Discussing Anyone running a Steeda CAI? in the 2005+ Forum. Anyone running one of these on their 05+ mustangs?? Reason for asking is I picked ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
2007 MUSTANG GT
286.2RWHP & 285.RWTQ
Reason for asking is I picked up a Steeda CAI for 100.00 shipped. I still need a tune (75.00) & the inlet elbow 99.00 - 199.00 ( I know I could use the stock inlet tube but think that would be half assed..
![]() HURST SHORT THROW SHIFTER,SLP LOUD MOUTH AXLE BACK EXAUST,GT-500 PEDAL COVERS,CAM COVERS PAINTED TO MATCH,FORD PONY GRILL,REAR PONY BADGE,K&N AIR FILTER //RAZZI QUARTER WINDOW LOUVERS,STEEDA UNDERDRIVE PULLIES. BRENSPEED TUNE |
2007 MUSTANG GT
It was a spur of the moment purchase. Those sell for 250.00 + shipping. Now I am doing some investigateing before purchacing the rest of the set up.
Captain Of Team Leg Hump
2006 Mustang GT
In the 13's
Do you have a tuner already?
![]() Bassani Crew Member #1 Better to be judged by 12 then carried by six. |
2007 MUSTANG GT
Authorized Vendor
2007 GT
12.40@114.55
First of all dont regret your purchase, if it isnt broke than that is a great deal. that steeda intake is the best on the market. I like it becuase its all one peice the maf housing and the heat shield, unlike the jlt and c&l where that is two peices. there will be no screwing with maf sensor placement that can mess up how your car runs. The steeda keeps that maf in the same spot as stock. Also that heat sheild will seal to your hood better then others and do a better job of keeping the hot air from the engine bay out of you intake. After all, that is the job of a cold air intake. Fact is the steeda fits the best, this isnt my opinion, its fact i have others in my possesion and have compared. The steeda was actaully made for the s197, these others look like you have to rig it up and could do so on any car.
To answer your question, you can use the stock inlet elbow, i did it for a long time before i got the carbon fiber inlet elbow. once i put that inlet elbow on, i could feel a slight difference, very slight, but you could feel it at the low rpms it seemed like. So either way even if you buy the regular 99 inlet, or just go with stock, you got a good deal. As for the elbow and tune, there is no affect, so you could get the tunes now with the stock inlet tube and switch anytime you want. Last edited by 07stanggt : October 7th, 2008 at 09:27 AM. |
I like mine, been running it for 2 years with no reason to change
![]() Nice find!
![]() http://www.youtube.com/watch?v=0r_8yTklKew <--12.60 @ 108 before heads/cams; 12.65 @ 114.23 after
Authorized Vendor
2007 GT
12.40@114.55
and i guess your asking which you should get, plastic or cabon fiber. Well other then steeda claiming a horsepower difference, i do know that at the track when everything else in my engine bay is hot, that carbon fiber tube is not. it doesn hold heat at all it seems like. is that worth 200 or an extra 100to you, thats your choice
2007 MUSTANG GT
Did you notice much from the stock inlet tube
To the steeda elbow.
why do you need a tune with the steeda "cai" if its just an open filter and no changes? correct me if im wrong but looks like a fancy replacement for the filter and maf housing...??? and if the elbow doesnt change for more flow or smoothing out the air then whats the poiont?
08 Mustang GT/CS, Boom Tubes, 4.10's, BamaChips Tune.
#10 | |
Authorized Vendor
2007 GT
12.40@114.55
You need a tune becuase the maf housing, I.E the pipe that you plug the MAF sensor into is bigger, its 90mm and it flows 1030cfm as appossed to stock which is like 580 i think or something, it might be 680 i cant remember. Someone on here will know. the biggest you can go without a tune is like 800 which is what the no tune cai's flow. The JLT and c&l street are 89MM maf. the only cai bigger then the steeda is the c&l racer which is 95MM. The point of the high flow elbow is two fold, first lets just talk about inlet air temp. remember we are talking about a cold air intake, its not called a big air intake or a shiny air intake or a pretty air intake. It's expressed purpose is to feed the coolest air possible to the manifold This is why its not just sitting right in front of the TB with direct flow, The elbow can be more a less efficient at this, this is the debate over plastic, shiny painted aluminum so forth, which absorbs less heat, which holds less heat. the cooler the air, the more the HP, period. The steeda with the carbon fiber inlet elbow claims that inlet air temp is 5 degrees above ambient, or outside air. this is the best of the others, some of which are 20 degrees above ambient on hot days. someone can correct me if im worng but i think for every 20 degrees you can cool the air its a 5% hp gain? thats 15 horse on a 300 horsepower engine. This requires no tuneing, its no different then makeing more hp on a cool day then a hot day. The second place the elbow might help would be in better bends, less turbulance, whatever, im not going to get into that some tuner could talk about it. also, over the stock rubber house that will crimp and move, you deffinatley can see where any hard inlet elbow can help keep air flow consisitent. very slight like i said, felt stronger in the low and mid range. but i put it on in the winter to. probably would have been more noticeable in the summer. |
ok that makes sense now i didnt know the steeda maf housing was bigger.. i figure if your going to go for that might as well get the elbow to smooth stuff out.
