Discussing Cut-In Cat Kit? in the 2005+ Forum. Hey guys, I am finally about to buy an exhaust system for the stang. I ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
Cut-In Cat Kit?I am finally about to buy an exhaust system for the stang. I want to get the mac LT's with prochamber mid and the FRPP stinger axle backs. The problem is i need cats because i have to pass emissions testing. I phoned brenspeed to see if another type of catted mid-pipe would fit, spoke to Seth there and he says i can buy a cut-in cat kit that i can cut into the shorty o/r prochamber to make it pass emissions. Has anyone ever used something like this or heard of it being used? If so, are they any good and will i need to buy anything along with it? Thanks
'07 GT Alloy, 5 speed; JLT, Livewire, MGW
2006 Mustang GT
Alloy 2007 Mustang GT
13.39@103.49
![]() Alloy 07 GT Hurst Shifter C&L Racer Intake w/Breenspeed Tune Eibach Pro Kit Pypes Mid-Muffler System 4.10s (Waiting to be installed) Current Best Time: 13.39 @ 103.49 (With Intake, tune, and shifter only at the time) Hurst crew member #8
#5 | |
13.39@103.49
Don't know of any solutions off the top of my head, but I'll look some more tonight.
Captain Of Team Leg Hump
2006 Mustang GT
In the 13's
![]() Bassani Crew Member #1 Better to be judged by 12 then carried by six. |
i found this kit off Jeg's after you linked me there PYPES CVM10K - PYPES Catalytic Converters - JEGS does anyone know how well this will fit/work if i cut it into the prochamber? Also, will i need to weld in bungs for 02 sensors or something or will they come on the headers/mid pipe/cats whichever?
13.39@103.49
2006 Mustang GT
In the 13's
2007 Mustang GT
Prochamber, Stingers, Pypes cats.....INSTALLED
I doubt it would have the exaust heat needed to make the cat's work... Not too sure on that though..
Authorized Vendor
2007 GT
12.40@114.55
There is only one prochamber, you can get it three ways, First, with legs that run all the way to the stock manifold or shorty headers, Second, with shorter legs that run to the long tubes, or you can just buy the prochamber itself and splice it in. You would do this in the same way you would do a splice in xpipe, you cut behind the H crossover and bolt the prochamber on. So, you have a couple of options; Buy the prochamber by itslef and find some catted legs and make them fit to the mac lts. Or you could buy the legs that go to the lt's and cut and weld in your stock cats, or aftermarket cats. Mac had a catted system for the long tubes until 2005, catco made the cats, they stoped providing warranties for the cats and Mac stop buying them. So it can be done, its in essence the same length leg. |
#14 | |
Authorized Vendor
2007 GT
12.40@114.55
I just clicked on that link piggy sent. Basically that is what can be done. Like i said in my last post, the prochamber is the prochamber, and what he did is buy some cats and plugged them straight into the prochamber where the leg, or "downpipe" would insert and then cut the leg to fit into the cat. That is an option to, but would certainly move the cats back further then what they normally are, we all know what code that can throw the 133. See he is doing it that way to avoid welding it. Like i said it would be interesting to see if he were getting the 02 sensor slow response cel. The other option is to cut 9 inches out of the middle of that down pipe or "leg" and weld the cat in. Last edited by 07stanggt : May 7th, 2008 at 11:58 PM. |
#15 | |
2007 Mustang GT
Threads Similar to: Cut-In Cat Kit?
| has anyone ever CUT!!!!!!!! | show95stang | 5.0 Mustangs | 3 | March 25th, 2008 01:21 AM |
| stock cat-back 99-04 bolt on... un-cut | 00SoSlow | Exhaust | 3 | February 26th, 2008 03:05 AM |
| X-pipe.....to cat or not to cat...that is the question... | themainman | 99-04 | 27 | June 11th, 2007 01:48 AM |
| Y Cut-out | TheChariot9923 | Exhaust | 11 | March 14th, 2007 07:29 PM |
| 1995 GT cat or no cat | new 5.0 | Exhaust | 5 | January 18th, 2007 01:30 PM |
