Discussing octane mixing in the 2005+ Forum. How many liters of c-14 race fuel would it take to turn a full ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
MM's resident Juice head
07 Mustang GT
octane mixing
How many liters of c-14 race fuel would it take to turn a full tank of 92 into 94 octane?
![]() The MGW short throw shifter Its not just a shifter...It's a lifestyle! |
May 08 ROTM
2007 Mustang GT
I don't recall the ratio in C-14 of iso-octane and heptang.
I know 92 is listed as 92 octane because it is 92% isooctane and 8% heptane. Having the exact number of gallons, and finding out exactly how much isooctane is present in c-14, you should be able to come to the required amount to add via simple mathmatics.. Now the search begins for c-14's chemical back bone..
May 08 ROTM
2007 Mustang GT
Also, are you using c-14 or c-14 plus, there's a point difference in motor octane rating..
how many gallons is your tank?
here is C-14 and C-14 plus in a nutshell
http://www.vpracingfuels.com/pdf/Lea...ish%20(US).pdf and http://www.vpracingfuels.com/pdf/Lea...ish%20(US).pdf |
2007 GT
How much leaded fuel does it take to ruin the cats? If trying to jump from 92 to 94 rating why not use a non-leaded octane booster ... NOS or whatever reputable brand out there?
May 08 ROTM
2007 Mustang GT
That means toulene is rated equally based on Hmusn's findings, and the math there is known to be 10% of your total volume in order to raise your octane rating to 94. So if it's truly full, 1.6 gallons of c-14 will bump you..
^ yep
07 Mustang GT
WOW thanks guys! all this while i slept...let the repping begin...and its just c-14, 5 gallons should safice for the summer.
07 Mustang GT
now i have to convert to liters ....canada
no problem.
gallons to liters is simple enough. |
Threads Similar to: octane mixing
| Mixing Oil | hellbred07 | 2005+ | 7 | July 11th, 2008 05:51 PM |
| Mixing rocket fuel and making atom bombs | WAR-PARTY | The Clubhouse | 8 | March 17th, 2008 06:51 PM |
| mixing gas | mu5t4ng | 96-98 | 6 | January 6th, 2007 01:34 AM |
| Which Octane? | bostonbands | 2005+ | 4 | December 2nd, 2006 11:05 PM |
| Mixing Rocker Ratios In One Motor | Zak | 5.0 Mustangs | 2 | October 26th, 2006 01:37 PM |
