Go Back   Forums at Modded Mustangs > Mustang Forums > Modular Mustangs > 2005+
Discussing 03-04 termie block? in the 2005+ Forum. Can I put one under my heads straight up? Or are the two non compatible?...
Old April 21st, 2008, 01:40 PM   #1
MM's resident Juice head
07 procharger's Avatar
07 Mustang GT
03-04 termie block?
Old April 21st, 2008, 01:44 PM   #2
2006 Mustang GT
11.02@122.6
u should be able to... if imm not mistaken, mmr use 03-04 cobra block on their short/long blocks.. if i were u id just keep the aluminum block we have n forge n stroke to save weight....unless ur planning above 900 rwhp.
www.RADMustangs.com
www.s197Performance.com
Bassani Crew Member #2
10 PSI
11.02 @ 122.6 1/4
6.9 @ 96 1/8
1.51 60'
Check it out at myspacecom/havokdacarking
Old April 21st, 2008, 01:48 PM   #3
07 Mustang GT
no im not going that high...just looking at options...i want t tough bottom end.
Old April 21st, 2008, 01:51 PM   #4
Grabber523's Avatar
2007 Mustang GT
12.3@113 1.8 60'
FRPP Aluminator FTMFW!!
HMUSN: "I was rewarded with a fart of colossal magnitude -- a cross between the sound of someone ripping a very wet bed sheet in half and of plywood being torn off a wall."
Old April 21st, 2008, 01:51 PM   #5
Authorized Vendor
07stanggt's Avatar
2007 GT
12.40@114.55
Old April 21st, 2008, 01:52 PM   #6
07 Mustang GT
link me holmes!
Old April 21st, 2008, 01:56 PM   #7
05mustang_kb_charged's Avatar
2005 Mustang GT
Dyno Racer
stock MFABFTMFW!!! they have plenty of people using the factory blocks on high hp builds. I would do some more reading since people have come to think the 05+ aluminum blocks or as strong as or stronger than the teskid blocks. they use a different pouring process for the new blocks that is better than the steel blocks
A Couple Bolt-Ons and GOOD Air
613 rwhp and 534 rwtq on 15 psi. and 17 degrees of timing
F/I Crew Member #1
KENNE BELL Crew Member #1
Old April 21st, 2008, 01:56 PM   #8
JStang14's Avatar
you would need to change out pistons unless you are going S/C
Old April 21st, 2008, 01:59 PM   #9
Grabber523's Avatar
2007 Mustang GT
12.3@113 1.8 60'
"stock MFABFTMFW!!! "
^ Sweet...
Yeah, you swap pistons and rods, but the stock blocks and crank can handle a good bit of abuse.
Old April 21st, 2008, 02:00 PM   #10
Authorized Vendor
07stanggt's Avatar
2007 GT
12.40@114.55
Originally Posted by 07 procharger View Post
link me holmes!
to what the aluminator or some tough bottom ends?
Old April 21st, 2008, 02:02 PM   #11
07 Mustang GT
both i likes to read....
Old April 21st, 2008, 02:04 PM   #12
Authorized Vendor
07stanggt's Avatar
2007 GT
12.40@114.55
Ford Racing Performance Parts [M-6009-A46NA*]
cant link you to the tough bottom ends in the tech section but there is the aluminator.
Old April 21st, 2008, 02:08 PM   #13
Authorized Vendor
07stanggt's Avatar
2007 GT
12.40@114.55
there you can sell some of them with some nice tops to got the the bottom. in case you like a well rounded girl.
Ford Racing Performance Parts [2008 Catalog New Parts]
Old April 21st, 2008, 02:09 PM   #14
07 Mustang GT
it doesint say it fits 05 and up but im sure it does.....hmmm pretty pricey....i think i could build my block for cheaper
Old April 21st, 2008, 02:11 PM   #15
Grabber523's Avatar
2007 Mustang GT
12.3@113 1.8 60'
By the time you figure parts and labor...they're about even...
Old April 21st, 2008, 02:11 PM   #16
Authorized Vendor
07stanggt's Avatar
2007 GT
12.40@114.55
yep
Old April 21st, 2008, 02:12 PM   #17
Authorized Vendor
07stanggt's Avatar
2007 GT
12.40@114.55
well our block already has forged crank so all he really is talking about is the forged pistons. everything else he needs to change is in the heads.
Old April 21st, 2008, 02:15 PM   #18
2006 Mustang GT
11.02@122.6
our block has what??? a forged crank??
www.RADMustangs.com
10 PSI
11.02 @ 122.6 1/4
6.9 @ 96 1/8
1.51 60'
Old April 21st, 2008, 02:16 PM   #19
07 Mustang GT
are cranks ARE forged??...and I will do most of the labour...except any headwork.
Old April 21st, 2008, 02:22 PM   #20
Grabber523's Avatar
2007 Mustang GT
12.3@113 1.8 60'
Well, there ya go. I guess Eagle is pretty good bang for buck as far as beefy innards. I want to see no less that a 300 shot on that ride!!
Threads Similar to: 03-04 termie block?
moderate termie flyby ZOOTOXIN Videos 9 March 5th, 2008 07:29 PM
Mach vs Termie weems Street 11 January 12th, 2008 05:44 PM
Beat a Termie!! k2boarder3187 Street 21 October 22nd, 2007 08:12 PM
Yellow '03 Termie DrHolliday The Clubhouse 62 September 28th, 2007 11:45 PM
short block differs from a long block how? mustangfox9091 5.0 Mustangs 35 September 26th, 2007 11:57 PM
