LinkBack (5) | Thread Tools |
#1
97 Mustang Cobra
Eaton M112 on 97 Cobra
Has anyone tried to install a supercharger from an 03 or 04 cobra on a 97 Cobra. I'm thinking all i need is supercharger, intake plenum, and injectors. What else would i need and is it worth it?
lower intake manifold, plenum, maybe a throttle body, another intake(like CAI), alternator relocation, all the tensioners, possibly a different crank pulley as I beleive only the 96 corbas came with a lower pulley for a blower, and of course another tune, some vacuum lines might need to be lengthed or shortened. the whole blower cooling system, im sure there's some other difference's and stuff that will be needed, possibly another MAF, and maybe a better fuel system
2003 Mach 1, 5 speed ![]() U.S. Army - 11B "And on the 8th day god created the infantry and all hell stood at attention" |
The Doctor
'01 Cobra Vert.
Just buy a kit designed for your car. It's going to be a b***h to put it on your car. It's very difficult to track down the correct parts needed for the swap and cheaply as well. By the time when you're all said and done you'll have spent a decent chunk of money on used stuff (some new stuff) and it will take you a while to hunt everything down. A kit for your car is the best way to go to save yourself a boat load of hassle.
96 GT
![]() iTrader: 2 reviews
Easiest way to do it is pull your engine out and get terminator long block and drop it in.Even if you get 03-04 cobra supercharger that's probably 1/10 of your total swap cost.You also need 99+ cobra heads.Your bottom end and tranny are weak and those are the first things which will go after the swap.Here is the timing cover mess on 04-04 cobras
![]() Here is the part's list that would be needed when doing the supercharged 03 cobra swap on 99-01 cobras and 03-04 Mach 1 . (6312) Crank pulley /Harmonic Balancer (6312B) Supercharger Crank drive pulley (8678A) Pulley w/mount Replaces stk. alt. Pulley on 99-01 Cobra’s and 03/04 Mach 1’s (6B209B) Pulley bridge assembly for S.C. (8678B) Idler pulley,timing cover LH side (6D080) Timing cover (10A313) Upper alternator bracket (10153) Lower alternator bracket (10346) Alternator 1U2Z-14S411-TA Electrical connector (alt. to harmness ) (6B209A) Tensioner on timing cover (8260) Radiator hose (8A593) Radiator hose (8K576) Radiator hose (8548) Water cross over pipe (6881) Cobra oil cooler adapter Note: Use your stock gasket from your adapter or a leak will occur with a Cobra gasket! (6A642) Cobra Oil cooler (9002) Cobra fuel tank (9H307) Cobra fuel pump (6F066) Eaton supercharger (9424) Lower intake (6K775) Garrett factory intercooler 3U2Z-14S411-JUA IAT sensor connector (9H308A) Intercooler hard lines that hug the block (9N491A) Intercooler hard lines that come from the h/e (9L443A) Intercooler pipe to heat Exchanger that goes from the i/c adapter to i/c res. (9L443B) Intercooler pipe to heat Exchanger that goes from the i/c adapter to the hard lines that hug the block (9L443C) Intercooler pipe to heat Exchanger that goes from the hard line to i/c pump (9L443D) Intercooler pipe to heat Exchanger that goes from hard line to hard line coming from h/e (9L443E) Intercooler pipe to heat Exchanger that goes from hard line from h/e to i/c pump (9L443F) Intercooler pipe to heat Exchanger that goes from hard line and connects to h/e (9L443G) Intercooler pipe to heat Exchanger that goes from hard line and connects to h/e (8501) Ford / Bosche water pump for intercooler (8K226) Factory heat exchanger (8A193) Heat exchanger mounting bracket (8C386) 2each bracket clamps for h/e (9N491B) Lower manifold to intercooler water adapter (9A589) Plenum (9E926) Throttle Body (9B659) Intake tube from maf to t/b. (9F715) IAC valve (9F593) Injectors (6F089) Boost bypass actuator (8N500) Intercooler pump bracket (9A825) Cruise control cable (9A758) Throttle cable (9728) Throttle and cruise control cable mounting bracket (12B579) MAF (9D475) EGR valve (9D477) EGR tube (6C324) PCV tubing (9F479) Sensor on the back of the S/C (9J432) Bracket for vacuum stuff on left side of the S/C (9H465) Vacuum stuff (9J459) Vacuum stuff (9J460) Vacuum stuff (9E498) Hose's or tube cluster of connectors for the vacuum parts above (9F670) IAC gasket (6020) Timing cover gasket LH side (6020) Timing cover gasket middle (6020) Timing cover gasket RH side (9H486) Intercooler to S.C. gasket (9L437) Plenum to S/C gasket (9D476) EGR gasket |
2011 ram 1500 hemi
jesus, i got a headach form trying to figure out that belt system
vmp500 hp. jba lts. powerhouse d/s Sold
Saving up for another one
(im saying all this in case you dont already know)
and REMEMBER, with whichever route you take, make sure youll have enough money left over to get a DYNO TUNE. i wouldnt trust using a handheld tuner or something like that after putting a blower or turbo on an engine. and dyno tuning can be expensive too. when i had my car done, the tuner said that the basic flat rate for all cars was $400. (of course you could probably always find it for a lil cheaper) REMEMBER-REMEMBER-REMEMBER!!!!!!!!: if you go through with your plan to put a blower on your car, DONT go driving the car hard or under heavy throttle until you get a good tune done. without a good tune being done, theres a high risk that your engine would have detonation, which can crack pistons and rods. |
#7 | |
1994 GT
Cohagan Engineering, Inc. |
#8 | |
if thats true, then i got fucked ![]() im pretty sure thats what he told me. ill try to find the receipt. hopefully 20PSIRABBIT or THEdarkness03 gets in on this thread. they had their cobras pullied and dyno tuned at the same place I did. maybe they can correct me on his prices if im wrong.
