNE BELL Crew Member #1 |
2006 Mustang GT
11.27@119.7
where can i get that done?
Or narrow it down, replace the shaft with the stock one (assuming you still have it) and go from there ... tire balancing next ... I'd even bypass the shaft if you feel it in the steering wheel. Could be the Posi not working right either ... but you have to narrow down by eliminating the the first two.
2005 Turbonetics Baby!!!
Do you notice it more in the steering wheel, pedals, etc.
2006 Mustang GT
11.27@119.7
more in the seats actually.
Authorized Vendor
none of those mods are new though right? I would start by looking at the tires or the alinegment. lot cheaper to take it somewhere and have the tires checked.
Sounds like a wheel balance issue to me, Been hitting any curbs/potholes recently? Would you be able to feel a DS balance issue at low speeds as well rather than @ 80? Not sure on that one as Im still rolling the two-piece over...
Aston DB9, 91 GT Hatch, 06 EB Explorer Aston Crew Member #1 ( of 1 ) |
2005 Mustang GT
I think most shops that do wheel alignments can check this for you. They can check your front wheel alignment while your there. You will need either an adjustable uca or adjustable lca's to adjust the pinion angle though....
#20 | |
2006 Mustang GT
12.85 @ 104.85mph before 4.10's
And like said above adjust your pinion angle back to stock spec....a adjustable upper link should be your next purchase
![]() BBK LT Headers w/ o/r x pipe : JLT CAI : 93 octane tune : Flowmasters : Hurst Shifter : Steeda Lower & Upper arms : 325/45r17 M&H's for the track : CHE K-Member/Torque Limiter : FRPP 4.10's : Steeda UDP's Hurst Crew Member #3 Co-Founder Last edited by 06GTMustang89 : January 7th, 2008 at 12:24 PM. |
Threads Similar to: A Possible Major Problem
| Need help with major problem | drumvudu | 2.3 Mustangs | 3 | March 13th, 2007 11:03 AM |
| major modifications | Mustang RacR94 | V6 Mustangs | 45 | January 16th, 2007 12:42 AM |
| anyone looking for some MAJOR horsepower | Brianzeke007 | V6 Mustangs | 25 | January 8th, 2007 10:11 PM |
| Major Problems, Need Help | super240sx | 99-04 | 10 | October 30th, 2006 05:48 PM |
| I need major help | yellowgtstang18 | 99-04 | 3 | June 22nd, 2006 01:04 AM |
