Why?...becasue I Said SO!
2011 Shelby GT500 Gets Less Weight, More Power and Improved Handling![]() Thanks to an all-aluminum block and a numerous other upgrades, Ford is promising the 2011 Shelby GT500 will offer more power, a lower curb weight and improved handling. The new aluminum block weighs 102 lbs less than the old cast-iron unit and puts out 10-more horsepower for a total of 550-hp. Torque is rated at 510 ft-lbs, 80 percent of which is available from 1750 to 6250 rpm. Plus, a new two-row intercooler delivers 40 percent better cooling so this sports car will perform with optimum potential even on the hottest of track days. Of that 102 lbs, 8.5 lbs was saved by using a state-of-the-art plasma coating for the cylinder walls, rather than having to use steel sleeves. The result of this drastic reduction in weight, especially over the front axle, will result in a much more neutral vehicle to drive, especially at the limit. The weight reduction will also work to improve acceleration and braking, and even has tangible fuel-economy benefits. While owners aren't too likely to care that the EPA rating has gone from 14/22 mpg (city/highway) to 15/23 mpg, they will when they discover that this improvement means the 2011 GT500 is the first modern Shelby to avoid the gas guzzler tax. Along with the weight loss, additional handling improvements come from Ford's new EPAS electronic power steering, which the automaker says delivers a better feel and a more precise movement, while also enabling less effort during low speed maneuvers. Also new for 2011 is an optional glass roof and standard HID headlights. Convertible models are now 12 percent stiffer. Oh, and lets not forget an all-new 2.75-inch exhaust system, with more volume when you want it and less droaning when you don't. Those seeking even more performance from their GT500 will want to opt for the SVT Performance Package with some aerodynamic changes, lighter wheels shod in new Goodyear Eagle F1 SuperCar G2 tires, a higher rear axle ratio, a lower ride height and stiffer springs. Ford claims that on a 2.3-mile road course, the SVT package will net a 3 second per lap improvement! Ford will officially unveil the updated 2011 Shelby GT500 at the Chicago Auto Show on Wednesday, February 10th. More: 2011 Shelby GT500 Gets Less Weight, More Power and Improved Handling on AutoGuide.com |
Threads Similar to: 2011 Shelby GT500 Gets Less Weight, More Power and Improved Handling
| Shelby and SVT plans for the 2011 revealed today! | 1FastFox | The Clubhouse | 58 | February 11th, 2010 09:09 PM |
| Chicago Preview: 2011 Ford Shelby GT500 Set to Debut, Images Leaked | Administrator | 2011+ | 0 | February 5th, 2010 11:58 AM |
| Shelby GT350 Returns Based on 2011 5.0-Liter Mustang GT | Administrator | 2011+ | 5 | January 21st, 2010 12:41 PM |
| 2011 GT Weight | DarkCandy08GT | 2005 - 2010 | 9 | December 29th, 2009 10:37 PM |
| New Shelby GT500 | Coltdog | 2005 - 2010 | 48 | January 9th, 2008 09:20 PM |
