Discussing 3v spark plug problem in the 2005+ Forum. Its a tough call. There doesn't seem to be a wide variety of choices ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
#21 |
2007 Roush 427R
Its a tough call. There doesn't seem to be a wide variety of choices right now. The guys with the more factory normally aspirated engines have a good one piece Champion 7989 plug to choice from but thats the only one so if they don't like that plug they are stuck unless they decide to have some sort of on going maintenance program pulling their old plugs. I'm not sure if thats even the perfect fix. Us supercharged guys are in a bit more difficult situation.There is a one piece Brisk plug but its sort of an in-between heat range plug so I don't really know how it will work. I've been told its a perfect fit for my car but we've all heard that sometime in the past so its a wait and see thing. Also Roush doesn't recognize that plug and so any changes I make could effect 'warranty' so I need to make sure I pick the best plug. Its a catch 22 right now. Its like alot of things, you do what you think is right for you and see how it works. At least we are only talking spark plugs...I can think of a few other issues that could be a lot more troubling...
#22 |
2006 mustang gt
I guess when I take my car to the dealer to get the recall fixed it would be a good idea to have the plugs and let my dealer install them since its still under warranty. That way if they break with them they can fix the problem.
#23 |
2007 Roush 427R
Since the Spark plugs aren't a recall item and only a TSB, if they replace them or even perform the TSB and they happen to break one or more plugs, its your cost not there's. That been discussed also. I'd talk to the service dept and get whatever they say in writing. I've heard dealers are trying to keep this plug issue hush, hush.
#24 |
2006 GT
13.69
Whoa!!!!!!!11
Arnt These Plugs 100,000 Mile Plugs , Mine Say Tune Up @ 100,000 Miles
BORLA STINGERS,FORD RACING GEARS 3:73/,AIRAID CAI ,vast int. & ext. JEWELRY ![]()
#25 | |
2006 mustang gt
#26 | |
2007 Roush 427R
#27 |
MMs Ford Racing Nut Swinger
2007 MUSTANG GT
I just turned 5000 miles on my 07. I am sure glad I seen this post.. My next mod will be to replace those stock plugs with the Champion 7989s!!
Left rep for ya 427!!
![]() sig by MUSCLETANG. Thanks Chad. |
#28 |
The 08's are designed diffrently using a plug similar to the more common 1 peice plug. I had 5 of 8 break off leaving the ground sheild in the head. I followed the TSB exactly and even added several hours of soak time. Cost me $240 + a tow bill to the dealer to fix it. This was a discounted price due to some contacts at the dealer. Normally the service bill would have been around $500. There were equal amounts of carbon on all the plugs but some seized and some didnt. I think its contributed alot to faulty plugs. I tried to take apart one of the plugs that came out whole and couldnt get it to come apart like the others. The ones that seized come apart using less than 15lbs of torque. Who knows but it sure is a pain. Just make sure to anti-seize the shankbelow the thread but not near the end. It doesnt take much just a very light coating. This will keep the carbon build up off of the shank.
#29 |
MM's resident Juice head
07 Mustang GT
im kinda screwed with my nitrous set up........great...well on the upside i plan on inspecting my plugs every month....hey is anyone else here breaking the coil clips when removing them from the coil on plug? ive had to splice in 2 now!
![]() The MGW short throw shifter Its not just a shifter...It's a lifestyle! |
#30 |
2006 GT
13.69
Yo Yo Yo Yo Yo
I TALKED TO THE SERVICE DEPT. @ MANTILLA FORD HERE IN CT. THEY HAVE A HOT ROD DIVISION AND THEY ARE AN SVT DEALER, THEY SAID DONT GO CHANGING UR PLUGS PREMATURELY, IT WONT MATTER ,THERE A BITCH TO GET OUT AT ANY MILEAGE, IF U CHANGE THEM @ 5000 OR 90,000 MILES. HE TOLD ME THEY HAVE SPECIAL ADOPTERS FOR THEIR TOOLS TO GET THEM OUT AND ITS NO PROBLEM.JUST TIME CONSUMING THE TOOLS ARE PICTURED ON ONE OF THESE REPLYS ON THIS THREAD. HERES THE KICKER THE CHARGE IS 3-4 HRS LABOR PLUS THE THE PRICE OF THE PLUGS. SO U ALL HAVE 100,000 MILE PLUGS ,IF U HAVE NO PROBLEMS WITH THESE PLUGS THEN LEAVE THEM ALONE AND HAVE A REPUTABLE FORD DEALER DO IT @ AROUND 90,000 MILES , THATS WHAT IM DOIN!!!!!
I ALSO USE LUCAS FUEL INJECTOR AND VALVE CLEANER EVERY 3-4000 MILES THIS WILL ALSO HELP KEEP THE PLUGS CLEAN
#31 |
2007 Roush 427R
I guess we all do our own maintenance on our own terms. Some do it ourselves and some rely on the dealership to do it. Either way whatever works for the car owner. We have car club tech days and we've replaced several sets plugs without issue. I doubt my car will see the inside of a dealership garage unless there's a major recall on something. My advice to everyone is do what you think makes the most sense for yourself. If someone is going to drive it the vehicle for 70,000+- miles and then sell it, I wouldn't think about pulling plugs. Let that be somebody else's issue. Mine are coming out sometime before winter sets in.
#32 | |
2008 GT 5Spd
13.7 102.39
Thanks for the info.These are the plugs I have in my Stang.There was a thread on here a while back to see if you have the revised heads,to check which plugs you have,I pulled one to see if I did,and I do,plug came out and looked good,but I've only got 10,000 my car.Maybe I should check with my dealer about the TSB.Whats the number on the TSB???
"Drive it like you stole it"
#33 |
2007 Roush 427R
tsb 08-7-6
#34 |
2008 GT 5Spd
13.7 102.39
Thanks..I've got a good relationship with my dealership,I'll have to ask them if this includes the 08's also.....
#35 |
2006 Satin Silver GT
11.47@118.20
I have 20,000 on my 06... about 2000 of that supercharged... I thought that the plugs were good for a lot longer than 20,000. Is there any reason to change them sooner if the only time they break is when they are removed? what is the expected life of the stock plugs.. someone ^ said 100,000 miles, is that correct?
![]() 2.6l KENNE BELL 100% forged bal and blu Stroked to 298 / Ported/polished heads Long tube/O/R X / McLeod twin 8 rib/65 lb injectors ET Drag Slicks/3.73 gear Detroit Truetrac GT500 twin fuel CDC AGR Spoiler D/S rotors / MGW Short Throw |
#36 |
2006 GT
13.69
plugs
yes thats correct 100,000 miles , but a safer replacement is around 90,000 if u dont have a problem with them , on supercharged engines im not sure probably the best people to ask that question is the manufactor of the supercharger.
#37 |
11.47@118.20
I will just stay off the juice and blow it up long before 90,000.. my stroker replacement won't have these plugs,EVER !!!!!
Threads Similar to: 3v spark plug problem
| spark plug gap? | 1982matthew | 5.0 Mustangs | 7 | April 22nd, 2008 06:27 PM |
| Spark plug | Elder | 4V / SVT | 3 | April 20th, 2008 10:32 PM |
| Oil with my spark plug!! HELP | caintcatchmyGT | 96-98 | 24 | November 1st, 2007 01:22 AM |
| spark plug ?'s | tgk | 94-95 | 1 | August 25th, 2007 08:29 AM |
| serious spark plug problem | calicuttc | General Tech | 1 | July 27th, 2007 04:22 PM |
