Tranny question
Old January 20th, 2009, 11:17 PM   #1
2004 Mustang Mach 1
14.02@101.27 pretune
RoBob31 is on a distinguished road
Tranny question
And no not the tranny's your thinking of you gutter minded fools.
I have no knowledge of a transmission other than it shifts diffrent gears. I have an auto 04 mach1 and looking through transmission parts. I see clutch kits and flywheels and was wondering if i can but these parts or if im stuck with the stock transmission?
04 auto Mach 1: Mods in garage
05 Pontiac GTO: K&N Intake filter, Muffler delete, ECU tune.
Old January 20th, 2009, 11:40 PM   #2
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
auto or manual? you can cahnge different things in teh drivetrain, just need to know what you are looking for.
Old January 20th, 2009, 11:51 PM   #3
TKOTLARZ's Avatar
1994 GT
TKOTLARZ is on a distinguished road
u can do things to both automatic and manual transmissions
Cohagan Engineering, Inc.
Old January 20th, 2009, 11:56 PM   #4
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
For an automatic, you can't do clutch kits.
If you want to change how your tranny acts, you have a couple options. One is a shift kit; this will affect how firm the transmission shifts, and how high of rpm it will hold gears. Another is a stall converter. Right now if you lightly hold the brake, and slowly press the gas, the engine will come up to a certain rpm before the wheels start moving (I'm not sure what stock stall is, I'm guessing 2k?). With a higher rpm stall converter, the car won't start moving until the rpm rating of the converter; so a 3500 rpm stall converter will allow you to bring the engine up to 3500 rpm when you launch.
That's not a perfect explanation, but I'm sure someone else will come and fill in what I've missed
O o
/¯/______________________
\_\
Buy my Bronco, special deal for MM folks
Old January 21st, 2009, 12:22 AM   #5
BYAHHHH!
Scott2001GT's Avatar
2001 Mustang GT
13.874
I have an auto 01GT and you can shift kit, j-mod, stalls, tuners, and get a tranny cooler asap. auto are prone to over heat and maybe shutter.
Old January 21st, 2009, 12:39 AM   #6
Oh, +1 on the tuner, ESPECIALLY with an automatic!
That would actually be the first thing I'd suggest, as you can undo whatever you do with a push of a button.
O o
\_\
Old January 21st, 2009, 12:47 AM   #7
Bearer of Bad News
Fluffy The Rhino's Avatar
I has mustang and legacy.
Slower than my Ruger.
Fluffy The Rhino is a splendid one to beholdFluffy The Rhino is a splendid one to beholdFluffy The Rhino is a splendid one to beholdFluffy The Rhino is a splendid one to beholdFluffy The Rhino is a splendid one to beholdFluffy The Rhino is a splendid one to beholdFluffy The Rhino is a splendid one to beholdFluffy The Rhino is a splendid one to behold
Are you not happy with the auto? You can always convert to manual.
~MOD NUTSWINGER~
My Tongue Soothes Razorburn
STOPSAYINGFAIL.COM
EVERY FART IS A GAMBLE
Just Think Of Me As A White Blood Cell.
Old January 21st, 2009, 12:52 AM   #8
Considering the OP said this:
I'm not sure that suggesting a tranny swap may be a good idea.
O o
\_\
Old January 21st, 2009, 01:01 PM   #9
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
Mach Boy has a spectacular aura aboutMach Boy has a spectacular aura about
It may not be a good idea but I was pretty much in the same shoes as the OP when I got my Mach. I'd driven a stick a handful of times and the Mach was fairly easy to learn with because it didn't take much gas to get it to move. On the other hand, I'd kill smaller engine cars because I wasn't giving it enough gas.
To the OP, you can get a flywheel if you want but it isn't something you will want to do with your level of knowledge. There are other things you could do that would probably net you better gains or performance. Seeing as you already have basic exhaust and intake mods I'd suggest going suspension or working on your rear. Throwing in a new set of gears really helps out the autos.
360HP / 345TQ N/A
Old January 25th, 2009, 07:14 PM   #10
Jsanders is on a distinguished road
wut
Threads Similar to: Tranny question
Tranny Question Euroeater95 94-95 3 April 13th, 2008 10:58 AM
tranny question 98 4.6 stang 96-98 6 January 14th, 2008 01:24 PM
tranny question oh2swapped 99-04 0 December 19th, 2007 04:12 PM
tranny question fsttang96 96-98 2 October 18th, 2007 08:22 PM
Tranny Question 5-0stank 5.0 Mustangs 3 September 14th, 2006 10:37 PM
