Go Back   Forums at Modded Mustangs > Mustang Forums > Modular Mustangs > 2005+
Discussing Dyno Results 06 GT Supercharger With 20's in the 2005+ Forum. Originally Posted by Pro Form Originally Posted by VegasGT Originally Posted by drgnracin72 anything past ...
Old October 10th, 2006, 02:55 AM   #41
anything past about 500 is unusable on the street even when using drs
Your right, up to about 75 mph or so. Heck my buddies Z06 has 420rwhp and it has traction problems at 60mph or so. He runs a 12.1 @ 116 but he also weighs 31-3200 lbs.
My mission is to pull on him, I figure 475rwhp or up will do it. We will see.
I am at 469 rwhp and I can only get a chirp from 1-2...I hook all the way..mayby my clutch is slipping (helpng) but I like it....pulls hard...no traction issues here.
The streets in vegas are known to have less traction than other areas of the country. We have very little rain and alot of dust/dirt blowing around.
Also keep in mind your centrifical blower makes about 1.6psi per 1,000 rpm at 10psi. So your power and torque climb with rpm. A twin screw blower builds full boost by 2,000 rpm which makes for alot more torque at a lower speed. I took your dyno graph and a buddies graph with a KB and looked at the difference. I WILL DISCLOSE HERE HE HAD HEADERS AND A FULL EXHAUST SO PLEASE DON'T TAKE THESE NUMBERS TO HEART, but as a whole the graphs usually look similar to this between the two types of blowers. It looks like both ended up with about 11psi.
Now here is the difference, at 3,000 rpm your making about 185rwhp/310 rwtq, the KB at 3,000 rpm makes 280rwhp/490rwtq. At 4,000 rpm your making about 285/375 ft lbs and the KB at 4,000 rpm makes about 390/505 ft lbs. This happends till around 6,000+ rpm the Novi and the KB make the same power with the KB just about 35 rwtq higher. This is why a centrifical rolling on the gas will have more traction than a twin screw.
On the flip side of things, your able to make alot of power and keep the IAT (intake air temps) down because of the larger air to air intercooler. The KB and most twin screws have a small water to air cooler and at much more than 12-14psi get very hot and you can not run too long at WOT (wide open throttle). The KB can be pullied up to 24psi but I have a hard time believing the the belt will stay on and the IAT won't be HUGE.
Old October 10th, 2006, 03:55 PM   #42
Originally Posted by T.M.-808-
why did you lose 12 hp with 20's.From the extra weight?
The stock tire is 26" tall,isn't your 20" tire also 26" tall?The dyno can't tell the diffence between 20 inch rims as long as the tire is still 26 inches tall..The track can though...he he..60 ft times...of coarse you kept the stock crappy 17's for track tires,yes?
I can't wait to get my 20's....next month i hope..
Rotational weight. By adding more rotational / unsprung weight it requires some HP / TQ to turn them, so it is lost power to the wheels.
I run the Foose 20's. I lost 10 HP / 20 TQ on the same Dyno with the same mods, on a colder day as well. Each wheel / tire is 15lbs more than stock.
Old October 10th, 2006, 11:25 PM   #43
V-SICKS
itschristorres8's Avatar
00 V6 & 09 GT
13.37@104.4mph--BONE stock GT
i wonder how your car vs a new C^ Z06 whould stand
i heard from a dead stop they dont rip out of the whole to well
The Devil & The Daily
Daily-13.37@104.4mph
V6- Stock bottom-439rwhp & 402rwtq 12psi 100oct
built motor-497rwhp & 508rwtq 15psi pump
Old October 10th, 2006, 11:57 PM   #44
I wonder If I should go back with my stock wheels.
