Discussing Slotted and Drilled Rotors in the 2005+ Forum. Anyone put these ony your GT for looks? If so, what kind. Also, if you ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
Slotted and Drilled RotorsIf so, what kind. Also, if you put rotors on do you need to put new pads on also? |
I would certainly recommend the pads changed if nothing else!
There are several reputable big brake kit mfr's for us. Baer, Brembo, (They are on the gt500, you can get the cobra brake upgrade from FRPP at a decent price now. Some dealerships are starting to stock this upgrade too. They are just heavier.) Stoptech Wilwood - Cream of the crop imo, I'm saving for their six piston big brake kit personally. By no means is this list meant to be exhaustive.
1999 Ford Mustang V6
the one thing you want to watch for if you buy a c/d rotor is drilling near the outter edge of the rotor. the several c/d rotor setups i have seen crack were at this point, and were either from diy cross drilling or mfg's who cross drilled oem cores. however, you won't see this from any of the aboved mentioned vendors. if you do choose to piece together your brake setup and keep the original calipers, and not buy a kit, make sure you research the rotor mfg's suggestions on what type of pads to use. i ran c/d rotors on my mustang at autox several times and found that my setup actually worked better the warmer i got the rotors, with no worries in wet conditions. i could also tell and audible difference in brakeing noise though.
...even fire and single cammin |
Threads Similar to: Slotted and Drilled Rotors
| Slotted vs Drilled | TheBusher | 99-04 | 23 | November 13th, 2007 12:08 AM |
| new rotors.... | 01silversnake | 99-04 | 15 | October 9th, 2007 04:18 PM |
| Wher can i get resonable sloted an drilled rotors and brakes | blown96stang | V6 Mustangs | 15 | June 2nd, 2007 03:09 AM |
| Front and rear slotted and cross drilled rotors for '96-'98 | starman1950 | For Sale | 0 | January 17th, 2007 12:54 AM |
| rotors | droppedbass87 | 96-98 | 5 | December 18th, 2006 08:33 AM |
