maximum motorsports rollbar install - Forums at Modded Mustangs
post #1 of 35 Old August 1st, 2013, 02:11 PM Thread Starter
MM elder
casper gt's Avatar
getting ready to install my rollbar this weekend/etc & thought I'd get a thread started to let you guys/gals follow how things go.
here's what I'll be installing,
Drag Race 6-point Mustang Roll Bar, standard door bars, fixed harness mount, 2005+ hardtop [Mm5RB-20] : Maximum Motorsports, the Latemodel Mustang Performance Suspension Leader!
heres a shot of the rollbar in the box/packaging material, to say they box this part well is a serious understatement.
I'll update this thread as things go along with the install.
MM BRACKET RACING CREW CO-FOUNDER
2012 300a GT A6......10.78 @ 124.........sold
2014 301a GT A6.............12.73 @ 112........d/r only
casper gt is offline
post #2 of 35 Old August 1st, 2013, 02:15 PM
'Murica
jdmpwr07's Avatar
Looks like a quality part. Interested to see after pictures of how much space/interior room is taken up.
2009 Chevrolet Corvette
jdmpwr07 is offline
post #3 of 35 Old August 1st, 2013, 02:23 PM Thread Starter
MM elder
casper gt's Avatar
I don't think the space lost will be a complete disaster, but the rear seat will no longer be useable (not like anyone ever sat back there anyway).
I do like to drive this car with my left leg resting on the door so I guess that will take some getting used to.
post #4 of 35 Old August 1st, 2013, 02:25 PM
awesome are u gonna paint/powdercoat it or anything first?
kk_kalina is offline
post #5 of 35 Old August 1st, 2013, 02:26 PM
manolith's Avatar
How much does it weigh? I am really interested on this. It looks like a pita to install but it should be worth it.
2011 GT. Paxton@10psi-ID1000-KB bap-O/R Xpipe-GT500AB-Boss intake-4.10 gears-TA girdle-N2NB Wot box-K Springs-UPR Pro series control arms-Big and littles. 780,000 rwsqp.
https://www.youtube.com/user/Manny32V
instagram: fumaliche
manolith is offline
post #6 of 35 Old August 1st, 2013, 02:33 PM
Don't BAAAAH 'Til Goatsday
xXFallout's Avatar
I could use one of those......
From here to infirmary......
0-60mph 0.5 sec. And we have liftoff!
xXFallout is offline
post #7 of 35 Old August 1st, 2013, 02:37 PM Thread Starter
MM elder
casper gt's Avatar
I haven't actually put it on a scale, but once it's out of the box & packing materials (yep those are 2 x 6's screwed to the bar to hold it in place in the box, lol) & with both the front & rear bars attached to the main hoop, it's not too bad to pick up, it does have some weight though, if I had to guess, maybe 70 lbs?
I did gut the entire back seat package tray area though to try & help a little (rsd, sound deadening, rear seat belts & child seat anchors, etc).
as to the install, it doesn't look too bad,
CJ’s upgrades our Gotta Have It Race Mustang’s safety with a Roll Bar. | CJ Pony Parts
post #8 of 35 Old August 1st, 2013, 11:47 PM
Does MM still require you to weld the rear tubes to the hoop in order to make the roll bar NHRA legal?
NoSlo5oH is offline
post #9 of 35 Old August 2nd, 2013, 12:05 AM
Ford Master Tech
Blazer707's Avatar
Yes I believe so, I installed mine a couple months ago and welded the rear tubes to the hoop.
I weighed all the bars minus the hardware and it was around 75#'s.
Install is very easy and with the EZ door bars removed and driving around you do not loose anything other then the rear seat function ability.
-Thomas
www.teambeefcakeracing.com
Lund...Paxton...Auto...E85...
Blazer707 is offline
post #10 of 35 Old August 2nd, 2013, 12:13 AM Thread Starter
MM elder
casper gt's Avatar
yep..........
post #11 of 35 Old August 2nd, 2013, 01:15 PM
manolith's Avatar
So is better if you just ditch the rear seats and only gain like 35lbs with the extra safety equipment..
manolith is offline
post #12 of 35 Old August 2nd, 2013, 01:41 PM
Ford Master Tech
Blazer707's Avatar
There is most likely enough seat belts, rear seats, misc brackets and trim pieces to get damn near a wash with the cage going in.
post #13 of 35 Old August 2nd, 2013, 05:58 PM
wbt
Not at 75lbs. for the roll bar. You may be able to knock 20lbs. off with the removal of existing stuff. Certainly not 75 or even 50 if you go with a chromeoly roll bar. It will always be a weight adder either way.
wbt is offline
post #14 of 35 Old August 2nd, 2013, 06:46 PM
Ford Master Tech
Blazer707's Avatar
Now im curious. Ill weigh everything out of the back this weekend.
post #15 of 35 Old August 2nd, 2013, 11:03 PM
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
Subbed
Convertible Crew Founder
Proud Iraq and Afghanistan War veteran
700 RWHP Club Member #1
Vortech T Trim @18 PSI
604 RWHP 516 FT LB
11.50@121.77@ 523RWHP
Precision Turbo 7675 CEA @ 20 PSI
738 RWHP 691 FT LB
10.9 @ 131 MPH
SSG Pate is offline
post #16 of 35 Old August 2nd, 2013, 11:22 PM Thread Starter
MM elder
casper gt's Avatar
little update from today.........
first, I wanted to do this in the driveway just so you guys can see that it can be done that way, lol.
getting ready
test fitting
all in all not too bad so far, I have everything fitted/etc ready to come back out & get welded & painted in the morning.
post #17 of 35 Old August 2nd, 2013, 11:23 PM
kdanner's Avatar
Damn, looked at this on the MM website. Unless it can be bought a lot cheaper somewhere other than direct, that thing costs significantly more than I paid Wolfe for chrome moly.
kdanner is offline
post #18 of 35 Old August 2nd, 2013, 11:28 PM Thread Starter
MM elder
casper gt's Avatar
I paid about the same as wolfe wanted (it was right around 800 shipped) but I have a phobia about floor mounting if I can avoid it so I went with this one.
post #19 of 35 Old August 2nd, 2013, 11:36 PM
Ford Master Tech
Blazer707's Avatar
Yea I bought the MM roll bar for $799 shipped off ebay. The wolfe roll bar in mild steel with what I wanted came out to about $900 shipped.
post #20 of 35 Old August 2nd, 2013, 11:36 PM
'Murica
jdmpwr07's Avatar
Any plans on seats and steering wheel? Interesting to see how high it comes up. Safety is king though.
jdmpwr07 is offline
Human Verification
