Go Back   Forums at Modded Mustangs > Mustang Forums > Modular Mustangs > 2005+
Discussing I broke it... in the 2005+ Forum. I guess 70+ runs at the strip with out a problem was pretty good for ...
Old May 23rd, 2008, 08:04 AM   #1
2006greyGT's Avatar
2006 Satin Silver GT
12.039@114.64
I broke it...
I guess 70+ runs at the strip with out a problem was pretty good for the durability aspect of my Stang.
The problem came at 100 mph and shifting into second rather than 4th.. took one more run after that before my lifter/s started taping...
well the reason for this thread is any one with a SC might tell me some things I can do, if any, while they have my blower off and and replace my lifters.
It won't go into the shop till the third so I have ove a week to gather ideas about this... thanks
2.6l KENNE BELL 100% forged bal and blu
Stroked to 298 / Ported and polished heads
Long tube/O/R H / stage 3 clutch
8 rib/65 lb injectors
20" Weld Racing Wheels
meth injection
CDC AGR Spoiler- clear coat bra
D/S rotors / MGW Short Throw
Old May 23rd, 2008, 10:10 AM   #2
Authorized Vendor
07stanggt's Avatar
2007 GT
12.40@114.55
cams
Old May 23rd, 2008, 10:33 AM   #3
May 08 ROTM
Emay's Avatar
2007 Mustang GT
Definately do a set of cams like 07 said.. perfect time..
Old May 23rd, 2008, 11:38 PM   #4
2006greyGT's Avatar
12.039@114.64
what cams would be good with my Kenne Bell?
meth injection
Old May 23rd, 2008, 11:45 PM   #5
05mustang_kb_charged's Avatar
2005 Mustang GT
Dyno Racer
Comp Stage 2 or 3....from 07stang
or BBR Stage 2 Cams
and I hope that all you hurt was the lifters. What RPM did you see when you did that?
A Couple Bolt-Ons and GOOD Air
613 rwhp and 534 rwtq on 15 psi. and 17 degrees of timing
F/I Crew Member #1
KENNE BELL Crew Member #1
Old May 24th, 2008, 12:52 AM   #6
MM Phantom
Onemanzu's Avatar
Location: looking for free hand jobs in poland springs nebraska... silly gooses
sure nothing else fried?? oil pump is okay, bearings, chains all that jazz
Back for brotherly love. My thoughts are with you Bubba!! [9-23-08]
Originally Posted by omz
Old May 24th, 2008, 01:37 AM   #7
2006greyGT's Avatar
12.039@114.64
don't know for sure till they pull it apart... the car runs fine and doesn't make the lifter tap noise till it is warmed up... the oil pressure gauge is fine and I ran a 12.4 wed night before my buds at the strip advised me to stop which I did... I have put about 100 miles on it since the event and besides the noise it runs great... it happened so quick I have no idea how high the rpm's got.. the tires did break loose when I did it but I had the clutch back in very quickly.
Hey 07... how about cams and lifters? PM me a price
meth injection
Old May 24th, 2008, 12:35 PM   #8
07 Grabber GT's Avatar
Lifters??? There aren't any "lifters" in this valve train ... if it only happens when it heats up (and it runs ok) your valve train is probably alright ... though you probably want to change out your valve springs with stronger ones seeing how you are a frequent 1/4 mile driver. There's a chance you damaged a spring an it's throwing your geometry out enough to make lash noise (if that's what you're hearing) when it gets to temp.
"Heating up" noises ususally mean when the oil gets to temp the pressure drops just enough to make a bad or spun bearing noisy. I would suspect a bearing somewhere is not happy with your untimely downshift ...
If you do the cam swap you'll have to custom tune again ... if your cams are undamaged I would leave them alone unless you got the $$$ to spare.
Old May 24th, 2008, 03:20 PM   #9
2006greyGT's Avatar
12.039@114.64
OK ... I am totally confused now... do the cams open the valves? where is this bearing that might be spun?
meth injection
Old May 24th, 2008, 03:36 PM   #10
There's actually 5 bearings each cam rides on ... could be one of those if you are for sure its coming from the top end. Back to the cam discussion, if you hurt the cam along with one of the mentioned bearings ... then it might make sense to do your cam upgrade ... still be sure to at least upgrade your springs.
