Discussing Cylinder Misfire!!!!! in the 2005+ Forum. I have a 06 GT that misfires when it wants to (mostly #3) sometimes multiple ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
Look Ma! My First Post!
Cylinder Misfire!!!!! |
Authorized Vendor
KB'd GT
If you are 100% sure its not any of those things it could be a bad ground or a crappy tune. Do you have cams?
SCT Custom Tuning, JLT intakes, Aeroforce Interceptor OBDII gauges and PLX wideband products @ Trick Tuners email joe@tricktuners.com PM for super MM member deals! |
2005 Mustang GT
Welcome aboard Ivan.........if you have positively ruled the above out as possible causes,..............maybe a bad tank of gas, maybe water in the tank.........are you getting any trouble codes?
Series VI, 3.2 pulley, C&L Racer 95mm cai, 39lb injectors, HTO's, BAP, PCV delete, Saleen susp., JBA LT's and H-pipe, high flow cats, Magnaflows, CHE lca's and antisquats, Saleen shifter, 18" Fanblades, 255/45zr/18 g-force kdw's
12.3 @ 115
do you have a custom tune or completely stock??
if stock, there is a TSB fix on the stock tune to prevent the cylinder misfire. had it happen on my 05 twice when it was stock. if not, I'd check to make sure that all the connections are nice and clicked on the coils |
My o5 was throwing p0355 and p0353 all the time till I got rid of my turbo. I dont know if was the tune or just the turbo, but it was annoying. It hasnt done it since I took off the turbo.
2005 mustang gtZex nitrous Tokico D-Spec Hurst shifter Nitto Drag Radials Hooker exhaust Raptor shift light Foose Nitrous Wheels Eibach pro kit 4.10 gears |
Threads Similar to: Cylinder Misfire!!!!!
| cylinder #8 misfire | tallman20 | General Tech | 4 | October 14th, 2007 04:11 PM |
| cylinder 6 misfire | Jucostud | 96-98 | 4 | May 10th, 2007 11:46 PM |
| Misfire BAD | Casper98GT | Modular Mustangs | 4 | September 5th, 2006 07:24 PM |
| 02 4.6 misfire...help me | aaron175617 | 99-04 | 5 | July 14th, 2006 09:25 PM |
| misfire.... | stang fanatic | General Tech | 10 | June 23rd, 2006 10:08 AM |
