Discussing Someone has got to know.... in the 2005+ Forum. Well guys, I just bought a motorcycle so I can keep miles off Barricade and ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
Authorized Vendor
Someone has got to know....I have heard that these cars do not need a fuel pump upgrade until a 150 shot. Any thoughts on this? I am going to run the jets close to the throttle body because I want the nitrous to hit hard . I plan on using a bottle warmer. I want to use a button to activate the nitrous, not half throttle initiation. What does a window switch do? How does it operate? Nitrous is one of the few things I don't know much about on these cars. Basically, I need someone to educate me on nitrous setups, not how it works. Any input is appreciated!!! PS- Rstrick was very nice to answer my questions and I appreciate all his help on this matter thus far
![]() 13.7@103 300rwhp 316rwtq 3710 lbs full street trim with street tires 92 degrees 90% humidity i had a bag of WIN for lunch. did you? Last edited by Mickey@HardcoreMustangs : July 17th, 2008 at 01:34 PM. |
#2 | |
Chuck Norris of Mods
2006 Mustang GT
In the 13's
You shouldn't need an fuel upgrades on the stock motor. I am going to run the jets close to the throttle body because I want the nitrous to hit hard . I plan on using a bottle warmer. I want to use a button to activate the nitrous, not half throttle initiation. The best way to do it is through a WOT switch. That is the safest way. What does a window switch do? How does it operate? A window switch will spray the nitrous from a pre-programed RPM range. It is typically 3000-5800. You don't want to spray below 3000rpm, and it will stop at 5800 so you can shift safely. The Nytrex Triple Threat Kit is the best kit for the S197s IMO. It is a more complete kit than the rest.
![]() Bassani Crew Member #1 Sign up at Modded AutosBetter to be judged by 12 then carried by six. McCain/Palin 08!
Authorized Vendor
rstrick told me that kit was good as well. I have heard that the Zex kits are more complete with a fuel shutoff, etc...any thought?
Ok, I understand what a window switch does now. But, what is the best way to actually spray? Botton?
![]() 13.7@103 300rwhp 316rwtq 3710 lbs full street trim with street tires 92 degrees 90% humidity i had a bag of WIN for lunch. did you? |
#4 | |
2006 Mustang GT
In the 13's
The best way to actually activate the nitrous is with a WOT switch. You floor it and it sprays. A WOT switch is more consistent. That is the way everybody does it.
Authorized Vendor
hmm. ok well I want to be able to floor my car without activating the nitrous...possible?
2007 Mustang GT
Mickey of hardcore going to school, isn't hardcore payin the bills so you can just play Barricade all day???
All kidding aside, you didn't really state what window switches you were thinking about. There's a few of them out there now and there's a few variances with each. You no longer need to run a button in these cars, there are window switches that also read WOT voltage now, I run one on my intercooler sprayer now and it does all the work for me. Because it is only an intercooler sprayer I run my RPM from 2500 to 6000 as it can't affect traction not being pushed into the motor. You can also get window switches with both of those features plus gear engagement parameters. Instead of the window switch coming on at 3000rpm in all gears, you lock out first and it only fires for 2,3 and 4. On a 5 speed it just ignores the first cycle of RPM reading from 3000 to 6000 and engages the first time the rpm level your to the redline input and comes below. |
Authorized Vendor
I actually "retired" from HCM so I could concentrate on my studies more.
Thanks for the input. I DO want to bypass first and do not want to spray in that gear if possible. With that, what switch should I get? I am just not understanding what I do to operate the spray
2007 Mustang GT
I'll get you some part number and manufacturer info..
Typically to operate the spray with the above wot window switch, you want a purge of course to get a good solid initial hit and a nitrous armed switch for turn on.. The window switch does everything else for you, you just mash the gas. |
2005 Mustang GT
13.02@107
This thread should school me a bit in case I take the plunge (still trying to hold off until next year though).
Mickey - How old are you anyways?
'05 GT, 5spd, Black, JLT, 93 Race, 4.10's, FRPP Hot Rod Cams, UDP, MGW, OBX LT's & O/R-H, Bassani Race, Prothanes, HIDs, 18" Bullits, SHR Louvers, Black Billet Grille, GT500 Spoiler, Seq. Tails Cammed Crew #1 RADMUSTANGS Store
#10 | |
Authorized Vendor
![]() Erin, that would be much appreciated!
2021 Mustang V12
Quad Turbo with nawz
Location: modified88dreamer likes penis in and around his mouth
just don't arm the nitrous.
slow car club - crew member 1 of 9 join www.moddedautos.com i had my bowl of WIN for breakfast. did you? |
2007 Mustang GT
Cheapest and easiest one to use, simple hook up, WOT detection, RPM activation.. end all answer to you being only a pedal masher:
Nitrous Outlet Product Details - Brand X Single Stage Window Switch Dual stage of the above witha multi gear lock out: Nitrous Outlet Product Details - Nitrous Outlet Digital Dual Window Switch |
#13 | |
2006 Mustang GT
In the 13's
Yes, your car behaves just like it would without nitrous until you arm the system.
Authorized Vendor
Ok, starting to make sense. I really appreciate the help gents.
2005 Mustang GT
13.02@107
#16 | |
Nowhere to be found
Well, guys its been real and its been fun, but it hasn't been real fun for me the past 3 months. Money has been tight and need to cancel my cable service to save what I can. I hope to chat with ya'll in 6-7 months from now. Bye!
Authorized Vendor
I thought you would be closer. I am 19
2007 Mustang GT
Youngin
Authorized Vendor
Yes I am. I like it better when people don't know my age because they treat you the same.
2005 Mustang GT
13.02@107
19? Holy crap! Before you told me you were going to school a few days ago I thought you were in your 30's!
How in the hell do you afford the barricade at 19? At 19 I had a 1988 Chevy Beretta with a bad trans and blown out interior ![]() Anyways... congrats on having a bad ass car so young. And good luck with school!
