Go Back   Forums at Modded Mustangs > Mustang Forums > Modular Mustangs > 2005+
Discussing DR'S in the 2005+ Forum. I have 18x 8.5 factory bullits Whats the widest DR i can put on ...
Old June 17th, 2008, 04:19 PM   #1
MM's resident Juice head
07 STROKER's Avatar
07 Mustang GT
DR'S
Whats the widest DR i can put on and keep the original diameter so my speedo is correct?
The MGW short throw shifter
Its not just a shifter...It's a lifestyle!
Old June 17th, 2008, 04:28 PM   #2
tribaltek's Avatar
2005 Mustang GT
13.02@107
Why don't you just reprogram with the revs per mile?
'05 GT, 5spd, Black, JLT, 4.10, FRPP Hot Rod Cams, UDP, MGW, OBX LT & O/R-H, Bassani Race, Prothanes
Blower Installation - This winter (finally!)
Cammed Crew #1
RADMUSTANGS Store
Old June 17th, 2008, 04:37 PM   #3
07 STROKER's Avatar
07 Mustang GT
i want it to look stock as well...as far as sidewalls go ya know?
Old June 17th, 2008, 05:17 PM   #4
Your Mom's Favorite
Grabber523's Avatar
2007 Mustang GT
12.21@111.74 1.789 60'
3782RP 265/40R18 27X10.5 9.0-10.0 26.5
These are from Mickey Thompson...they require a rim width of 9.0-10.0, but have a 27" diameter which is stock OD to keep your speedo and odo accurate and fill your wheel wells properly. Going down 1/2" in wheel width shouldn't pose a problem, but you'd have to confirm that with a tire guru like Jucostud. People are running a 275 width on stock rims with no problems.
www.myspace.com/grabber523
Grammar/Spelling Nazi Club Member
MEMBERS AGAINST MEMBERS AGAINST STUFF CREW FOUNDER
Old June 17th, 2008, 05:19 PM   #5
Blown 03 GT
The side wall wont be exactly the same but no one will know the difference. You shoudl beable to do 285 or 295. I think thats as wide as you can go with a 8.5 in rim
Old June 17th, 2008, 06:07 PM   #6
Stkjock's Avatar
2006 Vert
11.867 @ 119.35
As I recall the MTs are 26.5" in diameter. I have a set waiting to go on the car now.
The 265/40 size works fine. I have BFG 265/40s. But they are shorter then stock by .75". So the speedo is off, unless you change the revs/mi.
here's a shot in action...
06 GT- 4000lb Rowing machine
http://img519.imageshack.us/img519/2285/stkjockqp4.jpg
11.867 @ 119.35 1.799 - 60'
Old June 17th, 2008, 06:09 PM   #7
07 STROKER's Avatar
07 Mustang GT
you still have 235's on the front?
Old June 17th, 2008, 06:11 PM   #8
Stkjock's Avatar
2006 Vert
11.867 @ 119.35
no I went with 255/45s in the rear at first and they didnt hook for crap. I moved them to the front when I got the DRs
Old June 17th, 2008, 06:13 PM   #9
07 STROKER's Avatar
07 Mustang GT
they handle okay on the street?
Old June 17th, 2008, 06:13 PM   #10
Stkjock's Avatar
2006 Vert
11.867 @ 119.35
the DRs? yea fine. but my ride is not a DD. Its in the garage all week and it doesnt see rain
Old June 17th, 2008, 06:14 PM   #11
07 STROKER's Avatar
07 Mustang GT
mine either...no rain that is
Old June 17th, 2008, 06:27 PM   #12
2007 GT
handle ok is a relative term. they handle like shit at high speeds in my opinion. i got 275 40 17 on a 8 inch wide rim. they stick way out. i would think 265s would look almost normal on a 8.5 rim. but like he said they are way shorter then the stock 235 17s that were on my car.
Old June 17th, 2008, 06:33 PM   #13
07 STROKER's Avatar
07 Mustang GT
do they have a size that is the same as my 235's
Old June 17th, 2008, 06:45 PM   #14
2007 GT
height wise? do the math. use u.s math.
Old June 17th, 2008, 06:47 PM   #15
07 STROKER's Avatar
07 Mustang GT
i suck at math.
Old June 17th, 2008, 06:47 PM   #16
2007 GT
i dont think the mickeys do, look at nittos. im wondering what size that guy i run with all them has on his rims becuase he has 18s i think and they look kinda normal on there. not that wide like the mickeys though
Old June 17th, 2008, 06:49 PM   #17
07 STROKER's Avatar
07 Mustang GT
not too concerned about width as much as getting the diameter rite...as long as i get a big enough contact patch to hook up
Old June 17th, 2008, 06:51 PM   #18
2007 GT
what is the stock diameter of or wheels 28inches?
Old June 17th, 2008, 06:52 PM   #19
07 STROKER's Avatar
07 Mustang GT
i believe so.
Old June 17th, 2008, 06:59 PM   #20
2007 GT
nitto doesnt have anything on there website that they recomend for a 18X8.5. a couple that would fit im sure but the height is 25.91 so its shorter. thats a 275 i think.
Threads Similar to: DR'S
New DR's some shots. Emay 2005+ 65 June 8th, 2008 12:39 PM
DR's on stock rims 00gtCoolGuy 99-04 5 May 20th, 2008 03:50 PM
275/40/17 nitto dr's johnr2001 Wheels/Tires 12 May 6th, 2008 01:17 PM
dr's width qwik48r 2005+ 6 April 16th, 2008 10:55 AM
New best with MT DR's jivepepper 99-04 11 June 8th, 2007 07:01 PM
