oil on plugs
Old December 22nd, 2008, 04:25 PM   #1
rob madison is on a distinguished road
oil on plugs
i have a 1998 cobra, my problem is on the driver side of the motor, my second and fourth slots have oil on the plugs. i noticed this when i changed the plugs. my question is would i come out cheaper getting a new motor, or getting mine worked on?
Old December 22nd, 2008, 05:37 PM   #2
Moderator
wraitherx's Avatar
'99 SVT Cobra
wraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud of
iTrader: 11 reviews
there oil from the internal (inside engine) or external (plug)? It really depends on how much money you got to spend. It will probably be cheaper getting it worked on if you can find a good shop that can take care of you. But I also have heard of some companies selling the stock short block for cheap (cant remember them though)
BUILD 2 IN PROGRESS
Old December 22nd, 2008, 05:50 PM   #3
'97'Cobra's Avatar
1997 Mustang Cobra
8.65@84mph
'97'Cobra has a spectacular aura about'97'Cobra has a spectacular aura about'97'Cobra has a spectacular aura about
it would be cheaper just to rebuild what you have. correct me if im wrong but thats going to be rings most likely if you have oil on the spark plugs?
i usually wave first, but if the guy is sexy and i'm drunk, i might lift up my shirt and flash him as well.
MM Cobra Club Member #61
Old December 22nd, 2008, 06:17 PM   #4
Mustang RacR94's Avatar
03 mach 1
13.2@109
Mustang RacR94 will become famous soon enoughMustang RacR94 will become famous soon enough
Send a message via AIM to Mustang RacR94
isnt that either a ring or a valve guide or sometin
2003 Mach 1, 5 speed
U.S. Army - 11B
"And on the 8th day god created the infantry and all hell stood at attention"
Old December 22nd, 2008, 07:16 PM   #5
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
can be either one.
BUILD 2 IN PROGRESS
Old December 23rd, 2008, 07:40 AM   #6
acobraman's Avatar
96 Cobra Vert. , 97 Cobra
12.55@111.33
acobraman is on a distinguished road
If the oil is in the hole with the plugs, you need new gaskets, if it's on the bottom of the plug, you need other more costly things.
Old December 23rd, 2008, 01:36 PM   #7
2003 Cobra
1StockGT is on a distinguished road
Send a message via AIM to 1StockGT
Be more specific on where the oil is exactly on the plugs. Does the electrode have oil on it or is the oil on the exterior of the plug?
Old December 23rd, 2008, 06:39 PM   #8
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
Originally Posted by wraitherlx View Post
is there oil from the internal (inside engine) or external (plug)?
Uh... didnt i already ask ^ but yeah you need to be a little more specific so that we can help.
BUILD 2 IN PROGRESS
Old December 24th, 2008, 10:53 AM   #9
the oil was on the exterior of the plug,(where the coils are) i think i probably need a gasket. I noticed a piece on the spark plug wire when i took it back off yesterday. A co-worker took a look at it, he said if theres not blue smoke coming out the pipes, then it may be a gasket.
Old December 24th, 2008, 01:26 PM   #10
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
you have a gasket leak. just for your FYI the driver side valve cover is a PITA to remove, just search and you will find.
BUILD 2 IN PROGRESS
Old December 26th, 2008, 02:31 PM   #11
Ryan Paymaster's Avatar
1996 Ford SVT Cobra
13.36@102
Ryan Paymaster will become famous soon enough
Send a message via ICQ to Ryan Paymaster Send a message via AIM to Ryan Paymaster Send a message via MSN to Ryan Paymaster Send a message via Yahoo to Ryan Paymaster
If it's on the tip of the plug have fun getting your rings and/or valve seals replaced. Check thoroughly for blue smoke at high RPMs or even start up though. Some people lie to themselves about exhaust color. Have a friend check it out too. Motor is known for valve seals and with a decent mileage on your car a ring or two could be hurt.
If it's on the outside it's probably the gasket issue.
Slowly but surely creeping into the 12's on a stock N/A block...
Threads Similar to: oil on plugs
99 Cobra 4.6 Oil Cooler machined hole porting Oil? ocJB3 99-04 3 January 3rd, 2011 07:31 PM
Do stock foxbodys have 2 oil drain plugs? 93hatch 5.0 Mustangs 13 May 12th, 2008 02:43 PM
Spark plugs,antifreeze, oil and power steering fluid questions for the guys who know CODEBLUE 99-04 5 February 25th, 2008 05:12 PM
kickout 7qt oil pan w/low oil sensor hole Iownastang 5.0 Mustangs 2 July 19th, 2007 02:17 AM
Billit Oil Pimps vrs GT and Cobra Oil Pumps WAR-PARTY 99-04 2 August 22nd, 2006 01:55 AM
