Go Back   Forums at Modded Mustangs > Mustang Forums > Modular Mustangs > 2005+
Discussing for anyone as dumb as me. in the 2005+ Forum. if your only able to cut 1.8 60 ft times. and you usually run ...
Old July 19th, 2008, 12:08 AM   #1
Authorized Vendor
07stanggt's Avatar
if your only able to cut 1.8 60 ft times. and you usually run with a 1/2 tank of gas or more, your spare, and a bunch of whatever other junk in trunk. its probably not going to help to take your spare and everything else out of your trunk and run on basically an empy tank. nothing but 2.0 60s tonight sideways to 3rd baby. still won seven outta seven races though. with 4 13.0s and three 12.90s. hot as hell tonight and still couldnt hook at all.
Old July 19th, 2008, 12:28 AM   #2
Jucostud's Avatar
2007 Mustang
If i'm pulling 2.1's with 20in street tires, than how are you getting that bad with dr's?
GT500 Spoiler Club
Join the club and get your painted spoiler shipped for $120!
Old July 19th, 2008, 12:55 AM   #3
Authorized Vendor
07stanggt's Avatar
I have ask the question myself to racers, i guess i suck man. remember though i can cut 2.0s and 2.1s on my nitto street tires as well just takeing off from idle, actually on a 60 degree day, i got a 1.97 on street tires going off idle. but i need to slip the clutch better on those 3000+ launchs. im putting over 300plbs of tq down at that rpm.
I can tell you this much, i might not spend the money on another set of 275 17 mickeys, i think the sidewall is to short, i need some 16 inch rims and a taller mickey for next year.
Old July 19th, 2008, 01:00 AM   #4
Jucostud's Avatar
2007 Mustang
I was thinking about going with the 275/40/17 nitto dr's. I figured the shorter tire would make up for my 3.55's.
GT500 Spoiler Club
Old July 19th, 2008, 01:20 AM   #5
Authorized Vendor
07stanggt's Avatar
dont know what to tell you. Im trying more sidewall for more grip next year. i'll work on my foot work for the rest of this year. my clutch also has a lot of miles and raceing on it maybe thats not in the best shape either. consider a taller tire. I like the mickeys, they hook until they dont though, at 3000 i dead hook and bog to much, that cost tenths right there, and at higher rpms i spin to much, cant find the right spot. I know one thing, i need to be in higher rpms from the jump to run better times. this motor is all top end.
Old July 19th, 2008, 05:49 AM   #6
psycho bob's Avatar
07 MUSTANG GT
12.86@104
juco, i know i said it in your thread, but don't get the nitto's since they won't be your street tire. get some real tires for the track. some et streets, hoosiers, or m&h drag tires. just getting a dr for your 17's is going to be a waste especially the nitto's.
JLT CAI, SCT Tuner, Eibach Pro Kit, D-specs, BMR LCA's, Adj. Panhard bar&support, Tri Axe w/ pistol grip, FRPP X-pipe, SLP loudmouths, Konig Beyond w/ BFG KDW's, MT ET Streets
on order: GT/CS bumper, BMR shaft loops, black grill upper and lower.
Old July 19th, 2008, 06:31 AM   #7
2006greyGT's Avatar
2006 Satin Silver GT
12.039@114.64
not only stickies but 300+ size wise... I have 275's and they are way too small and they look funny on the car too... I am only worried that if I get it to hook I am going to twist something and need more mods... I should be around 550 rwhp when and if I ever get my car back from the shop
2.6l KENNE BELL Crew Member #2
20" Weld Racing Wheels
Magnaflow Mufflers w/Hi-Flo cats w/X pipe
Lowered 2" - Hood strut kit
CDC AGR Spoiler- clear coat bra
D/S rotors
Kenwood Excelon Touch..DVD/XM/GPS
MGW Short Throw Crew Member #???
Old July 19th, 2008, 09:14 AM   #8
tribaltek's Avatar
2005 Mustang GT
13.02@107
Just got with 15's man. WAY more out there for a 15" wheel. That's what I'll end up doing later next season.
'05 GT, 5spd, Black, JLT, 93 Race, 4.10's, FRPP Hot Rod Cams, UDP, MGW, OBX LT's & O/R-H, Bassani Race, Prothanes, HIDs, 18" Bullits, SHR Louvers, Black Billet Grille, GT500 Spoiler, Seq. Tails
Cammed Crew #1
RADMUSTANGS Store
Old July 19th, 2008, 10:11 AM   #9
psycho bob's Avatar
07 MUSTANG GT
12.86@104
yeah the only reason i went with the 16"er's is because i got them free from my sister when i gave her my stock 18's. she has a V6. if i had to buy some wheels for stickies i would've just saved up for the 15's
Old July 19th, 2008, 06:22 PM   #10
RStrick0352's Avatar
2007 Mustang GT
12.49 @ 105.67
Do you have and adjustable UCA? If so try putting a little negative pinion mayber 2 turns or so. Your pinion angle is huge in affecting your short times. Just be careful though these cars are really sensitive though and if you put too much you'll get a terrible driveline noise cuz the geometry is all out of whack. I took like 2 turns out of mine and it dropped me from a 1.6 to a 1.8 so literally like 4 degrees and a 2 10ths drop in 60 foot.
