Go Back   Forums at Modded Mustangs > Mustang Forums > Modular Mustangs > 2005+
Discussing Coil on plugs? in the 2005+ Forum. Those aftermarket ones..they are suposed to be a hotter spark or somthing...are they ...
Old May 12th, 2008, 04:01 PM   #1
07 procharger's Avatar
07 Mustang GT 5 Speed
Coil on plugs?
Those aftermarket ones..they are suposed to be a hotter spark or somthing...are they worth buying or is it a scam..like octane boost?
http://s245.photobucket.com/albums/g...ent=run005.flv
Nitrous is for western hayseeds who profit from raping the loins of our great nation.
Oh, hi, Ken.
Old May 12th, 2008, 04:10 PM   #2
silverstang's Avatar
2007 Mustang GT
13.37@105
i have heard different opinions on them............but all in all, i think it came down to being n/a or fI...........i think they where helping the guys with turbos and chargers, but not really the naturally aspriated thing.
Bassani O/R X pipe
Bassani Axle Backs
C&L
93 octane tune by Triangle Speed Shop
FRPP 3.73 gears
Hurst Short Throw
custom grind Comp Cams (thanks to RADMUSTANGS)
13.37 @ 105 on stock tires W/O cams, shifter, or intake
Bassani Crew Member #3
Old May 12th, 2008, 04:29 PM   #3
what about N/A plus stuffing it with 100 shot?
Oh, hi, Ken.
Old May 12th, 2008, 04:30 PM   #4
acmillr's Avatar
2003 GT
Street Fast 16.9@76MPH
I don't think they are a wise purchase. THe stock coils put plenty of fire to the plugs.
Originally Posted by Dennis-96GT View Post
its been nice actually having a civilized discussion with ac for once
Old May 12th, 2008, 04:44 PM   #5
2007 Mustang GT
13.37@105
well i have heard of the spark being "blown" out if the gap is set to much when using nitrous (or even a charger')...........so a little hotter spark might not hurt, actually might save your engine if you ask me, but hell, what do i know, im still runnin' 13s lol
Bassani O/R X pipe
Bassani Axle Backs
C&L
FRPP 3.73 gears
Hurst Short Throw
Old May 12th, 2008, 04:49 PM   #6
Thanks bro
Oh, hi, Ken.
Old May 12th, 2008, 05:00 PM   #7
I got the accel coils but I had 2 stockers go bad.The MSD coils are the same as stock.The accel are 60,000 v the Granitelli (sp ?) are 60,000 v. I never seen any power gains.
2006 GT Windveil Blue, NX 3v plate kit 125 shot ,C&L CAI,Motoblue Underdrive Pulleys,Bassani X-Pipe,FRPP Axle Back ,Steeda Delete Plates,Accel SuperCoils,Spyder Driveshaft,4.10 Gears,JBA headers
Old May 12th, 2008, 07:10 PM   #8
Grabber523's Avatar
Location: Northwood, ND...yes, hell does freeze over...
The only chance you might have of seeing more power with aftermarket coils is the fact that you can run a wider gap when under boost...I guess it has something to do with a wider flame-front...dunno. For nitrous, you shouldn't have to gap your plugs down (little if any) or increase spark voltage because you're not moving a larger volume of air through the cylinders, just a more oxygen-rich mix. The reason our engines get such bad blowout under boost is because the plugs aren't shrouded very well and the increased velocity of the larger air charge having to get in and out of the engine won't let them light. Shouldn't be an issue with NOS though...
myspace.com/grabber523
2007 Grabber Orange GT Premium 5-Speed, CDC Sequential Taillights, 2.6L Kenne Bell, 3.73 FRPP Gears, Steeda Tri-Ax, Dynotech Alum. D/S, BMR D/S Loop
Old May 12th, 2008, 07:21 PM   #9
BLACJAC's Avatar
2006 GT
13.69
Burned Valves
anytime u run a hotter spark , by way of plugs,coil, spark advancers , etc u have to check with {in our case maybe ford racing tec} to see if a hotter spark will cook the valves????
BORLA STINGERS,AIRAID CAI,3.73 FORDRACING GEARS AND VAST BILLET INT. & EXT. JEWLERYBLACJAC's Profile » MyMustangSite.com
Old May 12th, 2008, 07:23 PM   #10
well if my nitrous isint cooking valves i cant see how a hotter spark will
Oh, hi, Ken.
Old May 12th, 2008, 07:32 PM   #11
Grabber523's Avatar
No. Your spark will not cook valves. Running lean will.
Old May 12th, 2008, 07:44 PM   #12
BLACJAC's Avatar
2006 GT
13.69
lean
how lean are we talking about>?? if our cars get lean enough to do damage we go into limp mode, can we do damage with a lean code light on , but yet not in limp mode??
Old May 12th, 2008, 07:50 PM   #13
Grabber523's Avatar
Originally Posted by BLACJAC View Post
how lean are we talking about>?? Why is my penis is always stuck in limp mode??
Fixed!
Old May 12th, 2008, 07:56 PM   #14
Grabber523's Avatar
The lean comment was a generalization...since our friend Procharger is running Nitrous, and it doesn't take long for damage to occur if the extra fuel is in the mix. But we're getting off the subject....Procharger, if you have a stock coil go bad, might as well upgrade, but to replace stockers just because...that money would be more helpful elsewhere IMO.
Old May 12th, 2008, 09:51 PM   #15
06TYRFRYR's Avatar
06 Mustang GT
10.83 @125.50
I installed msd's on my wifes stock gt as well as mine at the track and hers picked up .07 and mine picked up .09 on the juice. Depends on how serious you are about getting every hp out of your car. there are many other mods that will give you a lot more hp and gain for equal or less dollars, but if all the other mods are done then why not.
Old May 13th, 2008, 11:37 AM   #16
Grabber523's Avatar
That's why I keep looking back to see if I started shitting money yet...no luck...no matter how had I push...
Threads Similar to: Coil on plugs?
Coil On Plugs?? yes or no? silverstang 2005+ 18 April 16th, 2008 04:30 AM
coil on plugs which ones ? greenwood 99-04 20 February 5th, 2008 07:22 PM
Cop's (coil on plugs) for sale. jivepepper For Sale 0 May 14th, 2007 07:19 AM
Aftermarket coil on plugs 1SLO85 99-04 7 January 26th, 2007 11:32 AM
coil, plugs, wires? oh my Orangester V6 Mustangs 20 January 17th, 2007 06:10 PM
