Discussing Coil On Plugs?? yes or no? in the 2005+ Forum. Has anyone installed an aftermarket set of COPs?? if so, are they worth the money? ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
2007 Mustang GT
12.72@108
Bassani O/R X and axlebacks C&L 93 octane tune by Triangle Speed Shop FRPP 3.73 gears Hurst shifter-J&M LCAs-Eibach Pro custom grind Comp Cams (thanks to RADMUSTANGS) 312rwhp (on a Mustang dyno, stock intake) Bassani Crew Member #3 |
2004 F-250 PSD
1/8th 9.256 77mph
msd makes some for your yr of stang
![]() NOBAMA 08 MM Truck Crew (Founder) MM Mach 1 Crew (Founder) |
2007 Ford Mustang GT
13.491 @ 106.19mph
not worth it unless your s/c but then its negotiable.
JLT, Hurst, 4.10s, Stage II NSR Cams, Kooks LT w/ H pipe, Stingers, Black FR500 rims, BMR (Lowering Springs, Adj Panhard Bar, LCA w/ brackets), Tokico shocks/struts Hurst Crew Member #13 Cammed Crew Military Crew E-5
2006 Mustang GT
^ what they said.
![]() -C+L Street intake -SCT X-Calibrator2 tuner w/Brenspeed tunes -Kooks LT headers w/catted X-pipe -Steeda Pulleys -MAC axlebacks Please leave rep for helpful info.
02 ROUSH STAGE 2
I have read that they are no better or not as good as stock cop's!
2007 Mustang GT
12.72@108
thats all i need to know, thanks guys........
13.491 @ 106.19mph
might as well get some Steeda Pulleys & CMDP with the $300+ you would have spent. That is if your staying N/A
2007 Mustang GT
12.72@108
im staying N/A for a LONG time, not because i neccesarily want to, because i cant afford F/I right now lmao
06 Mustang GT
10.83 @125.50
I installed msd's on my wifes stang as well as mine in between runs and we both picked up .07, so they are worth about 7 hp. give or take.
2006 Mustang GT
Obviously....running 10s..doing something right.
2007 Mustang GT
12.72@108
i bet he is still setting on the stock suspension.
2005 mustang GT
10.672 @ 128.42mph
I noticed a little benefit also, but I am also s/c'd with 16psi. I think its generally accepted that N/A they are not worth anything in the way of performance.
Daily driven 2005 Mustang GT Auto - Whipple @ 16 psi - 577 rwhp 519 rwtq 10.672 @ 128.42. Best 60' 1.43. Best 1/8th 6.74 @ 101.50 mph ![]() http://videos.streetfire.net/video/2...-GT_164989.htm |
05 GT
13.14@104
Yeah I saw a vid on on the GMS site. It seems that on turbo and SC the motor benefits from the extra zap the coil on plugs gives; like many of the mods we get sold, they seem to work best at higher RPM or bigger bhp applications. Which if you think about it stands to reason
06 Mustang GT
10.83 @125.50
I have ran in the 10's on stock suspension last fall, but was spinning and couldnt run the same number every pass. with the setup I have now it will run a 10.94 to 10.97 every pass with 150 shot
#18 | |
13.491 @ 106.19mph
05 GT
13.14@104
Yeah I heard bad things too; Im keeping clear of ignition and coils etc until I have some weight ripped out and decent heads, I reckon our stock electronics is more than OK for the 415 I reckon Ill have NA with heads
Threads Similar to: Coil On Plugs?? yes or no?
| coil on plugs which ones ? | greenwood | 99-04 | 20 | February 5th, 2008 07:22 PM |
| motoblue performance coil on plugs | pr gt | 2005+ | 1 | August 15th, 2007 10:13 PM |
| Cop's (coil on plugs) for sale. | jivepepper | For Sale | 0 | May 14th, 2007 07:19 AM |
| Aftermarket coil on plugs | 1SLO85 | 99-04 | 7 | January 26th, 2007 11:32 AM |
| coil, plugs, wires? oh my | Orangester | V6 Mustangs | 20 | January 17th, 2007 06:10 PM |