Old October 11th, 2006, 08:45 AM   #45
Slayer of Douchebags
Drgnracin72's Avatar
no keep em. they look badass on your car. keep the sotckers though and throw on some drag radials and have those be your track wheels
RIP
ΜΟΛΩΝ ΛΑΒΕ
One Big Ass Mistake America
Old October 11th, 2006, 10:52 AM   #46
"Slow Ass Car"
ChrisJ's Avatar
SLOW
^^^^What he said...
www.myspace.com/cjobe
Old October 11th, 2006, 02:09 PM   #47
1993 5.ohhhh
14.47 at 96 mph
General question here...how come max torque is allways lower. Is it cause most torque is used in the first few gears for a car to launch?
exploder top end with 12 psi of v-tech
Old October 11th, 2006, 04:04 PM   #48
Offroad X pipe and plugs will be here monday....hope shes not to loud.
Old October 11th, 2006, 10:08 PM   #49
V-SICKS
00 V6 & 09 GT
thats not true
i think the V6 mustang come with my torque then hp
plus ive seen plenty of mustangs with more tq then hp
Old October 11th, 2006, 11:43 PM   #50
My partners sl65 has 600 HP/700 TQ
Old October 12th, 2006, 02:21 AM   #51
V-SICKS
00 V6 & 09 GT
yea its just Pro Form's car thats all fucked up!
haha just kiddin
most cars do have my hp though..
but tq gives you numbers!
Old October 12th, 2006, 02:43 AM   #52
2001 Mustang Bullitt
13.24@106.48
Nice numbers on the dyno. I can't wait to go forced induction.
2001 Bullitt #5069
Vortech SQ-Trim
366rwhp/382rwtq @ 8#s
AFM Power Pipe
MGW STS
Originally Posted by FluffyTheRhino View Post
Nothing says "Upgrade EVERYTHING" like busted parts
Old October 12th, 2006, 03:48 AM   #53
I understand this...but how can the dyno operator say for sure "10 hp",thats a guestameet...
and everyone who mods there cars puts wider tires on there stock rims,or bigger rims,so why is it that folks seem to think that only the new body style losses power for bigger tires,and or rims?
Nice car by the way...
..........05 GT... 2 1/2" DROP..........
Old October 12th, 2006, 03:52 AM   #54
True,but they'll still run a mid 11 crossing the time line just after shifting into 4th gear out of 6.go to www.digitalcorvettes.com and watch all the street racing and track vids...killer vids...i used to be a moderator for years on that site..
Old October 12th, 2006, 05:30 AM   #55
acehogg69's Avatar
06 GT with bolt ons
I sucked
What about changing the rear end gears to compensate for the 20's or even a 18's in the rear with a charger?
Kyle Busch Haters Club!! Member Uno!
Tony wrote "Blowers blow, turbos suck, and nitrous rules!!! lol "
Borla cattless L/T's topped with Flowmasters , Roush short throw, JLT2 CAI w/ X-CAL2 from Brenspeed, Bullit 18X9 and 18X10 deep dish.
Old October 12th, 2006, 06:02 AM   #56
No gears needed to "compinsate",the 20 inch tire is only a 1/4 inch taller than the stock255/55/ 17" tire= 26"...285/35/20=26.1 inch tall.
It's the rolling weight that sucks a few ponys.Hope that makes some sense..
Old August 14th, 2007, 06:26 AM   #57
GT/CS's Avatar
Power can be lost due to increased wheel weight, true. However, even if you take a 25 pound 18in wheel and stretch it to a 25 pound 20 inch wheel you still lose power. It has to do with increasing the power needed to over come the inertia of the wheel to spin it.
Ford Racing heads, Comp stage III cams, 4.10's, Steeda delete plates, SLP long tube headers, Custom 3'' X pipe, Magna flow 3" Magnapacks, Airaid CAI, SCT XCAL 2 93 tune, Steeda front and rear swaybars, Dynotech aluminum driveshaft, HTP TB spacer
Threads Similar to: Dyno Results 06 GT Supercharger With 20's
Dyno Results? Wally1968 2005+ 35 November 21st, 2007 02:21 PM
My Dyno Results WAVEBYE The Clubhouse 46 October 25th, 2007 10:47 PM
Dyno results in!! stanglifemike 2005+ 35 September 20th, 2007 11:05 PM
Sniper New Tune...and Dyno Results... 02ponypackage Electronics 29 September 11th, 2007 11:09 PM
My DYNO results are in!! Bossman 2005+ 18 February 7th, 2007 08:34 PM