![]() Yes those are cobra R replica mustang wheels on my 300zx 03 Cobra- gone but not forgotten 90 Nissan 300zx 00' Yamaha YZF 600 Last edited by WilltheThrill; December 27th, 2008 at 05:44 AM. |
yep, just looked at the receipt. he charged me $400 total for all the dyno time.
97 Mustang Cobra
thanks guys I didnt realize how much of a hassle it would be, thought i finially found a cheap way to make some decent power.
#11 | |
1994 GT
how long did the tune actually take??and how many pulls did they do..cause some charge like 75 for three pulls or 75 per hour..turbos can take like 3-4 hours somtimes...and if the shop fucked you, they probably fucked the other guys to which is bullshit..i got fucked by the shop who did some of my work while i was out of state to
97GT & 97Snake & 00L
T.B.A
yeah i was thinking tha same...well wat is the best bolt on for these 96-98 cobras...
![]() 97 Cobra & 00 Lightning Beauty & The Beast I rev next to hybrids so they can hear me kill the environment ![]() MM Cobra Club Member #77 MM Lightning Club Founder |
That sounds about right.The first time you go they start from scratch and need to get a baseline and then fine tune it from there. Whenever you mod again and go back it is always a lot less. My first time with the new set up was 400 and whenever I go back it is about 100-150 to do it correctly. This is not the time to cheap out since longevity and power are all in the tune. It is insurance that all your hard work and $$$ are paying the dividends you expected.
The Doctor
'01 Cobra Vert.
^ Jumper, where'd you get all your stuff done at? Did CJ's do the install/help you out? And where'd you get your dyno tune?
i cant remember for sure but it was definitely under an hour. |
#16 | |
Priest of the Car Gods
This swap only makes sense if you've got a wrecked car to swap all the parts off of, and honestly I still wouldn't swap them into another working Cobra: I'd go get a on-its-last-leg GT to swap the drivetrain into.
O o /¯/______________________ |BLAAAAAAAAAAAAAAAAAAAAAAAAARGH!!! \_\ Buy my Bronco, special deal for MM folks |
#17 | |
97 Cobra
Weight up front is the hardest to remove, hardest to lower, and generally a road block to even better handling. If you can make enough power to have fun with the Teksid there is no need for an Iron block. Forge the Teksid and enjoy the weight loss. If you plan on making well over 1000rwhp then get Iron if you cant tune and keep things together. A well tuned Aluminum block will last just fine. Just requires a bit more precision with crazy power levels to keep power going through the block and not into it. |
#18 | |
96 GT
#19 | |
97 Cobra
#20 | |
My understanding is that the forged crank with cast rods/pistons is to create a motor capable of high rpm. If you're not needing the extra strength of forged pistons, it's just extra weight slowing you down, and N/A, these motors don't need forged pistons. However, to hold that motor together, it does need a forged crankshaft.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/4v-svt/102847-eaton-m112-97-cobra.html
| Page 2: M112 Engine images & M112 Engine stock photos at HealthHaven.com | This thread | Refback | June 30th, 2010 09:11 PM | |
| Oem 2003 mustang cobra supercharger - Lincoln vs Cadillac | This thread | Refback | May 6th, 2010 02:19 AM | |
| Oem 2003 mustang cobra supercharger - Lincoln vs Cadillac | This thread | Refback | May 6th, 2010 01:57 AM | |
| Eaton M112 Cobra Supercharger on Kosmix | This thread | Refback | April 30th, 2009 08:11 PM | |
| Eaton M112 Cobra Supercharger on Kosmix | This thread | Refback | April 5th, 2009 05:15 PM | |
Threads Similar to: Eaton M112 on 97 Cobra
| Eaton M112 | Lefty | 4V / SVT | 10 | July 3rd, 2008 04:13 PM |
| Eaton M112 installation | 00v6newbie | V6 Mustangs | 22 | May 8th, 2008 03:32 AM |
| Eaton M112 | rob3980 | V6 Mustangs | 8 | April 22nd, 2008 01:36 AM |
| m112 eaton | emgjsdk1 | V6 Mustangs | 13 | February 16th, 2008 10:16 PM |
| Will An Eaton M112 Supercharger Fit On My GT? | phisherize | 99-04 | 6 | November 16th, 2006 06:54 AM |