If you can't tell which side or top from bottom for the sound ... first make sure its not coming from the S/C ... if not then its probably in the bottom end somewhere.
Old May 24th, 2008, 04:00 PM   #11
Authorized Vendor
07stanggt's Avatar
2007 GT
12.40@114.55
just saw this man. How much boost you running? ill pm you the price.
Old May 24th, 2008, 07:17 PM   #12
2006greyGT's Avatar
12.039@114.64
I just put the 3.75" pulley on her and I am told that I should be around 12... as you saw in the thread Grabber enlightened me to the fact that my 4.6 has no lifters... so I will need better springs... I think I might need it apart before I order the parts... what is your turn-around on an order???
meth injection
Old May 24th, 2008, 10:28 PM   #13
Authorized Vendor
07stanggt's Avatar
2007 GT
12.40@114.55
I can have cams quick. I already have a few comp cams in stock. With that kinda of boost are you thinking you want a blower cam? thats not that high but let me check. and im assuming you dont want a real radical cam right. Im mean they have stage 1 and II nsr cam's that will work good with a supercharger and then the blower nsr cams for high boost applications. Then of course you have blower cams in VSR.
Here is the whole line. And they have tons of grinds already as well. we just need to figure out what your looking for outta the cams.
COMP Cams: 4.6L & 5.4L 3 Valve Cams & Kits
Old May 24th, 2008, 10:33 PM   #14
Authorized Vendor
07stanggt's Avatar
2007 GT
12.40@114.55
just the KB for engine mods? what rear you got? manual or auto?
Old May 25th, 2008, 12:49 PM   #15
2005 Mustang GT
Dyno Racer
Negative Ghost Rider, there are 0 cam bearings in a 3v head. The oil that passes through the cam journals actually creates a oil bearing<--Has a thin sheet of oil around cam and aluminum guides on head. As for lifers no you have Hydraulic Lash Adjusters and Cam Followers. The cam follower sits on the bottom of the cam and the top of the hydraulic lash adjuster and valve stem.
F/I Crew Member #1
Old May 25th, 2008, 06:06 PM   #16
Go to the "All Knowing ..." page and find the manuals, pick the left camshaft (right reads the same). Read pg 4 real close ... you'll find the word "bearing" mentioned many times.
What you've described is the purpose of any lubrication system ... bearings are there to keep harder metals from making contact with each other during any type of load or rotation.
Old May 25th, 2008, 06:52 PM   #17
2006greyGT's Avatar
12.039@114.64
I am going to keep my stock lower end for now... I use the car to drag race and cruise on the weekends... I am staying with the sleeper profile so I would need cams that would give me gains with out the rough idle...
meth injection
Old May 25th, 2008, 07:08 PM   #18
Authorized Vendor
07stanggt's Avatar
2007 GT
12.40@114.55
mild cams then. you want more top end or low end? either stage I or stage IIs, you can do VSR or NSR its up to you, changing the springs even though its a mild cam can allow for some higher rpms. I guess you need to find out what is wrong to know. Plus the other benifit to the mild cams is keeping the VCT working, thats good stuff and helps optimize power at all rpms.
Old May 25th, 2008, 08:41 PM   #19
I'd be curious to know what is found as the source of your "ticking" ... certainly worth putting in the knowledge bank.
For the sake of tunability I would stick with a milder cam if you choose to do cams ... get the "blower" version where the exhaust profile is steeper then the intake ... and from what I've read in a few places most shops are charging the same if they do the springs as well or not. Better springs will help keep things in check at the high end of shifting ...
Threads Similar to: I broke it...
broke something mmvi V6 Mustangs 7 October 23rd, 2007 12:21 AM
Broke again..... C MY 4D 5.0 Mustangs 20 July 28th, 2007 07:21 AM
I think i broke something :( Timmano V6 Mustangs 12 June 3rd, 2007 05:10 AM
Broke Something 99mustang232 Feedback Forum 3 November 21st, 2006 03:03 AM
Broke! 97Cobra The Clubhouse 49 October 11th, 2006 12:17 PM
