12' sixxer
Tire Size???
Hello all i have a 12' sixxer with the 17inch rims. I like the rims that are on the car currently but the puny 225's are'nt cutting it! my question to everyone is i would like to drop my car on H&R Super Sports. what do you think the widest i can go tire size on the rear?
Priest of the Car Gods
Why do you want wider tires, form or function?
12' sixxer
Function I do not want to scratch gears and would like to grab more from stops...
2011 V6 Performance Pack
You can go at least to 315........
There were 3 different drops for H&R Super Sports for our car back when I was in the market for springs (a year ago). Might want to be a bit more specific about what drop you want.
H&R SS's; Tokico DSP-12's; MM CC Plates; BMR Panhard, UCAM, UCA, CABs, LCAs; JLT Oil Catch |
If I understood the OP correctly, he wants to stay with the stock wheel, so while 315s may fit in the wheelwell they're not going to work.
OP if it's function you're after, you need to go to wider wheels if you want properly performing wider tires. If you stick with your stock wheels, keep the stock size, but upgrade the compound. A 225 DR is going to give you more grip than a 315 Sumi allseason.
12' sixxer
Yeah i kinda scratched my head on the 315's for a second i had 315's on a old car of mine but that had the rim size to match with the tires.. and yes i was worrying a little about the tire sizes never thought about just up grading the compound! ha whoops
12' sixxer
and through all the searching i have done i cannnot find a 225 DR thats why i in part asked what sizes yal thought i could run and still not bubble the tires and run on the center patch of rubber
2011 Ford Mustang V6
13.77@104mph
the widest
From my understanding, the widest tire you would want to put on a 7 inch rim, somewhat safely, would be a p235. If you want to create an illusion of wider, try and find one with a taller sidewall. Drop the car only one inch using those steeda ultra light springs that give a better ride than factory springs. Then try and find some p235/60 tires. That be the best look and tread width for 7 inch rims, in my opinion
2011 Mustang V6 Base
I've got 305's in the rear and 285's in the front (speedo corrected) and they fit perfectly. I'm lowered on FRPP GT500 PP wheels and FRPP springs. I will probably be buying coilovers eventually because I can tell from what I've measured that I have a lot more room in there. You could probably do 335's if you really wanted to; though you need not. I must say though, the combination has made a HUGE difference in every aspect of how the car drives and I'll never go lower on size. I started off with 275's on these wheels. This is only a slight stagger. 275's in the front would be okay with my rears, but I like the 285's
12' sixxer
see i perornally like the factory rims on the car i just want a drag radial or some stickier tires that i cannnot find
Companies don't make drag radials for economy consumer wheel sizes - They (genuine drag radials) are illegal for use on public roads anyway. It is interesting that there also isn't a near-DR alternative available either (NT05's, for instance), but there's probably no market for it either. You're probably one of a dozen people looking. ;]
If you are really concerned about the function of tires and are dead set on keeping your stock wheels, you should just find some decent performance tires: tirerack.com/tires/TireSearchResults.jsp?skipOver=true&width=225%2F&r atio=45&diameter=17" tirerack.com/tires/surveyresults/surveydisplay.jsp?type=UHP tirerack.com/tires/surveyresults/surveydisplay.jsp?type=MP God damnit. Seems the forum is injecting some misdirect on my links. Or it's Tirerack, but that shouldn't be possible. Bah. Copy and paste those URLs, I guess. :\
2010 Mustang Coupe
14.99@94.4
nitto NT555 255/50/17 will fit the stock 17x7 rims
here's a link NT555 and also the Nitto Invo in the same size fits as well. this is according to the size chart ont heir website. the 7" rim is the smallest size rim you can use with these, and they are the same diameter as stock so it wont throw your speesometer off.
![]() GO: Diablosport Trinity w/93 race tune from Bama Ford Racing T-Lok, Motive Gear 4.10's BBK Cold Air Intake Stack Racing Throttle Body Spacer SHOW: Rear Deck Lid Blackout Panel |
2011 Mustang V6
Just make sure you get a tire specc'ed for a 17" wheel, otherwise you are going to feel like you are floating.. That could cause some uneven tread wear especially if you drive fairly aggressively (your fronts could roll, potentially causing sidewall wear if you're really aggressive.)
That Nitto NT555 looks interesting. I'd want to see it on a 17" rim to see how much it hangs over though.. That much tread on a 17" wheel, that just doesn't sound right. (Sure they sell it, but....)?
![]() SMR# 2071 Eibach Pro Plus kit: Shocks, springs, swaybars - Adj. Panhard bar - Eibach LCA's JLT CAI - Bama Tuner running 93R - 18x9 GT500 AM Wheels, 255 Sumitomo Shoes |
2010 Mustang Coupe
14.99@94.4
according to the Nitto website the nt555 and invo 255/50/17 fit 7.0"-9.0" rim with 8.0" being the best size. the diameter is the same, its just a couple inches wider than stock
Threads Similar to: Tire Size???
| tire size? | dbmustanggt | 99-04 | 9 | June 7th, 2011 04:40 AM |
| Rim Size/Tire size | Garagebuilt01 | Modular Mustangs | 20 | February 25th, 2011 08:05 AM |
| Tire Size | Steeda187 | 99-04 | 4 | January 11th, 2011 03:56 PM |
| tire size | adrenaline=lifeline | 99-04 | 10 | April 22nd, 2009 09:19 AM |
| what is the max tire size | 02stang281 | 99-04 | 4 | January 3rd, 2007 12:29 AM |
