Discussing gears, from the horse's mouth. in the 2005+ Forum. Here the issue has come up a lot so this is what the big boys ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
Authorized Vendor
![]() 2007 GT
Here the issue has come up a lot so this is what the big boys say. Its from MM&FF
>>>Changing the gear ratio in the rearend is one of the biggest bangs for the buck and a time-honored tradition in hot rodding. "Gears are a torque multiplier, and allow the engine to use it and get through the rpm range faster for quicker acceleration," says Tony Gonyon of HP Performance. Typical gear ratios from the factory (2.73, 3.08, 3.27, and 3.31) are designed for a mix of mild performance, miles per gallon, and rpm range at cruising speeds. The new Mustangs are offered with 3.55 gears as an option, but for the most part, the rear gears from the factory aren't optimal for drag racing or the performance we expect out of our cars. Also note, when talking about gear sizing, the lower ratio gears are numerically higher--4.10:1 is a lower ratio than 3.73:1. If you own a 5.0 Mustang, the two most popular gear choices are 3.73s and 4.10s. With 3.90 gears coming to the market in the past few years, that size has become more popular. Automatic-equipped cars will benefit greatly from 4.10 gears because of the greater rate of acceleration. Typically, anything numerically higher than 4.10 reduces driveability, as highway cruising rpm is drastically higher and performance tends to fall off with stock engines' power range. The Two-Valve crowd should go after lower gear sizes such as 3.90s and 4.10s. Justin Burcham of JPC Racing says, "These cars don't have a lot of torque, so they respond well to gears." He also says that with 3.90s or 4.10s, the rpm drop-off on gearshifts is not as severe, and that helps performance. Those enthusiasts with Three-Valve combinations found in '05-up Mustangs should run 4.10 gears, as unanimously selected by Gonyon, Burcham, and Mike Dezotell of Dez Racing. They said that for enthusiasts who don't want something as steep, the 3.90s are sufficient, but nothing numerically smaller works well to warrant the gear swap. The more hard-core drag racers out there should consider 4.30 gears.
Seat of the pants tested. Becuase your @$$ and ears are all that matters. www.radmustangs.com |
2005 Mustang GT
Good stuff, REPS
- WILD Jeff Shrewsberry
Authorized Vendor
![]() 2007 GT
thanks wild man.
I'm still going with 3.73's. Everyone who I talked with that drive GT500's say as you add HP to this car, you will quickly find that the lower gears (4.10's etc) almost become uselss on street tires. So I think 3.73's are a good middle ground because the 3.31's that come on the GT500 suck.
![]() 2008 Shelby GT500 JLT CAI w/SCT Tune, FRPP 3.73 Gears, FRPP KR Short Throw Shifter and KR Handle (Black), FRPP GTA Mufflers, Sequential Tail Lights, SPP 8" Billett Antena, Ceramic Tint, Nitrogen Filled Tires |
Authorized Vendor
![]() 2007 GT
its your choice bro. Traction is an issue for sure. but its an issue either way. I dont get it myself, back in the day guys were pushing 500hp and running 4.10s, 4.30s 4.50s. in push rods that were low end tq monsters and the tires werent as good back then. Throw some drag radials on that car get some 4.10s and HTFO.
May 08 ROTM
2007 Mustang GT
CH53, vouch for the comment whole heartedly within the supercharger world. If my car was a dedicated track car with the ultimate in suspension set up for traction it would be a completely different story. Traction is zero on the street, DR's or not at my power level. It's only fun for so long and then it's old.
#7 | |
May 08 ROTM
2007 Mustang GT
Authorized Vendor
![]() 2007 GT
yea thats true emay. I understand what your saying and agree. But you also know that the myth of cars being a lot heavier back then isnt really that true. 65 stang is lighter then my stang. and dodge had some cars with 400+cubic inch engines that we sold as drag packs so to speak rolling of the lot at 2900lbs. The rambler????
Authorized Vendor
![]() 2007 GT
but no one was getting traction back then.
Any hole is my goal!
2021 Mustang V12
Quad Turbo with nawz
Location: modified88dreamer likes penis in and around his mouth
good article.. i saw that in MM&FF a while back too
![]() 1989 LX 5.0 1990 LX 5.0 1993 LX 2.3 notch 1992 LX 5.0 1997 Cobra Buy one get one free. PM me i founded the founder of the cobra club |
Authorized Vendor
![]() 2007 GT
i can see supecharged guys on the street not doing it. My car will break loose well into second gear, if i stand on it and im making a lot less tq then you guys.
Yea i thought it was a great article. By the way curb weight of a 68 gt with a 390 is 3400 something, lighter then me. no heated power leather seats, computers, airbags, six disc cd changers.
Tomorrow I am supposed to have my 4.10s installed. I am really looking fwd to it.
Authorized Vendor
![]() 2007 GT
you be smiling ear to ear as soon as you roll of the lot. going from wht 3.31s?
3.55s. I am guessing I will need to take it easy for the first 500 miles or so. Easier said then done.
Just had my 4:10's installed a couple of weeks ago and wished I would have done it in 05 when I got the car. I am supercharged and it is a daily driver with 60K miles on it. Like a brand new car.
#16 | |
Authorized Vendor
![]() 2007 GT
Yea you heard the man he wished he would have done it in 05. Thats is the usuall consensus with guys who get 4.10s.
08 Vapor GT
Is there any whine or noise when going with 373 or 410. I was told there was a whine by dealership. They also recommended 373 with my automatic, especially if going with a supercharger.
MM's resident Juice head
07 Mustang GT
I layed into my new 355's right away...now they whine a little but i can live with it...if it gets worse ill have ford replace under warrenty again
![]() The MGW short throw shifter Its not just a shifter...It's a lifestyle! |
#19 | |
Gear break-in
Authorized Vendor
![]() 2007 GT
I dont know man. dont listen to me. I was raised on a philosophy of break it in like ya drive it. I didnt take it easy at all. When i got home that night from getting my gears installed i handed a sti his ass. You search my threads you can see the post of that day and that sti. And I havent stoped smiling yet. got probably 59,000 on my stang now driveing it like i stole it. Not one problem. I have no gear whine. These freaking cars are tough if you ask me. Ask the ford guys I guess, or some techs on this site. But you arent going to tell me that drag racers dont make gear changes the night before they race.
Then again on my 750 gixxer your not suppose to go over 6000rpms for the frist 600 miles. LOL that lasted about 10 miles. Only rule i do respect is when breakin an engine in dont keep it at the same rpm for long periods of time.
Threads Similar to: gears, from the horse's mouth.
| swallow anything in your mouth... | WAR-PARTY | The Clubhouse | 18 | January 20th, 2008 11:09 AM |
| Put Your Tongue Back In Your Mouth | HMUSN | The Clubhouse | 14 | December 25th, 2007 05:10 PM |
| PAINNN my mouth is about to expload! | MustanG_guy17 | The Clubhouse | 46 | October 7th, 2007 07:14 PM |
| OK I'm just a potty mouth ck new avatar | WAR-PARTY | The Clubhouse | 2 | May 16th, 2007 11:04 PM |
| slp loud mouth | miafan | 2005+ | 0 | February 1st, 2007 04:30 PM |
