steig ported eaton and CAI power loss? - Page 2
Old December 25th, 2008, 05:39 PM   #21
03snakeminated is on a distinguished road
same dyno, same operator, weather if anything was a little cooler 2 weeks after
Old December 25th, 2008, 06:39 PM   #22
20psirabbit is on a distinguished road
oh also how many run pulls previous to the run you're quoting on both trips? ie: are you quoting your numbers from the first pull both instances, third pull, differing pulls etc.
maybe you made xxx hp the 1st trip but -20 hp the next trip but on the 3rd pull instead of the 1st? and was it iced down? all these play in.
Old December 25th, 2008, 07:00 PM   #23
different days, higher #'s for last pull on 1st day. lower numbers 2 weeks after, 1st,2nd.3rd.4th pull icing the i/c everytime numbers didnt change maybe 2-3hp
Old December 25th, 2008, 11:40 PM   #24
check for fault codes, you could have something like a coolant temp sensor not doing it's job. that's why the wideband is important, to make sure the mixture is consistent as well. other than that man i don't really know. did you possibly change the wheels and tires or anything else as well?
Old December 26th, 2008, 12:01 AM   #25
just the tires, went from bold worn out street tires [can't remember brand] 275/40/17 .
to 2 285/40/17's nittos streets [not dr's]
Threads Similar to: steig ported eaton and CAI power loss?
power loss Elder 4V / SVT 8 September 8th, 2008 04:31 AM
okay ebay cai are junk and cause loss of power.for me anyway MustanG_guy17 V6 Mustangs 9 November 6th, 2007 11:15 PM
power loss? xedubx 99-04 16 June 20th, 2007 10:52 PM
