Go Back   Forums at Modded Mustangs > Mustang Forums > Modular Mustangs > 2005+
Discussing Hood Pin Install?? in the 2005+ Forum. Originally Posted by TheUNZippee! I simply used a rubber grommet to fill the hole. If ...
Old May 8th, 2008, 12:44 AM   #21
prinzzz's Avatar
Thumbs down
I simply used a rubber grommet to fill the hole. If you look closely in this picture you can see it.
a1
07 gt-20"maas/toyo t1r-frpp handling pac-frpp drag pac/3.55-manual-frpp x pipe and exhaust-frpp headershurst short throw shifter-frpp/whipple 500hp twin screw kit, cervinis ram air iv, mcleod twin disc clutch, billet flywheel, zex 75/175 shot
Old May 8th, 2008, 12:59 AM   #22
Stone Cold Mod
TheUNZippee!'s Avatar
2007 Mustang GT
282 rwhp/292 rwtq
Location: I've got Rags in my bubble and I don't know what to do with it!
Thanks man
Dyno Pull/MBRP's - The pee Test
My Mods
Originally Posted by OMU
don't look like a loser when posing.
Old May 8th, 2008, 01:09 AM   #23
ROUSH STAGE II's Avatar
2005 Turbonetics Baby!!!
Don't know about the factory hood, but with my aftermarket hood I drilled the first holes, then put a dab of white lithium grease on the posts to mark the inner most part of the hood. Then drilled 1/8" pilot holes from the inside. Then taped the outside of the hood to prevent chipping and drilled the final holes the exact size from the outside to find the exact location. Worked out perfectly!
Turbonetics baby!!!
60' - 1.73
1/8 - 7.59
MPH - 94.62
1/4 - 11.743
MPH - 119.36
Race weight 3,770 #'s
3.55 gears
Old May 8th, 2008, 01:11 AM   #24
Stone Cold Mod
2007 Mustang GT
282 rwhp/292 rwtq
I mounted the pins on the rad support, put a dab of red silicon on the tip of the pin, gently touched the hood to the pins, and then drilled up from the bottom of the hood with a step bit. I also went to Home Depot and bought stainless bolts, lock washers, washers, and nuts, to use in place of the stainless screws, which were barely long enough too bite properly
My Mods
Threads Similar to: Hood Pin Install??
F/S HOOD AND DECK PIN KIT and few other things HTK241 For Sale 7 January 2nd, 2008 11:25 PM
Hood Pin Poll Regency 2007 2005+ 49 December 25th, 2007 12:00 PM
Ford Racing Hood Latch & Pin Kit gills99stang 99-04 69 August 1st, 2007 05:37 AM
Hood pin Difficulty blk98gt 96-98 1 July 24th, 2007 04:27 PM
Hood Pin Help. TheUNZippee! 2005+ 15 April 16th, 2007 07:45 PM
