Discussing CEL came on with 2 codes, need help in the 2005+ Forum. Ok so I just pulled my VC's and painted them and put them back ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
2006 Mustang GT
CEL came on with 2 codes, need helpCar starts and runs fine. But im worried about the CEL that popped up. Codes read: p0183 p0193 I plugged everything up the way it was suppose to and found no problems when re-installing. What can I do? |
2007 Mustang GT
13.37@105
the p0183 is your fuel temp sensor voltage too high..........the p0193 is the "fuel rail pressure sensor circuit A too high"............you need to check all your connections on the fuel rails.........sounds like when you plugged everything back in, you forgot, or mis-connected a harness. Easy fix, just take your time.
Bassani O/R X pipe Bassani Axle Backs C&L 93 octane tune by Triangle Speed Shop FRPP 3.73 gears Hurst Short Throw custom grind Comp Cams (thanks to RADMUSTANGS) 13.37 @ 105 on stock tires W/O cams, shifter, or intake Bassani Crew Member #3 |
2006 Mustang GT
Ok so then my next question is does gray go on top, or black clip? Should I unplug them all and re-plug them back in on the fuel rail?
2006 Mustang GT
bump for help
2007 Mustang GT
13.37@105
im not possitive on that, but what my research is telling me, something is not plugged in, or something is plugged in the wrong place.
2006 Mustang GT
Ok I unplugged all connections, then plugged them back in. 2 were loose and I fixed those. Still throwing CEL. Do i need to clear the code now that everything is tight or will it just go away on its own. Its bugging me because everything is where it should go, i mean there isnt really anything that could go anywhere else....
2007 Mustang GT
13.37@105
its not going to go off by its self.....at least not right away.......if you aren't about to go anywhere, unhook the battery for about an hour or so.....(it doesnt take that long, but if you have the time, why not).........that should take care of it for you.
2006 Mustang GT
Isnt there a thing I can do like unhook it and hold the break down or something? Also should I re-tune my car with the 93 tune?
Use your tuner to clear the codes.
2006 Mustang GT
SCT tuner won't delete these codes.
Threads Similar to: CEL came on with 2 codes, need help
| CEL | 07stanggt | 2005+ | 13 | May 1st, 2008 01:21 AM |
| woo hoo more CEL codes | mikethetigerrr | V6 Mustangs | 10 | August 22nd, 2007 01:42 PM |
| CEL came on. Codes | JASonic | The Clubhouse | 2 | July 27th, 2007 05:57 PM |
| CEL with O/R X | 01GT | 99-04 | 4 | May 25th, 2007 07:50 PM |
| CEL codes - 96 v6 mustang | AtlanticBlue99 | General Tech | 12 | December 12th, 2005 08:20 PM |
