Go Back   Forums at Modded Mustangs > Mustang Forums > Modular Mustangs > 2005+
Discussing New Door Speaker -- Installation in the 2005+ Forum. Ok, Im sure that I am not the only person that owns a 05+ pony... ...
Old June 26th, 2008, 11:21 PM   #1
Audio_Orphan's Avatar
2008 427R Roush 08-319
Exclamation
Ok, Im sure that I am not the only person that owns a 05+ pony... This is my 4th Mustang, had two fox bodies, 1 SN 95, now a 2006 GT..... I have always upgraded my stereo
Now, I have googled that hell out of the Shaker 500 system ..... I got the schematics.... but I don't know if my car has an amp, if so... where is it?
Also, anyone know either (a) how to run wire from the car thru that little rubber tunnel [i know its not a tunnel] to the door or (b) what colors are the wires that I am looking for to hook up my new component speakers in the doors... (c) run it from my HU harness.... [I got a AVH-6800DVD HU]
I have installed the 1" tweets in the A pillers and I want to install the 5 1/4 in place of the 5 x 7.....
Any help would be great......
Old June 26th, 2008, 11:29 PM   #2
tribaltek's Avatar
2005 Mustang GT
13.02@107
Your car does have an amp for the subs... I just forgot where the hell it is.
'05 GT, 5spd, Black, JLT, 93 Race, 4.10's, FRPP Hot Rod Cams, UDP, MGW, OBX LT's & O/R-H, Bassani Race, Prothanes, HIDs, 18" Bullits, SHR Louvers, Black Billet Grille, GT500 Spoiler, Seq. Tails
Cammed Crew #1
RADMUSTANGS Store
Old June 27th, 2008, 12:26 AM   #3
scramblr's Avatar
2006 Mustang GT
12.4@111
There's quite a few write up's with pics over at TMS on this.
12.4 @ 111mph
Saleen S/C, 8 Rib, Kooks, Stingers, Spyder DS, Spec 3+, Spec Stl f/w, Pro 5.0, Ultralite Springs, D-Specs, Prothane Mounts, BMR - Adj. Panhard Bar, LCAs, LCA Relo Brackets, Adj. UCA, Rear Sway, Sway Delete/Rad Support
My Gallery
Old June 27th, 2008, 01:18 AM   #4
Captain Of Team Leg Hump
06RedfireGT's Avatar
2006 Mustang GT
In the 13's
You shouldn't have to run new speaker wire from the headunit. I believe that they are on the top of the driver side footwell. This is what they look like.
Bassani Crew Member #1
Better to be judged by 12 then carried by six.
Old June 29th, 2008, 10:46 AM   #5
I wasn't going to run new wire from the head unit, i got a 4 channel amp in the trunk.... I will post pix [hopefully today] when i get done installing my system.
I appricate the input guys, now if anyone knows where this amp is, that Tribaltek spoke of, so I can unhook it... that would prolly solve my audio problems
Old June 29th, 2008, 02:42 PM   #6
2008 Mustang GT
TBD
On the subject of speakers. I have the shaker 500 stero and wanted to upgrade to the shaker 1000. I have found the amp and sub on line. Do I have to change the head unit or does it just plug into the back of what I have?
Old June 29th, 2008, 07:23 PM   #7
scramblr's Avatar
2006 Mustang GT
12.4@111
With all the problems the Shaker's have, you may want to consider just going aftermarket.
12.4 @ 111mph
My Gallery
Old June 29th, 2008, 08:48 PM   #8
02' and 08' Mustang GT
What problems?
Old June 29th, 2008, 10:56 PM   #9
aleykat271's Avatar
2008 GT 5Spd
13.7 102.39
There's a TSB 07-17-06....Vibrations in the driver's side speaker,that makes it sound like it's blown.They add foam strips.Had the TSB done,but made it worse,finally thanks to a sharp eyed Tech the problem is fixed....
"Drive it like you stole it"
Old June 29th, 2008, 11:06 PM   #10
1BADSTANG's Avatar
The shaker 500 is fine for someone who doesn't go crazy with music, for someone who does (me), it is definitely time to rip the headunit out, the front speakers, and the 8 inch subs in the doors. Do this, Put a 6.5 component system in the front, amp them with something nice (we all like around 125-150rms, gets nice and loud) get another amp for two rear 8 or ten inch subs (add them to the rear) And get a new headunit, and use the headunit for the stock rear speakers.
331s burn oil and have a bad piston to head ratio.
http://www.StreetChallenge3D.com/sig...?referal=1BAD1
LOL @ THIS http://www.ihateyoujulia.com/?id=0a8...27aa2c6245e4c2
Old June 29th, 2008, 11:16 PM   #11
2006 Mustang GT
In the 13's
I have the Shaker 1000, and it is a great system, but if I could do it over again I would just go aftermarket. You could get more for less.
Old June 30th, 2008, 12:01 AM   #12
usafimj's Avatar
2007 Ford Mustang GT
13.491 @ 106.19mph
I got the shaker 1000 and I like it. Never go over half the volume. Gets crazy loud after that
JLT, Hurst, 4.10s, Stage II NSR Cams, Kooks LT w/ H pipe, Stingers, Black FR500 rims, BMR (Lowering Springs, Adj Panhard Bar, LCA w/ brackets), Tokico shocks/struts
Hurst Crew Member #13
Cammed Crew
Military Crew
E-5
Old June 30th, 2008, 02:39 AM   #13
2007 GT
On my '07, the amps are on mounted to the side of the driver footwell, on the outside wall. Right up above the pedals and steering column... makes it hell to work around. The picture posted above is exactly what mine look like. If you look on the left side of that picture, you can see the hood release... that should tell you exactly where they are. Definitely bypass these amps, but take this into consideration. If you are keeping the stock head unit, all the speakers are run through a crossover so only the deep notes go to the subs, and only mids and highs go to the regular speakers. As long as you don't try to stick components where the subs are and use the stock wiring, you should be fine.
Old June 30th, 2008, 02:42 AM   #14
2006 Mustang GT Auto
14.778@94.74
the amps are on the drivers side. They are on the side with the clutch Just look under there and you'll see them.
Old July 2nd, 2008, 09:10 PM   #15
Alright.... This is what I have done so far... I left the stock shaker 500 speakers in the doors and back baffle... I got a Kenwood 4 channel running my component speakers [only have small tweets in right now, A-Pillar install] the I have one 3000w Kenwood 12" sub ran by a 1800w amp... I have a Pioneer AVH-6800DVD head unit.... It sounds good, may leave it like that... 11 speakers... I can't even put it past 10 on the deck
Threads Similar to: New Door Speaker -- Installation
anyone using these speaker? vfast The Clubhouse 0 May 17th, 2008 06:05 PM
Driver door lock is stuck. Can't open door Help!!!! White 89 5.0 Mustangs 9 February 28th, 2008 12:47 PM
Fix your 94-98 door speaker rattle justinsstang V6 Mustangs 9 January 29th, 2008 02:53 PM
06 stang door speaker... Ware Electronics 1 June 26th, 2007 10:48 AM
Speaker help Destang V6 Mustangs 4 February 6th, 2007 09:30 PM