GT 5sp Grabber Orange
For mods check my garage.
357 rwhp, 339 rwtrq Naturally Aspirated
439 rwhp, 465 rwtrq 100 Shot
Times are still from N/A unfortunately and before the cams
60ft: 1.6849
1/4: 12.4969@105.67
Old July 19th, 2008, 07:40 PM   #11
Chuck Norris of Mods
06RedfireGT's Avatar
2006 Mustang GT
In the 13's
You definetly need to hook up with some subframe connectors and other chassis stiffeners. With that amount of power it wil be easy to twist something, especially with a vert.
Bassani Crew Member #1
Sign up at Modded Autos
Better to be judged by 12 then carried by six.
Originally Posted by 97Cobra View Post
if you dont want the mods coming at you dont do somthing to deserve it.
Old July 19th, 2008, 09:15 PM   #12
2008 GT
Doesn't Hoosier make some QTP's in the size we need? I loved my QTP's on my Lightning - if they can handle that much torque, I think they may be great for the Stang.
Fuel Altereds Rule The Earth
Old July 19th, 2008, 09:53 PM   #13
drgnracin72's Avatar
2000 mustang GT
11.79@125
on my old 97 cobra that was blown, i cut 1.48 on 17 inch cobra r with 275 m/t drag radials. so man its not the tire, just the driver
if i had a cobra R, i'd take out the vents and put little miniature fish tanks in their places and fill them with sea monkeys
Old July 19th, 2008, 09:56 PM   #14
2000 mustang GT
11.79@125
unless your making more than 450 or so hp, a 28 inch tall tire is gonna be way to tall for anthing under a 4.10 gear ratio, id suggest sticking with the 26 inch tire and maybe going to a smaller wheel to get the more sidewall, but even then, the drag radials arent going to be flexing in the sidewall area.
Old July 19th, 2008, 09:58 PM   #15
2000 mustang GT
11.79@125
i say bs, the nittos are all in the way you use them. ive cut 1.71 60 foot times on them on a 17 inch tire, and ran 12.01@111 on 305 rwhp in my current car. they can hook well, but youve got to run them at around 15 psi aand burn them good, probably 10 seconds longer than you think you need to. plus they last longer as a street tire. i was launching at 6000 with nittos and dead hooking
Old July 19th, 2008, 11:45 PM   #16
Authorized Vendor
07stanggt's Avatar
Since you called me a bad driver i'll throw some shit back your way if you were launching at 6000rpms.... dead hooking and only cutting a 1.71 60 something was wrong.
Old July 19th, 2008, 11:48 PM   #17
black05stxjt's Avatar
2005 GT
12.79@106.89
i launched a 5000 and dead hooked on MT and i only cut a 1.80 but i dont have gears and thats going to be my next mod.
C&L Racer Intake, BAMA 93 Race Tune,OBX LT Headers O/R H,Magna Packs, GMS Sway bar delete,BMR LCA Steeda UDP,MGW Shifter, Strange Shocks, M/T 275/40/17 for track.
New times to come!
12.79@106.89
13.07@107.17 on STREET TIRES
Old July 20th, 2008, 12:21 AM   #18
2000 mustang GT
11.79@125
that was with only 305 rwhp, but since im a bad driver, howd i run a 12.01@111 n/a with a 2v? just wondering lol
Old July 20th, 2008, 12:48 AM   #19
2000 mustang GT
11.79@125
oh and when it dead hooked, it bogged!!!!! my car has been a best of 1.51 60 foot
Old July 20th, 2008, 05:26 AM   #20
psycho bob's Avatar
07 MUSTANG GT
12.86@104
if the nitto's were going to be his street tires then absolutely, but they aren't. they are going to be strictly for the track so what's the point. he's putting them on his stocker 17's. why not get some real tires and not even have to think about it. with only a couple trips to the track a month you're not going to wear them out that fast. they'd last at least a couple seasons. now if he were getting some for his 20's then of course then i would say get the nitto's (other than nitto's i think are the only one's that make 20" dr's right now).
Threads Similar to: for anyone as dumb as me.
Dumb Dumb Question on my part. mustangmanic The Clubhouse 53 July 3rd, 2008 12:57 AM
I feel dumb cbrown 99-04 6 April 16th, 2008 05:40 PM
Dumb Question. RAGEman 99-04 18 April 1st, 2008 12:54 AM
dumb question zmaier 96-98 22 February 27th, 2008 03:24 PM
dumb question sb2f5marine69 5.0 Mustangs 1 March 2nd, 2007 11:43 PM