thanks gfor the insight 07so if i buy this? i can make my own cai?
Authorized Vendor
2007 GT
12.40@114.55
well i dont know if you can use that maf becuase it puts the sensor in a different location then what is on our mustang. that is for a lightning. for some reason, and maybe someone else can comment on this but if the maf sensor is not in the same place it can mess things up. this is the problem that some people with the c&l run into because the housing is its own peice and it just sits in a hole in the heat shield connected to the inlet elbow. its something about haveing the sensor in the 3 oclock position. I dont get it thats just what i hear and i know that some guys have had to turn there maf to get that sensor positioned right and it got rid of some pcm problems.
Now with that said, emay has rigged his own cai unit up. So in short yes if you just want to buy a mustang maf houseing which you can do from c&l and probably Jlt then i guess you could make your own heat sheild or use no heat sheild like emay. And hell maybe that one will work but you should ask a mustang tuner or even call c&l and ask them. |
2006 Mustang GT Vert
I went with STEEDA and happy with it. It's not a track car and the STEEDA SCT Tune is conservative and that's fine with me. They say the tune is required so I guess the above explains that. Hated the stock crap, looked at other manufactures and didn't want hot metal.
So you guys like your carbon fiber elbow, huh? Hmmm.....I have the upgraded large inlet but carbon fiber wasn't out yet.
![]() Shar 06 GT Vert, MM & FF Dec 07 Ladies Edition Steeda CAI/Tune, FRPP M5230-5GT exhaust, CDC Light Bar & Sequentials, Flaming things,& MGW Bling |
#14 | |
Authorized Vendor
2007 GT
12.40@114.55
Yea the tunes you got with the steeda sct are fine. also when did you get that? does it have the tune for the delete plates on it, becuase now it comes with that. yea im happy with the carbon fiber, everyone seems to like the look of it, i actaully dont like the look of it. LOL, i thought it looked tough with the stock inlet tube on there. what i do like is even after hot laps at the track that carbon fiber is cool. |
#15 | |
Delete plates? I have an 87 octane tune if thats what you mean, LOL. I am considering ordering another inlet and sending out for custom air brush paint like my plenium/fuel rail covers....OR just get the carbon fiber. OR just get that ROUSH fascia...God, the money pit!!!!!
Authorized Vendor
2007 GT
12.40@114.55
no with the power package now steeda sells, the cai, inlet tube and xcal. the xcal has a tune on it for the steeda delete plates.
#17 | ||
2007 MUSTANG GT
So I was looking pick one of them up used, so far no luck there. Do you offer the inlet elbows for sale? I waas going to go thru Brenspeed because I have had great luck with them & love their customer service. But you have been very helpfull & I thought maybe I could throw some of my mod $$ your way..
Came with two loaded tunes, 87 and 93 <which is what I run> or 91 if that's what is available in your state. I have the larger intake, maybe those are now standard?? It does what it's supposed to do and looks fine. Good luck and just get one . : ) I got mine last year. I have two filters because they should be cleaned each oil change. I have the my dealer clean one put it in a box and put the other one on. Just more convenient for me PLUS I have never cleaned one and if you do it wrong....you could wreck the engine.
2007 MUSTANG GT
Why is the rubber seal thicker on mine than yours?? did they change them at some point?
2007 MUSTANG GT
Thanks
Threads Similar to: Anyone running a Steeda CAI?
| steeda cai or bullitt cai | dtom | 2005+ | 30 | July 9th, 2008 02:02 PM |
| Steeda CAI | bheet | 2005+ | 3 | June 20th, 2008 07:49 AM |
| steeda cai | steedafied05 | 2005+ | 5 | August 26th, 2007 11:21 PM |
| Anybody using a Steeda CAI? | miloman | 2005+ | 3 | April 23rd, 2007 12:28 PM |
| Steeda CAI | west92 | 2005+ | 21 | January 25th, 2007 08:14 PM |
