Go Back   Forums at Modded Mustangs > Mustang Forums > Modular Mustangs > 2005+
Discussing Trouble codes in the 2005+ Forum. I ran a diagnostic check with the diablo tuner and I got a few trouble ...
Old May 10th, 2008, 10:54 PM   #1
gragra73's Avatar
Trouble codes
I ran a diagnostic check with the diablo tuner and I got a few trouble codes,
P0600 (serial communication link) , P1000, P2105 (Throttle actuator control-Forced engine shutdown) and U0305 (unknown) Before I adjusted the tuner to reflect the new tire size I was not getting any trouble codes. Should I just leave it alone for now? My check engine light is not coming on and the car seems to be running fine.
Old May 10th, 2008, 11:45 PM   #2
frdfrst's Avatar
05 mustang gt
i got the same codes.it was coil pack{s}.changed them out and everything went away.i have 05 gt with 51000 miles on mine.i had a 97 f150 with the 4.6 did the same thing at about 40000.while i was at it i went to new champion 7989 plugs.so far so good on those.
Old May 11th, 2008, 01:32 AM   #3
gragra73's Avatar
Thanks, I may change the sparkplugs in the near future. I cleared the trouble codes, then started the car. I checked again for trouble codes and no trouble codes were found.
Old May 11th, 2008, 01:40 AM   #4
stangracer01gt's Avatar
2005 MUSTANG GT
I got the exact trouble codes today. Except I got a U0300. I been having trouble with throttle lag with Bamachips tune. I went to re-install the Diablo 91 K&N tune and at the end of the download the message center said "FAIL SAFE MODE". No check engine light but I decided to check for codes and thats what I got. The car seems to run fine, I did clear the codes, I'm gonna drive it around for a day and check agian. I read it's something to do with the throttle body messing up. I getting frustrated!!
05 GT, JLT II, BAMACHIPS 91 RACE TUNE, DIABLOSPORT, PYPES VIOLATOR, EIBACH PRO KIT, CDC CLASSIC CHIN SPOILER, 3.55.
Soon to be installed: 18" deep dish Bulliltts. Wish list:4.10 gears.
Old May 11th, 2008, 02:06 AM   #5
05mustang_kb_charged's Avatar
2005 Mustang GT
Dyno Racer
Safe Mode?????
When my car went into Safe Mode it wouldn't rev past 3k rpm and had no throttle response. Might be something in the tune but you would know if the car was in Safe Mode
A Couple Bolt-Ons and GOOD Air
613 rwhp and 534 rwtq on 17 psi. and 17 degrees of timing
F/I Crew Member #1
KENNE BELL Crew Member #1
Old May 11th, 2008, 02:14 AM   #6
gragra73's Avatar
Tomorrow I will drive around and then re-check for codes. The car runs fine, but I was just curious and decided to check for codes.
Old May 12th, 2008, 03:58 PM   #7
gragra73's Avatar
I re-checked for codes after driving around for a little while. No codes were found. I guess everything is okay....for now.
Old May 12th, 2008, 04:47 PM   #8
silverstang's Avatar
2007 Mustang GT
13.37@105
U codes are from reprogramming a module, (such as installing a tune)........they are normal occurances after a reprogram, they just need to be cleared out......p1000 means the car hasnt gone through a complete drive cycle since the last reflash/battery disconnect, etc...(a p1000 is how we know a vehicle has a chip in it when a customer brings it in the shop)........because that means a customer has recently removed the tune, and programmed back to stock, and it hasnt been long enough to complete a drive cycle.
Bassani O/R X pipe
Bassani Axle Backs
C&L
93 octane tune by Triangle Speed Shop
FRPP 3.73 gears
Hurst Short Throw
custom grind Comp Cams (thanks to RADMUSTANGS)
13.37 @ 105 on stock tires W/O cams, shifter, or intake
Bassani Crew Member #3
Old May 12th, 2008, 08:48 PM   #9
What is a complete drive cycle?
Old May 12th, 2008, 09:15 PM   #10
gragra73's Avatar
I modified my custom tune to reflect the new tire size. I guess that is were the error codes were coming from.
Old May 14th, 2008, 03:23 PM   #11
2007 Mustang GT
13.37@105
those codes came from the reprogram most likely, every time we reprogram a vehicle at work (update pcm, etc)......there are U codes present, which our diagnostic software automatically knows to clear the codes after a reprogram. a complete drive cycle basically is how long it takes the car to run its normal "tests" to make sure everything is functioning properly.........like when you put an O/R x pipe on your car without a tune, it takes a while for the check engine light to come on, because the car hasnt "checked" itself for errors yet.
Bassani O/R X pipe
Bassani Axle Backs
C&L
FRPP 3.73 gears
Hurst Short Throw
Old May 14th, 2008, 05:39 PM   #12
Grabber523's Avatar
Location: Northwood, ND...yes, hell does freeze over...
Originally Posted by 05mustang_kb_charged View Post
Safe Mode?????
Yeah, a little wrench-shaped light comes on, the car drives sluggish, and it won't let you set the cruise control...disconnecting the battery makes it go away.
myspace.com/grabber523
2007 Grabber Orange GT Premium 5-Speed, CDC Sequential Taillights, 2.6L Kenne Bell, 3.73 FRPP Gears, Steeda Tri-Ax, Dynotech Alum. D/S, BMR D/S Loop
Threads Similar to: Trouble codes
Trouble Codes... Hasselm8 99-04 6 March 14th, 2008 12:52 PM
Trouble Codes GTsetGO Modular Mustangs 15 December 4th, 2007 03:13 PM
trouble codes...HELP!!! sleezy 96-98 6 July 10th, 2007 10:06 PM
trouble codes '94 3.8 DJ207 V6 Mustangs 2 June 18th, 2007 11:24 AM
trouble codes scubasteve041186 V6 Mustangs 2 December 31st, 2006 11:19 AM
