Go Back   Forums at Modded Mustangs > Mustang Forums > Modular Mustangs > 2005+
Discussing Which Turbo for 2008 in the 2005+ Forum. I got a 2008 mustang gt im looking to Turbo it what are poeples suggestions ...
Old June 25th, 2008, 11:00 AM   #1
2008 Mustang GT
I got a 2008 mustang gt im looking to Turbo it what are poeples suggestions from poeple actaully know what there talking about.... i Was loooking at STS Twin Turbo system and poeple are sayin its shit....what you guys think
Old June 25th, 2008, 11:05 AM   #2
tribaltek's Avatar
2005 Mustang GT
13.02@107
I hear good things about the Hellion. Brenspeed sells it
'05 GT, 5spd, Black, JLT, 93 Race, 4.10's, FRPP Hot Rod Cams, UDP, MGW, OBX LT's & O/R-H, Bassani Race, Prothanes, HIDs, 18" Bullits, SHR Louvers, Black Billet Grille, GT500 Spoiler, Seq. Tails
Cammed Crew #1
RADMUSTANGS Store
Old June 25th, 2008, 11:25 AM   #3
usafimj's Avatar
2007 Ford Mustang GT
13.491 @ 106.19mph
+1 on the Hellion kit brenspeed sells. It comes with everything you need.
JLT, Hurst, 4.10s, Stage II NSR Cams, Kooks LT w/ H pipe, Stingers, Black FR500 rims, BMR (Lowering Springs, Adj Panhard Bar, LCA w/ brackets), Tokico shocks/struts
Hurst Crew Member #13
Cammed Crew
Military Crew
E-5
Old June 25th, 2008, 11:31 AM   #4
MaverickMLFD371's Avatar
2005
12.3 @ 115
not a big fan of Turbo's, but from what I've read on other forums the 2 good turbo kits seem to be.
1. Hellion
2. Powerhouse
Old June 25th, 2008, 11:40 AM   #5
2008 Mustang GT
single or twin
does a bigger single put out more than a twin turbo?
Old June 25th, 2008, 11:52 AM   #6
tribaltek's Avatar
2005 Mustang GT
13.02@107
Twin seems hard to beat, but then again, are you running a stock block and stock internals? If so, the single would be more than enough.
Cammed Crew #1
RADMUSTANGS Store
Old June 25th, 2008, 12:21 PM   #7
forensicsteve's Avatar
10.3 1/4 ET
I have a Powerhouse turbo. Hellion no doubt is a good product but several posters (on other forums) complain about ground clearance issues. That made me shy away.
I don't know much about car mechanics and that includes difference between single and twin turbos. Certainly "twin turbo" may roll off the tongue better than just "turbo" and make for a better decal or emblem. I'm very happy with my single 76mm. On what I would call an almost timid tune (very low timing), it produced 680 rwhp/735 rwtq at 20 lbs of boost. The 76m is capable of about 1100 hp at about 28 lbs of boost. I will definitely seek a more aggressive tune in late September (when the extreme heat/humidity starts to decline). Would like to go up to 25 lbs of boost also. Then just added a 200 shot wet nitrous system to help with present temps/humidity. So there's plenty of potential from a good size single turbo. I went from a 67mm to a 76mm...so if around 1200 hp is not enough...I'll get the 88mm single...lol
06GT, PH 76mm turbo, MMR 5.0 stroker, turbo cams/heads, FB Perf 3 speed 4r70w, 9" rear, GT500 pumps, 2 single KB BAPs
6.5 @ 105 -1/8, 50 shot
10.31 @ 124 -1/4, 50 shot, lifted
6.6 @ 103 - 1/8 & 10.42 @ 129.98 - 1/4 (no nitrous)
Old June 26th, 2008, 12:09 AM   #8
2008 Mustang GT
how do u run 20lbs of boost wont u Blow your engine poeple say 8 MAX
Old June 26th, 2008, 12:12 AM   #9
usafimj's Avatar
13.491 @ 106.19mph
he has a built motor
Cammed Crew
Military Crew
E-5
Old June 26th, 2008, 05:49 AM   #10
10.3 1/4 ET
Probably should put more info in my sig
Motor
MMR 5L stroker 950 (rated at 950 rwhp)
MMR stage II heads and cams
Transmission
FB Performance Racing Transmission, 4r70w (rated at 1200+ hp)
Automatic with full manual valve body and transbrake. 3 speed forward shift pattern
Rearend
Currie 9 inch with trutrak, 4:10 gears
Fuel
GT500 dual pumps, 2 GT40 pumps (piggybacked), 2 single Kenne Belle baps, Kenne Bell boost a spark, 60 lb injectors, big rails and lines
1st Power Adder
Powerhouse 76mm single turbo
2nd Power Adder
200 wet nitrous (Nitrous Express), not quite hooked up yet
Old June 26th, 2008, 12:14 PM   #11
2008 Mustang GT
ok wow lol thats alot of mods man sooo you seem to know what ur talking about....Where the HELL do i start with a turbo....first off to u suggest a twin or single which is better? and if i do go with the single turbo and go bigger than 76mm like mayb a 90+......wont i look at space issues?
Old June 26th, 2008, 01:47 PM   #12
leebunnyz's Avatar
if your not building your engine you dont even need 76mm, i would stay at like 67mm.
Not stock
RADMUSTANGS
Jesus Christ is #1
Hurst Crew member #1 of 21
"The Founder Of Crews"
Old June 26th, 2008, 02:03 PM   #13
10.3 1/4 ET
Actually I consider myself a newbie. My only experience with this kind of stuff is watching people like Lance build the car and also drive it at the track. I can only report my experiences with this one vehicle. Not qualified to offer really technical advice.
That's really a good point because a turbo setup is a little tricky...you don't want one too small or too large for your application. Seems like, larger the turbo...larger the moving parts to get moving...potential for lag. Certainly noticed some lag between the 67mm and 76mm. In our case, other mods like transbrake, address the lag factor.
I would give Mike Bowen a call at Powerhouse (Powerhouse411.com). He's very good at discussing personal needs/goals and providing options. I started talking to him months before I spent any money with him. You can mention steven/lance from south Louisiana. His base 67mm really is ample for most folk. I upgraded from the 67 to a 76.
Threads Similar to: Which Turbo for 2008
Turbo timers and Boost Controllers? Turbo guys where you at? 95StangSVT Poweradders 14 July 11th, 2008 07:01 AM
FS 2008 Turbo Mustang GT ChrisJ For Sale 17 December 14th, 2007 08:27 PM
Turbo HorsePower Twin Turbo kit dblindberg 2005+ 34 June 17th, 2007 08:05 PM
Mellon's Twin Turbo Stealth vs Wills99z's Single Turbo z28 Mellon Videos 10 December 30th, 2006 10:05 AM
Super Charger vs Turbo/Twin Turbo: Pros and Cons of each FireryDriver 2005+ 9 September 17th, 2006 04:15 PM
